... EGR, Diesel and Gas
... We have been suffering this bandaid for about 35 years. Anyone know of it's use before the early Seventies? If we had been measuring the total amount of exhaust gas, especially green house gas, I doubt it would have ever been put in one vehicle.
... For those that don't know it's not a system to take exhaust gas and reintroduce it to the combustion chamber to extract more energy with a more complete combustion. Fifteen percent exhaust gas is the max I know about, is recirculated to contaminate the combustion process and make the reaction (burn) a lower temperature, that creates less NOx.
... What really cleaned (considering the era), the engines, was the implementation of sequential, individual runner, injection. This is all the more vexing because, Cadillac, Cosworth Vega, VW and more had good injection (although maybe not sequential) back then, enabling engines to be tuned as they should (all cylinders close to equal). The thought of a large, American, low compression, EGR'd, timing retarded, remotely (from the end cylinders) carbureted, V~8, tuned to the WORST cylinder is DISGUSTING.
... Of course the Diesel always had the problem handled, IE it's comparatively easy to get an even amount of air to all cylinders, but fuel wants to fall out of aeration and puddle in various areas of the manifold. The diesel puts a precise amount of fuel in each cylinder and the modern manifolds (gas and Diesel) are doing a better job of balancing the airflow.
... So somebody(s) dreams up recirculating 15 percent of the exhaust gas. There was probably none or almost no consideration of the Diesel industry. A gas engine does not produce soot and this is probably the worst of Diesel related problems with EGR. The soot that has left the combustion chamber is (partially) brought back into the chamber and contaminates the process and wears upper cylinder components.
Dave
kcram - Pickups Host
Do you think I will have any side effects from running the gas that was in the tank?
