Toyota Highlander Hesitation
I have a 2005 Highlander. Ever since I bought it (used) I noticed that when I slow down and do not completely stop, then accelerate, that it hesitates, then it jerks upon acceleration. Is this something normal for a Highlander or should I have it checked out?
Pat
Pat
A year ago, the Toyota dealer reprogramed the chip as per the Totota billetin which about cured the problem, but the problem still exists only not as pronounced. The dealer (McDonough, Staunton Va.) is not aware of any new bulletins, and cannot fix the the problem. While this hesitation is not annoying enough to sell the car, it is of suffucient annoyance to me that I would not purchase another.
What has happened is that the transaxle shift pattern/sequence/schedule has been changed/revised, beginning late in the last century, such that upon any full lift-throttle event the transaxle will automatically upshift in order to reduce the level of engine compression braking. Engine compression braking which, should the roadbed happen to be slippery enough, will oftentimes result in loss of directional control of the vehicle, or maybe even worse, interfere with the proper operation of your ABS, anti-lock braking system.
So far, all to the good, yes..?
But.
What if, just by pure happenstance you re-apply a fairly serious level foot pressure to the gas pedal almost immediately after the full lift-throttle "event".
The engine RPM has dropped to idle, the transaxle is busily upshifting and now a quick sequential downshift is required and there is no "reserve" ATF pressure source to provide the "means" to quickly provide the downshift.
So, DBW, e-throttle, is used to delay the response of the engine for 1-2 seconds to your new "request" until enough ATF pressure flow is available to accomplish the required downshift.
1001, 1002...GO...!
Appreciate your input, wwest.
Carl
The 2000 and 2001 Lexus RX300 shop/repair manuals describe a shift pattern wherein upon a full lift throttle event the transaxle is upshifted. A 30 day "pass" to techinfo.toyota.com will get you access to ALL Lexus/Toyota repair/shop manuals and you can verify the above to be across the board for FWD and front "based" AWD vehicles.
Until Toyota redesigns the transaxle to allow a variable displacement ATF pump (as Ford seemingly has done with the new FWD Edge) to be implemented it is likely ALL FWD and front torque biased AWD vehicles will be subject to the downshift delay in the circumstances the TSB describes.
In the alternative they might license the Ford patent and only upshift the transaxle if the OAT is near or below freezing or if VSC/Trac or ABS has recently activated. Or only license a portion of the patent and then maybe even only upshift if the brakes are applied shortly after a full lift-throttle event.
Otherwise, yes, just one person's opinion.
They also said that this is common in most of Toyota.
R
Can you imagine, then, the level of ATF that was pumped needlessly, ported right back into the sump, while cruising for hour upon hour in OD at ~2200-2700 RPM..??
Waste, HEAT...!!
So lots of "gain" was to be had should one be able to reduce the displacement of that gear type ATF oil pump.
As so it was DONE...!
So...
Downshift into 1st below 10-0 MPH with the engine at idle BEFORE coming to a complete and full stop...
NOT.
Feeling, 10-0 MPH, as if being "bumped" lightly from behind...??
WEll..yes.
Most stick shift drivers might downshift 10-0 MPH but disenage the clutch....
So the new shift technique/pattern/schedule adopted along with the downsizing of the ATF pump "back when" involved NEVER downshifting in circumstances wherein due to lack of pump volume the clutches could not be quickly and firmly seated.
But things went awry...
The drivers did not exactly cooperate.
So the '99 RX300 transaxles started failing prematurely since the drivers could not know, nor even so quickly change, adapt to, the new upshift technique.
Toyota's answer....
"Depress the gas pedal S..l...o...w....l...y for quick (QUICK???) acceleration.
In other words give the engine time to rev up slightly thereby raising the ATF pumping volume before reaching the pedal position wherein the ECU "realizes" a downshift is required.
Sure.
The drivers continued to think that when they pushed the gas pedal to the floor the transaxle should instantly downshift and GO...!!
Well, at least the engine (no DBW, yet!) responded quickly with HIGH revs..and then evenually the transaxle downshifted and once the downshifted clutches stopped SLIPPING due to the already high engine RPM...
I have had too many vehicles in recent years and honestly, there is no perfect car, no better dealer and everything is a trade off. I personally like the issues with my Toyota's better than the issues and hardships I had dealing with Honda.
Unless this becomes a major safety concern, which subjectively, it isn't, I wouldn't bother fighting the battle. Keep the relationship with your dealer for anything significant that may occur.
Pat
toyseeker, "2008 Toyota Highlander" #1708, 10 Oct 2007 12:26 pm
Hope that helps,
Mike
And as we divert more corn to bad fuel, corn, corn sweeteners, corn meal, tortillas, and anything that uses or eats corn, like cattle, therefore milk, meat, etc...costs more.
ain't ethanol great? Reformulated? some of use don't have a choice.
Let me know if it work for your vehicle.
Mike
