Jeep Grand Cherokee Tailgate Won't Open
Bought mine used with only a few problems, but the main ones are the tailgate which is stuck closed (you can hear the elec lock engage and disengage when elec door lock and regular door key is used and, the battery completely dies after two or three days of it sitting idle.
Also, I get a constant 'Rear Lamp Failure' messege on the in-cabin computer as well as a very loud noise from the front left tire assembly.
Any ideas? Thanks
Any ideas? Thanks
-Marc
Side note: I read somewhere about removing the nuts underneath that hold on the striker to open the door. That did not work at all, there was not enough room for the studs to come up through the holes. Then I had to readjust it so the door would not rattle.
No biggie - we'll just move the post over here.
Dennis
is there a fuse or some thing?
Normally, when one activates the "unlock" mode with the keyless remote, one hears a clicking sound of the tailgate locking mechanism. Now I only hear the sounds of the front row and second row doors, either locking or unlocking. No sound from the tailgate. The tailgate handle, when pulled, moves in the normal range of motion, but does nothing.
On the inside of the tailgate, there is a plastic button, hole-cover about 1 1/2" in diameter.
Q: Is it an access cover for a door release (override?)?
Q: How does on get the door open without the keyless remote?
Thanks for your help
Keith
2006 JGCL
The lift gate doesn't open all the way
