Buick LeSabre Heating / Cooling
sturigs_larry
Member Posts: 3
in Buick
My 93 Buick LaSabre thinks the external temperature is 185 degrees. I am just guessing but I think that is the reason I don't get any heat unless I crank the climate control to the highest setting. The ext. temp numbers went up gradually over a one year period.
There was another post that made me think this might be a grounding problem. Has anyone seen this behavior? Does grounding sound like a possibility? Where would I start to look?
Thanks, Larry
Thanks, Larry
I have a 98 service manual but I'll look in the 98 service manual for resistance for that sensor. You might pick up a sensor from a junkyard if that's the problem. I'm betting on the connection.
Since you don't complain that the auto control unit isn't doing other things properly I'd suspect the ground is okay for the power to the unit. I believe it grounds through a buss that's next to the driver's seat right at he bottom of the A pillar. it's under the plastic cover rolled over the door frame. I had problems there and the power doors locks wouldn't work and the AC went into a default with the compressor turned on and in defrost for a manual AC unit.
The rest of the climate control stuff seems to work (switches to defrost, panel, etc) except that A/C doesn't blow cold air. I don't know if the system is out of refrigerant or if the compressor never kicks on. Since I live in Michigan I decided I can live without A/C. Unfortunately now the heat doesn't work right!
I assume both hoses to your heater core are hot meaning it's not clogged up.
John
Thanks, Alan
I'll bet if you take off the hush panel above the passenger's toes and take off the glovebox and watch the two levers move while you change the controls, you will find the lower one that changes the temperature for both works and moves.
If you watch the smaller white, upper arm when you adjust the passenger side, you'll see no movement or erratic movement. You might try moving it to see if the door inside of the heater box is sticking. But most likely the little electric motor in the actuator that moves the white arm is broken or disconnected...
And alternative is to use a pressure meter on a charging kit to see how much pressure is on the low side.
Search for words lincoln town in the "Search Forums" box on the right side of this page1.
Here is the group for Lincoln Town Car Maintenance and Repair
link title
What does it do on cooler days when there's no AC on. On some an electric actuator motor that moves the temperature vane can slip. It may cause a clicking sound at first.
Is yours the dual AC with a passenger control also?
On normal days when its cooler outside the temp light still blinks like on hot days even when the air is not on...
If you watch these while changing temps on the main dial and passenger dial, you'll see them both move.
I'll bet at startup of the car after sitting, you'll see one of them not move properly all the way that the programmer box is trying to move it. The top one has a little black box with a motor and plastic gears in it and the gears crack allowing the control to slip. The lower one has an actuator motor like the top but it's inside the programmer box itself.
I have a 98 Lesabre "Limited" model with the auto climate control system.
Last summer I noticed the MID position would not send air.
I made it through the Winter as I don't use the MId for heat, anyway, but I really need the Mid position to cool off with A/C.
The Floor only, Floor and Windshield work ok. The Floor & Mid only send out through the Floor. The Mid seems blocked or stuck?? I've seen the 4 colored vacuum lines - Green, Orange, Blue & White and the actuators "seem" to be working. In the Mid position, the air does flow through the door channels but nothing come out through the front vents.
I've removed the lower panels from the driver and passenger side to have a "look-see" - but I don't want to start disconnecting and opening-up more than I need to.
Your help would be MOST appreciated.
Chuck Leavitt - cjleavitt@verizon.net
I actually took another color tube off over there and applied it to the AC vanes instead of the blue to be sure they moved.
I believe the blue line is the right one. I can't check right now. It goes to a vane which has an axis of rotation parallel to the dashboard an horizontal. It blocks the movement of air going upward to the defrosters and forces it out.
See more Car Pictures at CarSpace.com
The cover for the programmer box unsnaps on one side and can be removed without removing the programmer. The plastic connector slips out of the corner of the box. You CAN cut one one inside and outside and just connect it (both blue in this case) and apply vacuum directly without going through the connector where the black nipples inside closeup with age and heat. Connect using a piece of aquarium tubing or gas line (1/8 inch internal diameter worked for me free from NAPA junk box since I needed only 5 inches... I used about 1 inch long piece.).
I suggest searching further on the net. Also spend some quality time with the hush panels off under the dash and watch the actuators move when you operate the AC control unit to determine which one and where does what... At least you can do this with the key ON and don't have to have the motor running like the 92-99 system which used engine vacuum to operate motors to move vanes and had two actuators for the blend doors (driver and passenger).
Second is that there is an actuator that affects the blend door from what posters have said. It is the one on the driver's side. You may have to take off the hush panels under the dash to see. You should be able to move things by adjusting the settings while the key is in the ON position.
FYI this has seperate warm or colder control on the passenger side located on door panel. Freon level is normal.
The air conditioner blower rarely comes on when the car is started but after several minutes, sometimes nearly an hour it will began to work.
On other times when it is not working I can make a sharp turn either clockwise or counter clockwise and the blower will begin to work.
When the blower is not working and I drive over a rough stretch of road it will begin to work.
When the blower is working and I stop the car, the blower will slow down almost to the point of stopping.
When driving and the blower is working, it surges, i.e. varies rpm for no apparent reason.
Once the blower begins to work, it will continue to work until I turn the car off.
Any ideas on how I can get the air conditioner repaired?
I recall someone who had an erratic blower motor on the same type car after 2000+
and he tookthe motor apart and found a contact was not quite long enough inside the motor. He rebuilt the contact and it worked happily ever after. He felt the motor itself was poorly engineered and that led to the contact wearing too much too early.
He hiimself is an engineer.
That story is why I asked if you had replaced the blower motor. It's inside the car and removed from under the passenger side of the dash. If I recall it has 5 or so screws holding it in place and comes out with a tight fit but is doable.
I'm disappointed that the Buick technicians have not been able to repair the problem.
Is there some place I can check to see if other owners have the same problem?
That would indicate there's a vacuum problem. When there's no vacuum the default is defrost for safety to be able to clear the windshield.
You can check the vacuum line (black plastic, 1/4 in) that goes to the vacuum tank in front of the right front wheel behind the headlights. You have to be on the gound looking up to find it. With the motor on or just turned off pulling off the connector should give a whoosh as air rushes in. It should hold vacuum for 30 seconds after motor is off (or more).
You should be able to switch buttons on the controls inside with the motor running and hear the vanes inside the box move; same if motor just turned off so it's easier to hear the movement noises.
The flashing is most likely because you didn't turn off the heater controls with the switch ON before you disconnected the battery. The unit does a check for positions of the vanes and it probably cracked the actuator gears as it went full off and then full on.
BUT first find the vacuum. The source is next to the big hose that goes to the brake booster on the firewall; the big hose connects to the intake manifold on the backside and if I recall the little tube connects beside it. Follow that black plastic vacuum tube to the Y connector next to the AC dryer. You may have to take off the cover over the relay center that has a couple of clips holding it; it covers the area you want to look at. The vacuum line runs through bundles with the electrical wires so you can't see it all.
The Y sends the line to the vacuum storage up front and the other side goes to the inside of the car. Most likely your problem is in the front of the car, not inside.
You really need to see a factory service manual.
If you have a library that's part of a fairly good one, call to see if they have AllData on their library computers. Our county-wide system does, but it's not accessible from home computers like most of the databases and info services. I have to go to the local branch and use their terminal. I can save pages and pictures onto my USB memory stick. I can print out things there if I want.
You can buy factory service manuals used that are authentic Helm GM manuals on Ebay, but you need to do some comparisons from year to year and seller to determine what's the real appearance of the Helm manual for that year.
They are available new form helminc.com for about $125.
You need to find out where power for the buttons is supplied through what fuses and relays.
This past summer I had to replace the manual AC/Heater Control Unit C-60 with rear window defogger switch. I found a used one on ebay. I finally had AC but now I find that the defrost isn't that strong or hot and the defogger switch doesn't work.
My heat works fine.
I know that the control panel only controls the fan, but did the mechanic do something with the temperature or is it just an old car wearing down?
I am having a hard time finding info and was told that I can replace just the defogger switch and that it plugs into the new controls. Is this correct and do you have a part number or photo? Or do I have to replace the whole thing again?
Since the parts are no longer available, no one seems to be able to find part numbers on computers. Hope you can help me.
I cant figure out the heating problem. I have worked on my on cars all my life 35 years now days thy are getting complicated.
Which HVAC system does it have?
Has the water pump been replaced?
Which type of coolant has been in it?
When it's running and the fan is on HIGH, and you touch both heater hoses next tot he firewall, are they nearly the same temperature or is one noticeably cooler?
Which HVAC system does it have? I dont know
Has the water pump been replaced? Not by me, the car dont get hot
Which type of coolant has been in it? Regular antifreeze
When it's running and the fan is on HIGH, and you touch both heater hoses next tot he firewall, are they nearly the same temperature or is one noticeably cooler? Yes. I have flushed the heater core nothing came out but clean water. I replaced the thermostat put in new antifreeze. The heather will blow hot air for a little while then right back to cold and keep doing this. Sometimes it will stay warm for a good while then right back to cold air. Thanks for any information. Michael
* digg
* delicious
* stumbleupon
* netscape
* addthis
Does it have a digital readout with numbers? IF so, the actuator motor that moves the temperature vanes inside may be broken and moving the vanes that direct how much air goes over the heater core wrong.
The water pump may have not be working well due to corrosion of the vanes.
If it had DexCool in it and it had not been changed every 2-3 years or someone added the old type green antifreeze, the DexCool may have been deteriorated and it forms a sludge that can block things.
This is a symptom of a clogged heater core or poor circulation.
One thing is that you might have an air pocket in the heater core.
After draining antifreeze, when car is at full temperature after being driven 10 minutes or so, run the motor at 2500 rpm for 10 seconds, idle, then repeat up to 5 times. This will move the air out of the heater core.
Check to be sure coolant in the radiator is at full level up to the cap.
Either way you're looking under the dash for an actuator arm that moves a vane inside the heater box. Take off the hush panel under the passenger side. I suggest taking off the glovebox door with about 5 more screws on the hinge. You'll be able to see this
link title
and you're looking for white arm on top of the box, I believe, if it's manual. If it's automatic it has that arm for the driver and the lower arm for the passenger. the lower arm comes out just to the right of the bottom screw marked by two red lines in picture.
Look for both of these arms to move if you turn key ON and change the temperature settings and wait a few seconds>
BTW if auto, does the passenger temp change when pressing buttons on the passenger temp control?
Check the vacuum tank connector and tubing behind the front bumper area on the passenger side. While working on my Mom's car trying to fix this problem, I removed the connector from the vacuum tank and it snapped off the tubing instantly. The tubing had become brittle and I believe was leaking vacuum, causing the actuators to not move in their full motion. I reamed out the old tubing stuck in the connector with successively larger drill bits (cordless drill on low speed), then inserted the existing tubing back into the connector. I pushed it back onto the vacuum tank fitting, started the car and the dash vents (MID setting) were again blowing air.
The vacuum tank is clearly visible in front of the passenger tire and behind the bumper. It's about a 4" diameter black tank with black tubing connected to the front of it. I stuck my head under the car about a foot without the need to jack it up. Be careful pulling off the connector to inspect it. The vacuum tank appears to be made of pvc and the fitting on it may be brittle also.
I did this after pulling the programmer from behind the glove box and testing the solenoids and tubing. All appeared to be functioning normally. I then observed the vacuum actuators behind the dash (looking up from underneath the dash) as my wife pushed various buttons on the A/C control unit. The actuator arms moved, but only maybe 1/4" or so. After the vacuum connector was fixed, the actuator arms moved a good 1"-2". Short actuator arm movement would be a good indication of a vacuum leak.
Hope this info helps somebody. It took all of 2 minutes to check the connector and 5 minutes to fix it after it snapped off. A lot easier than taking off the glove box and programmer unit!
Good Luck -
RangerDave19
So far, I've found the actuator and it's linkage and watched it while I moved the temperature control and nothing happens.
So now I need to know how to test the temp. control and how to check the actuator.
Thanks for your help!
this part is used in these cars in manual AC units.
BUICK LESABRE 1999
BUICK LESABRE CUSTOM (1992 - 1998)
BUICK LESABRE LIMITED (1992 - 1998)
BUICK PARK AVENUE (1991 - 1996)
BUICK PARK AVENUE ULTRA (1991 - 1996)
OLDSMOBILE 88 1999
OLDSMOBILE 88 ROYALE (1994 - 1998)
OLDSMOBILE 88 ROYALE LS (1994 - 1998)
OLDSMOBILE 88 ROYALE LSS 1995
OLDSMOBILE 98 REGENCY (1992 - 1994)
OLDSMOBILE 98 REGENCY ELITE (1992 - 1996)
OLDSMOBILE 98 REGENCY TOURING (1992 - 1993)
OLDSMOBILE LSS (1996 - 1999)
OLDSMOBILE REGENCY (1997 - 1998)
I'll try to pull it off tonight if I get a chance.
Thanks to all who posted and helped me with this!
