2008 Subaru Legacy
For the record, VW does not have terrible reliability. #1 Lexus has 1.36 problems per vehicle and VW has 2.9 problems per vehicle in JD Power long term dependability. Subaru 2.3 problems per vehicle.
Then again, VW phased out the 1.8T, so the ignition coil failures will eventually disappear from those studies as well.
Everyone likes to spin JD Powers, Consumer Reports, Edmunds and others. Consumer Reports for example... will rate some new vehicles based on their replacement model w/ some brands and not with others. Consumer Reports doesnt send me a surveys for my new vehicle purchases - JD Powers does. I chose to rely on information that I've actually experienced and know first hand that they ask consumers for data.
Did not fill them out, though. Too time consuming, and noone's paying me!
CR does have the biggest sample size, IIRC.
TireRack says no due to brake clearance; Discount Tire Direct says yes. The '08 Legacy has an 11.5" vented front disc and a 10.6" solid rear disc. By comparison, the 2004 Legacy L (the last year that came with 15" wheels as standard) had a 10.7" vented front disc and an 11.3" rear disc.
Anyone have an idea? My thanks in advance.
-mike
Maybe 15" gold Impreza RS wheels.
Ask the dealer if you can test-mount one wheel on the front axle. Tell them it's a pre-requisite for a sale.
The Imprezas were 16x7!
There are aftermarket 15" rally wheels that run about $300-400 a pop that will clear the 4-pot FHI calipers, but even then I'm not sure they'd clear the legacy brakes.
-mike
But I do not know if the turbo engine tolerates 89 or 87 octane fuel (Subaru recommends 91). I also don't know, in general, how Subaru turbos hold up (one work associate of mine went to great lengths to put additional oil pumps on his, along with long idle up and idle down times).
I also don't know how seat comfort holds up over long trips. Any comments from folks around 170 lbs who have had long stints in this car would be welcome.
I've got almost 30K on on my '06 WRX 2.5 turbo without any problems.
Bob
The lower output tune in the Forester runs less boost and in that case premium fuel is not actually required.
It is required on the Legacy, though.
Maybe an H6 for you? You can use regular fuel with those.
So I've grown accustomed to doing that all the time.
Also someone in an earlier post mentioned the need for 3,750 mile oil changes now required for the 08 GT's. This is the first I have heard about this. Does the turbo put that much stress on the engine?
Someone also mentioned using a cat back exhaust and cold air intake. Are these reasonable modifications to wake up the car a little more. Are there other mods to consider? Do they work to really increase performance? What about warranty?
-mike
But an extended warranty for rust proofing?
The rust proofing just isn't necessary. They use galvanized steel nowadays, so unless there is damage they will outlast the warranty anyway.
I've decided on getting an extended warranty, and am leaning towards the 6 yr. It's about $500 more than the 5-year, but $1100 less than the 7-year. Any thoughts? :confuse:
Don't think i'll be getting the Tire and Rim Protection unless someone can convince me otherwise. It's $399, only good for 5 years and has a $5000 limit. Is this worth the extra money? :confuse:
Finally, also debating getting the rust protection. I come from Newfoundland, where winter's can be harsh on cars, but it's another $500, and though its guaranteed for the life of the vehicle, it only covers rusting which began on the INSIDE of the vehicle. I Would've thought that rusting generally starts on the outside? :confuse:
Any suggestions would really help me out!
-mike
-mike
And don't sweat it if you go over 4000 rpm for an instant or two, just don't drive for miles and miles at that high an rpm during break-in.
My manual transmission turns 3000 rpm at 70mph in fifth gear so that 4000 rpm limit shouldn't cause problems in everyday driving. (I think an automatic turns an even lower rpm at 70.)
Another typical recommendation is not to drive for several hours at one set rpm. (So don't take a two hour drive with cruise control.) Vary the rpms a bit.
Jim
Also, the price of Subaru's extended warranty is negotiable, so if your local dealer is not willing to come down on the price of the package, you can always look for a dealer who will. The warranty comes from the factory, not from the dealer. It is not imperative that you buy it there. Additionally, you can purchase it at any time prior to the expiration of the 3-year, 36,000 mile base warranty.
had a few problems with it well one major,the rear defrost shorts out the radio,
dealer said it was the tint, ripped it off, no go... swapped radios no go.. replaced rear window no go.. gouged the paint no go.. put a dent in it no go.. ripped the front seat no go.... i hate bennington subaru!!!!!!!!!! well my car is in the shop again being painted.. i hope it comes out black like it went in... but i doubt it. but it goes like a raped ape!!!! I should of went to kinney subaru!!!!!!
-mike
Motorsports and Modifications Host
http://cars.uk.msn.com/Reviews/article.aspx?cp-documentid=7283675
Let's hope this finds its way to North America very soon!
whats messed up is subaru only "factory tints" tribeca's. the rest is a stick on port tint.
i think if i want to be able to have a " Stained' factory tint i should be able too. at leaast most other car companies offer that, :lemon:
-mike
Where does this hose exit the vehicle, and where is the drain in the sunroof? I can see nothing that resembles a drain.
Great car--also have an 07 Forester.
Dave............
One more thing: is synthetic oil recommended on the first oil change?
-mike
Does the system protect the hatch and hood, in addition to the doors?
Does the system "chirp" when arming and disarming?
When disarming, does the system exhibit a different sequence of chirps or light flash if the alarm had been triggered in your absence? ie. instead of chirping twice, it may chirp 5 times, etc.
In some earlier Subie models, if the alarm had been triggered, you can identify what had been opened or tampered with by way of a sequence of flashes of an indicated light on the dash. Same for 2008 Legacy and Outback?
Can the system be programmed for passive arming?
Thanks in advance.
As for if it lets you know, you may want to try leaving a door window open and locking the car. Then open the door from the inside and let the alarm go off. Then see what it tells you.
As long as you lock the doors it's passive, it works based off the locking mechanism.
You can have it chirp or not chirp, your choice.
-mike
Ok...I know what you mean. But what I meant was could it be programmed to arm and lock by itself after all the doors are closed. IIRC, some earlier Subies had Alpine-made security systems that could do that.
