Jeep Liberty Diesel Oil Questions
Hi to all,
I have a ’06 Jeep Diesel – 20,000 miles and for the most part like the vehicle. The ONE big issue is the engine oil:
• Currently change it every 6200 miles
• Use Mobil 1 (0-40W synthetic)
• Wix filter
• At best ½ quart of oil used between service
My question/concerns:
• As a long term diesel vehicle owner (30 + years) I’m amazed at how dirty (ink black with soot) the oil in the little Mercedes gets – within 5 minutes of running with fresh oil the oil is black. In comparison my Dodge Cummins with 200+K miles – or a John Deere Tractor with 8600 hours produces much cleaner oil – even after 2000 miles on the oil.
Nonetheless, is this:
• Dirty (looking) oil a concern
• What is the preferred oil choice – we live in eastern WA with some extreme temps. 0-100 degree range.
• 90% of the driving is my wife’s 100 mile interstate daily commute
I like & use Rotella (15-40W) in my other vehicles & would like to switch to something else in the Jeep.
Any input will be appreciated, Mike (imthomas@nwi.net)
• Wix filter
I started out using Mobil 1 0w40 oil then switched to Mobil 1 5w40 until it was not readily available. I also use Wix oil and air filters. I developed a ticky lifter using Mobil 1 and switched to Rotella T 5w40 synthetic and the ticky lifter went away and has not returned - maybe nothing to do with the oil - just coincidence. Oil changes are at 6k miles and the level on the dipstick drops maybe 1/16 inch in 6k miles (35k miles on engine).
Black oil is normal on EGR valve engines and none of us worry about it. It's almost a shame to dump new high quality oil in one of these engines considering what it does to the oil. The issue is that the soot in the oil must be low enough concentration to remain in suspension in the oil. If you wanted to run your oil 12k miles or more you might want to have the oil tested to be safe. This is not an issue at 6k miles.
Nescosmo....
Are some of the engine combustion chamber use the oil different when cooling the cylinder than others?
There have been advancements through time to obtain more complete burning and higher efficiency in diesel engines. The EGR valve seems like a step backwards to me.
please clear my dumfound.
I cannot. The only thing I can offer is that Rotella T diesel reads on the container that it contains "Advanced Soot Control" meaning that the maker expects soot in the oil and soot leads to black oil. It would seem to me that in an engine where the rings are sealing very well there would not be much blow-by and not much soot in the oil. Does the CRD have excessive blow-by relative to the Sprinter? Once again, I cannot answer that question relative to the Sprinter.
You do make an interesting point.
I looked on the Sprinter forum and there is some talk about black oil - but not much. My recollection when reading about the Sprinter is that it has a smaller turbo that spins up faster to reduce turbo lag, so the Sprinter may not run as high a boost as the CRD producing less blow-by. The engine might be made a little better with better control on the systems. I work in a downtown area where I see Sprinters almost on a daily basis and I have never seen so much as a wisp of smoke exit the exhaust on one. Some of them are being run pretty hard, too.
In the EU, this denomination relates to engines that use the particulate filter on the exhaust system. This is also a prolonged duty lubricant, usually good for 20,000 miles or more.
I checked the specs of the Sprinter (in Luxembourg), and it's supposed to run 30,000 miles between oil changes when used intensively in a fleet. In such a case the engine has very little time to cool down and humidity doesn't have a chance to get into the block.
Sorry, Nescosmo I have no opinion on which dealer.
No blow-by hoses are clean as the first day i bought it
Do you have a different crankcase ventilation system on you sprinter than the CRD? Those crankcase fumes have to be going somewhere.:confuse: Maybe there is something different with the CCV design?
I checked the CAC hoses on the CRD today and they are starting to dry up at 35k miles. At 6k miles the hoses were all snotted up. Now there is a very thin almost dry layer of oil and the oil seeping at the clamped connection on the input side is almost clear, not black.
The oil on the dipstick is better too. When I rub it between my fingers it feels slicker and wipes off my fingers with a rag. At 6k miles I had to uses a cleaner to get the oil off my fingers.
Can i use those metal tubing that they use on the bathroom exhaust fans or just buy the hoses at the dealer.
Based on what I read here as well as Shell/Rottella's suggestions I did switch to the Rottella 5w30 and the oil seems cleaner - but we only have 3000 miles on this service.
A new question: Are there any suggestions on miles between servicing with the new oil - given the same driving conditions?
Thanks Mike
I use Rotella T 5W40 and I am happy with the price and availability. My oil gets black as coal after a few hundred miles from change.
Putting superior Amsoil in the CRD engine is like watching two beautiful women mud wrestle. When looking at the long list of non-oil problems with the CRD, I don't think it deserves oil that good.
The 'long list' of symptoms points towards two causes:
- Synchronization of the Emission control system
- Higher torque for slower driving habits
Do you prefer to change your oil more often while others watch mud wrestling? Now I get a better understanding of where our reputation comes from
Nescosmo.
Nescosmo...
You have to consider 2 microns for the fuel filter rating. The moving components of the injectors and pump are machined with a very tight tolerance. If larger solid particles reach the high pressure side of the pump, you may face expensive issues.
link title
http://www.rockauto.com/dbphp/mfr,WIX,Fuel%252FAir,6200,Fuel+Filter
Then "Part Number Search" tab
Part Number: 33647
Principal Application: Jeep Liberty w/ 2.8L Common Rail Diesel (05-06) All Applications
Style: Spin-On Fuel/Water Separator Filter
Service: Fuel
Type: Full Flow
Media: Paper
Height: 7.322
Outer Diameter Top: 3.444
Outer Diameter Bottom: Closed
Thread Size: 16X1.5 MM
Gasket Diameters:
O.D. 2.770
I.D. 2.440
Thk. 0.240
Personally speaking I would not use this cartridge because two main functions will be removed:
- The water in fuel sensing
- The pre-heating of the fuel for winter use.
Don't you have a Parker Racor equivalent? Mine is the R20S. It's the clone of the Mopar filter, and Parker once wrote they were doing good business with Chrysler Marine Diesel :shades:
P0178:
-Water in Fuel Light—Water In Fuel Sensor Voltage Too Low
Cause:
- Loss of water-in-fuel circuit or sensor.
Nescosmo
Nescosmo...
Nescosmo
- The preheating of the fuel for winter use.
The water in fuel sensor came with the CRD originally and screws into the bottom of the replacement filter in lieu of the drain plug that comes with the replacement, so the sensor is not lost. The sensor is just 2 electrodes in the plastic that measure the conductivity of the water if high enough.
The preheating element is not in the filter itself. The original filter I disassembled was simply a canister with a filter element. The canister extends well below the filter to provide room for water. Is the heater in the housing that holds the filter?
I would prefer to use a Racor with a clear bowl. I contacted Racor about a year ago and they said that they thought the R20S(if memory serves) would work but could not say absolutely so I did not order one.
-Both heater and water sensors are located inside the plastic bowl.
-The R20S filter cartridge has a 'chamber' for allowing a volume of fuel to remain around the heating element.
European 4x4 clubs promote Parker-Racor filters when preparing for African rallies. When you're not certain of what will be poured into your tank, you add another filtration element to the one I received with the truck. My fuel filter element has 20,000 miles and doesn't show any sign of fatigue.
The plastic bowl is really neat to detect the presence of water: I apply a flashlight underneath the bowl, next to the connectors. :shades:
When illuminated, the colour of the plastic bowl full of fuel is like tea (or american coffee )
Some time ago I posted these pictures:
http://richard.fortin.free.fr/KJ_diesel/Corps_filtre.jpg
http://richard.fortin.free.fr/KJ_diesel/Purge.jpg
You will see the two connectors on the bowl.
The fuel heater is a 3/4 turn ring element that is fixed inside the bowl.
The filter cartridge has an empty volume (recess) built in just above the heater element.
The Parker filter housing is accessible and repairable. Yours is quicker to prime, every 40,000 miles
When you buy the marine version, the mount/housing is painted beige. DC saved a penny by not painting it.
http://img215.imageshack.us/my.php?image=1000330cp2.jpg
Please take a look at the catalogue below specifically page 9.
http://www.usdieselparts.com/pdf/pdf/Section01.pdf
Is that your unit, model 230R, using R20S 2 micron cartridge and “Heater and See-thru Bowl”? Racor tells me that they think the R20S will fit on the US CRD filter head. If that is the case I can get by just buying the R20S cartridge and a non-heater see-thru bowl and install my existing water sensor. I am going to order the parts and find out.
If you retrofit this on your truck, spend the extra dollar on the purchase of two stainless steel elbow fittings ("Swagelock" or equivalent) for the fuel hoses.
You were lucky not to set fire with the fried connector :sick:
George
George
I have had great success with my 2001 Freightliner FL70 3126 Cat.
The secret to success with Biodiesel is slow intergration and filter changing.
5%, 10%, 20%, 99%
This process took me 3 months to do.
Is there anything I should know with the Jeeps operation on B99?
Can I get the name of the dealership and service manager you brought it to.
I want to know what went wrong and why.
I'm going to run B99 and want to know if I can override these problems.
Joel
Let me tell you what happened with the BioDiesel in my 2005 Liberty.
I went to the store and out of the blue lost 90% of the engines power.
However, when I put it in neutral I got 3-4000 rpm.
This is a sign that the BioDiesel is cleaning out the system.
At this point my buddy who has been a diesel mechanic for 30 years said to shut it down before the glow plugs melt.
I changed the filter. It ran fine again.
Remember....carry an extra filter and one pint of BioDiesel (in a non-plastic container) in the Jeep.
If anyone has questions, please feel free to contact me.
After a Cat3126 in my FL70 and the Jeep CRD I think I get it by now.
Some oil additives seem to migrate through the hose material. There is nothing to worry about besides getting your hands dirty.
Let us face it, the issue is not so much the engine as in the care or lack there of, not following the reasonable guidelines set out by Chrysler, the use of inappropriate lubricants, and on some occasions poor dealer/service quality.
Let us face it, America is really not ready for good quality European diesels. Americans are not willing to invest the few extra minutes it takes to keep these engines running properly. Let us also consider that most American diesel fuel is swill and it is a wonder that these engines run as well as they do. I add goodly amounts of cetane improver and other additives to each tank of fuel resulting in less smoke, easier starting and better overall performance.
I have spoken to several MB diesel mechanics who have told me that when the MB diesels arrive from Europe they run beautifully but after a few tankfuls of American diesel, they do not run as well. Whatever component failure they do see, especially turbos is usually a result of poor care by the owner. That makes me wonder. At my dealer, the tech is really very good. They have several other customers with CRDs who do not care for them as they should be cared. I have, with the dealer having asked me to do so, spoken with at least one of these people in an effort to help them. I have pointed people to this and other forums and had them look especially at the advice given by Caribou1.
I know we are all busy, but investing a little time into caring for this very good engine has big dividends.
