Nissan Altima Engine Rattle
Took the 2007 Altima 2.5 in for service today with 1,500 miles. Engine has loud rattle when starting cold, and louder when shifting into drive or reverse as the idle kicks down a few hundred rpm. I sense that the engine oil has settled over a period of time not running. Further, I believe the internal engine parts do not get the oil lubercation until fully warmed up. Then the loud rattle goes away. More noticeable as we get into the cooler/colder Fall days.
Nissan dealer is calling the "hot line" to see what the problem and/or fix might be.
Has anyone experienced this loud rattling noise during engine warmup?
If I am told this is normal, that will definitely not be acceptable.
Hindsight, I would reconsider buying the 2.5. Otherwise it is a great car.
I will post what comes back from the "hot line" call that the dealer makes. (..traveling rest of week, will reply on weekend. Tks.)
Please let me know what your results are with Corporate. Likewise, if the local dealer does not resolve my problem, I will also elevate to Nissan Corporation.
i also have two other problems with new altima (bought it on 9/29) one is that I can hear the WIND NOISE when i speed up to 60 mph... which is quite annoying. Also sometimes when I release the gas paddle and step on the break....the car would "suddently drive foward like a downshifting mechanism". The last problem also happens in the morning, too, which is when I turn the steering wheel...i can hear a grinding noise near the fender....
any thoughts?
This is normal for most cars now. Actually, I prefer the way it behaves.
And I also have that wind whistle through the driver side window. It is a bit annoying, but overall, I really love my new car.
You might consider asking the dealer remove the shields until a permanent solution/fix can be made. Using washers to tighten the bolts doesn't sound like something that will be long lasting...
Our 2.5 Altima is great, and the gas mileage is starting to improve with city driving. With 2k miles, getting 23 mpg city compared to EPA 26.
Presently there is no rattle on our car due to the heat shields being completely removed. Again, waiting for dealer to get in new heat shields and/or perform a fix.
Concerning gas mileage; I asked the service department to scope the engine or put it on the computer. The service writer suggested that we get 2k to 3K for a good break in first. Time will tell as they say.....
Otherwise if the rattle returns I will pursue with Nissan the idea of removing the heat shields completely. We had gone without them three weeks while waiting on parts to arrive.
I've noticed this on my 3.5 SE--on cold start-up, the software rips the engine instantly up to just over 2,000 RPM, which is when I hear the noise. This is ridiculous to race a cold engine this fast. Here's what I do: I push the start button without my foot on the brake, then place the selector in "N". Then, with my left hand on the start button and right hand on the gear shift, I push the button and instantly put the gear shift into "D", which prevents the engine revving above just over 1,200 RPM. Then, after a couple of more second, I put it in "P" and the revs rise up to around 1,750, then settle back. I don't know how this could hurt the transmssion, but at least it keeps the cold engine from trying to destory itself.
Perhaps it would be useful if these Nissan service departments communicated with each other and try to solve the problem based on experiences. I am satisfied that our Nissan service department (Nissan of Omaha) is doing all it can. Hopefully our issue is squared away.
Don't you mean CVT? If not, what is the VTC gear?
The MIL is on with any of the following DTCs stored:
P0011, P0014, P0021, P0024, P1110, P1135,
NOTE: The engine may also have Camshaft Sprocket rattle noise and/or other engine noise THIS IS A VTC GEAR
NOTE: The engine may also have Camshaft Sprocket rattle noise and/or other engine noise I started with the heatsheid it has been replaced three times im not saying everyone has my problem. but after three heat sheilds this is what they say mine is..i have filed! they say they have no fix at this time now they want to give me what my car is worth now its not my fault they have a defect and cant fix it what if i said i didnt have my payment what would they dooooo. i bought my car in jackson tn.they do not want to work with you to settle the problem. and if they do i loose several thousand dollars.for something that is there fault not mine.
Questions or concerns are to be directed to a Nissan rep at 1.800.647.7261.
With new heat shields installed on our 2.5 a few weeks ago, the rattle has not returned. Hopefully that was the solution.
Sure the car will run with the noise, but who in their right mind would accept it? How is everyone else doing with their rattle and/or fix by their dealership?
It has been approximately two months since Nissan issued the letter to Altima 2.5 owners suggesting that there would have the problem determined and a solution. I am not going to wait for the mailman or my phone to ring. Friday 1 Feb I have an appointment to take care of the Smart (?) Key issue by having them replaced. I will take up the rattle issue once more...
Good luck! All of us 2.5 owners need it.....
im in my third rental car since i bought my altima! very fed up!!!!!!!!!!!!
I did not know about the rattle recall until the service writer told me they could take care of it today while doing the smart key replacement. Further, I was told that the dealers had been waiting for Nissan to send them the "special tool" that would take care of the problem. Special tool?
Our rattle was into week two after getting the heat shields tightened (for the second time..) eight weeks ago. It was getting unusually louder by this morning.
So, the purpose of my posting tonight is to relay what has happened and make sure everyone is aware of this recall that was waiting on the "special tool." My goal is to exceed six weeks without the rattle returning......
We have had no other issues with the Altima 2.5 and believe it to be a good car otherwise. Again, good luck to all.
I have got back car from this 2nd dealer that I went to and my rattle is completely gone.
this is what they did.
Plate heat shld
Cover exhaust M
Manifold Assy E
Gasket Exhaust
Gasket Exhaust
Stud
Also, they told me they fixed cadilac something. I don't recall what it was exactly but they fixed that also. (I will get more info and post new comment later)
About petition.. I think all of us should ask for longer warranty or some kind of benefit out of their mistakes. I think most of us went to nissan more than 10 times (for myself 12). anybody up for this?
why did you get your keys replaced? and
Do you haer a thunking noise sometimes when you drive?
I hope the "special tool" helps you and if you do let us know please!!!
The smart keys were replaced as part of a recall. Cell phones may wipe out the transmitting code if too close to the smart keys. Check with your dealer about the recall. I am surprised they didn't mention it to you during your last visit.
Good luck!
i am going to email channel 4 eye team and see if they will do a story on these 07 engine problems and nissan not doing anything to fix our cars! after four heat sheilds you would think they would realize thats not the problem! i think the lifters are not priming up until the oil gets warm! i live in a very small town and i know three people here with the same problem! i will email channel 2 to. if anyone would like to email them to maybe the more people who emails them about this problem we might get them to do a story! nissan might hear us then!!!! i go before the arbertration board at the end of this month wish me good luck!!!!! :sick:
I changed the oil in our 2.5S this weekend, and wasn't sure which heat shield it might be.
Ours doesn't make any noise, but I want to know:
a) is it the shield surrounding the exhaust manifold & first catalytic converter? :confuse:
OR
b) is it the heat shield surrounding the exhaust pipe underneath the body? :confuse:
ALL I KNOW IS THE SERVICE TECH. TOLD ME THAT THEY WERE HAVING TROUBLE WITH THE NEW NISSAN ROGUE!!! SAME ENGINE NOISE!!!! IF ENOUGH PEOPLE COMPLAINS I SEE ANOTHER RECALL!!!!!!!!!!! :sick: :sick: :sick: :sick: :sick:
Hope this helps!
I also hear a puttering sound when the car is idling, no matter what the temperature is. The noise is very similar to that of a diesel engine. Is anyone having this trouble?
