kcram - Pickups Host
I'm no expert, but I would go with the helper springs/extra leaves if you were going to leave the camper on the truck the majority of the time. If you were to take the camper off often, I would go with the air bags, that way you wouldn't have such a rough ride without the camper.
My owner's manual containes a list of GM truck towing capacities and the 1500 crew cab is only model that has this 5th wheel restriction.
If someone has more info on this topic please post it.
I hate it when companies do this kind of BS. I'm sure there are people out there with sliders in a CC model towing just fine. You only need to slide it back when the trailer is making an angle more than xx degrees with the truck. Otherwise the trailer will hit the cab. Depending on how "pointy" the trailer front end is, I bet most of the time you don't even need to slide it. It must have a pretty decent clearance otherwise you'd have to slide it every time you went around a corner.
On another note, I found the 1500 series a little lacking on the payload rating for fifth wheelers. Ones I considered had a hitch weight of 1200+ pounds. Most are over 900 pounds. After you add the passengers and gear you can easily go over 1500 pounds. You might consider the 2500 series - much better suited for 5th wheels. I ended up going with a traditional trailer.
triker57
I wouldn't get too crazy with pulling 5th wheels with a half ton. Unless it's those short ones ( no more than 24 ft.). Having a crew cab already lowers the amount your truck can tow anyway.
Google Pull-Rite and see if they make a hitch for your truck. I know they make one for those shortbed Dodges.
Any clarification will help.
If you have the factory tow package, just buy a controller with the connector for GM trucks in your year and all ya gotta do is plug it into the harness under the driver's dash next to the steering column. Yes, it's just a plug in. At least it was for my 03 GMC.
I don't know what these guys are doing with connecting wires to batteries,etc.
Factory tow pkg. Simple plug in.
I bought a Prodigy controller.
But it is an add-on in addition to the tow package.
Thanks for your help.
ed
Fred
Lawson
At any rate, the towability will depend upon the terrain. Your 1500 has plenty of chassis, but the motor is a bit light if you are going to do hills/mountains. The 3.37 is fine. I would go ahead and use it, don't abuse it, and watch the temp gauge. Don't operate at high rpm for long periods, uphill.
I have an '04 1500 4x4 w/3.73, 5.3, and tow package. It pulls my 6500# 5th wheel great, even up most hills. Trans never heats up, and neither does engine.
I have an /04 with the 6.5' "short" bed (not as short as the 5.5'). I have a standard 5th wheel hitch, and my unit has the EPB. I can make lock to lock turns in the tightest circle with no cab contact.
GM has the blank in those spots because they do not want to be liable for some idiot crushing his cab.
Jim
I have to pull my '68 Camaro on a U-haul auto transport that is listed at a weight of 2,000 pounds and the Camaro is somewhere between 3,000 and 3,500 pounds (title says 3,100 but who knows if that is exactly right).
Does anyone know if I should worry about being just a few pouds over the 5,000 since the truck is rated for more?
I have a ham radio I want to install and need power from the battery. Instead of going through the firewall and connecting directly to the battery, I was hoping I could get a pigtail connector, place the power cables from my radio into it, and plug it into the same distribution box.
Does anyone know if this is possible and where I might get information on what each of the connectors are for and what they provide in this distribution box? Do dealers sell the pigtails that connect to this?
The power band of the 5.3 is up in the 3-4K range which doesn't help when towing in OD but I think you know that already.
Consider the 411 probably your best bet and it doesn't make that much of a difference in gas.
If you have 3 low batteries, lights on, a/c on hi, etc that's too much load. Leave lights off, fan off, charge truck batteries 10 min. then plug in trailer after dry camping.
If your truck batteries are at full charge then no problem.. we put the 40 amp in an 05 today.
When you hit a bump there is an amount of wheel spin. The locker will pick that up as slippage and engage. Nothing wrong there either.
what pins did not have power
Hope you got it resolved by now, but just in case, here is a half-cent worth.
On my '98, I added a second battery in parallel (never got around to putting in an isolator) and ran a fused set of wires with Anderson power connectors into the cab to run my FT-8900.
My counsel is to make sure that the transmit power requirement doesn't exceed the circuit capacity and use wire heavy enough to handle the current.
I just got my 07 2500HD Duramax (new style) three weeks ago and haven't figured out how I am going to handle radio stuff yet. I have wondered about using the trailer plug to re-charge a gel-cell (that I will use operating stand-alone during extended field operations) on the return trip. Another local ham has a similar rig so I will be playing 20 (at least) questions when I get an audience with him.
New rig means so many new questions...
73s
N7AKJ
