Tahoe oil gauge reading
When I start out driving I notice the needle of the oil gauge at 40 (in the middle of the gauge), but when I get on the high way or give it some gas the needle moves between 40 and 80, probably like 60 or something.
I was wondering if this is normal or not?
Dealer would not do anything even though it appears they created the problem
Any ideals on how to fix this?
I took it back to the dealer for a recheck. They performed a test with a mechanical gauge and measured 30 psi at 1000 RPM, 40 psi at 2000 RPM, and 50 psi at 4000 RPM. My actual oil pressure is fine. The dealer states that the gauge in the dash is operating within specifications, but they don't say what specs those are specifically. The gauge is reading around 25 psi higher than it should and I can't believe that's right.
But the service advisor told me that they pulled another truck off the line to check its system and it behaved the same way. And a guy at work with a Silverado told me he's never seen his gauge below 40 psi.
I'm slogging through my '01 service manual trying to find the acceptable tolerance on that dash gauge now. I think the dealer may have failed to duplicate the issue with the gauge, although I think something else is going on here.
