GMC Jimmy Vibrations
Hi i have a 2000 jimmy 2 door. I has just over 105K on it and im getting these really anyoing vibrations when im driving and it starting to bug me? And its hesitating and slugish? any thoughts on what i can get done? Thanks for your help
Also my wipers work when they want and not when its raining of course...
It's good on extremely bumpy dirt roads at any speed, and good at highway speeds. But when I hit small bumps at 5-55 mph on paved "rural" roads (such as a little mound of ashphalt left over from a road repair) I get a horrific vibration throught the vehicle. (It seems less horrific if I am going 60 mph or faster) The vibration isn't really in the steering wheel so I don't think it's the idler arm or pitman arm or anything like that. Plus those things check out ok and have been recently replaced.
I also know for sure it's not the shocks as they have been replaced twice. The ball joints have also been replaced. The drive shaft is fine and the u-joints have been changed. I have even checked the body mounts, motor mounts, and transmission mounts and they are fine. I have also checked the rear axle bearings. All of those things check out ok...but the vibration/shake is still there.
Anyone have any suggestions?? The vehicle runs great and I would love to get another 250,000 miles out of it. But this vibration is conerning me. I hate driving a vehicle when there is an unknown problem.
I have same problem, my is at 220,000, shakes really bad...esp around 90-100k..mine increases the shaking with speed.
I will post an update ASAP.
Hopefully to say the vibratrion is gone!
The shop told me that it was uneven wear of the front right tire (left was replaced recently and is nearly new), but I failed to tell them about the vibration disappearing when taking my foot off the gas.
Anyone have a clue? I'm thinkin U-joints to start.
I was thinking the hub too, but I replaced the passenger side hub about a year ago and there was a distinct shimmy in the steering wheel that went along w/ the bad hub, so I ruled that out (for now).
thanks for the help
anything else just hit me up
