Nissan Maxima Fuel and Fuel System Questions
Hi! I just bought my first maxima today. It's a 95 GXE automatic. unfortunately it didn't come with the owner's manual, I'll have to buy one online I guess. I just read something that said some models need premium grade gasoline, does anyone know if this is true for the one I drive? thanks!
i wanted to know if it was ok to put regular gasoline (not premium) in my 2007 nissan maxima. i consulted the owner's manual and on page 9-3, they say that they recommend 91 AKI, which is equivalent to 96 octane. i have never seen octane higher than 93....so i dont know what they expect there.
the manual goes on to say that i can use "regular"....but their definition of regular is 87 AKI, which is octane 91 according to the manual.
every gas station i go to has "regular" defined as 87 octane....and you dont see any thing about AKI. furthermore.....i never see "91 octane" anyway...its all 87, 89, and 93.
What Gives!! can i use regular or not?? and where the %&*% do they expect me to find 96 octane??
i assume the drop in performance that the manual speaks about would be unnoticeable to teh average driver, am i correct?
Any guidance would help...thanks very much
Terry
so when you say "regular"...you are talking about "87 octane"....not this "87 aki...91 octane" stuff that they talk abotu in the manual...right?
Thanks in advance to those who may be able to help me with this.
I went to the local Midas and they thought that if the "check engine" light was on that would lead them to figuring out the problem. No such luck, the light is not on.
The mechanic thinks it may be a problem with the Throttle Position Sensor or some other acronyms; basically he thought there was some sort of intermittent communication error between the engine and the computer that is causing this. He didn't think it was the fuel injectors or the fuel pump.
If anyone has idea what might be causing this, I would appreciate it. Thanks.
Step 2. Take it to your local Nissan dealer and have them diagnose the problem.
Is it possible to find car manuals for a certain model year online?
I am possibly looking to buy a used 1998 Maxima SE or 1995 Maxima.
Well...then now yesterday, the engine was idling a little rough when I first started (I guess I didn't give it enough time to warm up) and now the "Service Engine Soon" lamp glows so now I have to get it checked out (again) with the OBD tool.
Thinking about going back to the dealer...will see. The car runs fine and doesn't cause any stalling/rough idling. Maybe it was a one time thing...but at some point I'll have find out what the code is for and clear it and hopefully it won't return.
