Anyone have any trouble with their 2002 Chevy Venture
Hello all!
I have a question about anyone who has an '02 (or close in year) Venture van. Mine is nearly 6 years old and has 107K miles on it. It is overall doing fine but I know vehicles don't last forever. Did anyone have any major issues with it as it got older? I'm going to start a savings account for a new vehicle, not to replace soon, hopefully, but I thought in a few years (hopefully 5 more or another 100K miles) it might be time. Anyone out there have to replace their aging Venture van due to major and expensive trouble?
No major problems (knock on wood)
Items replaced which do not count as routine maintenance:
Alternator
front blower resistor
fuel level sending unit
Typical problems which I've heard about but haven't had to deal with:
Intake manifold gasket leak
pressure control solenoid in transmission
You'll find the biggest problem with these vans is the fact that due to their design, even small jobs are major ones as there is so little room under the hood to work and often lots of stuff has to be disassembled to do even the simplest jobs - the part might be 50 bucks but the labor to replace it could be 500. As an example - It took me the better part of a day to replace the alternator and I've replaced dozens of alternators...can't imagine what the labor charges would have been for that job.
Overall has been reliable and a nice ride - its great on the open road and not too bad on gas for its size...and since they tend to depreciate rather quickly (like many American cars) we got it for a pretty good price when we bought it used. Keep[ up on your routine maintenance and I think you'll be good for a long while...good luck
John
Some out of warranty stuff we did:
Spent about $1500 replacing the guts of the driver seat and the seat track (and we're not that heavy), had the oil pan gasket sealed, which cost about $500 but is still not working (the alternate is a much more expensive fix because as someone else said, every job is a big job on these suckers).
I always found that the thing I was most disappointed with on this van was the assembly quality, there was always way too many squeaks and rattles which get worse over time. I've had other GMs before which weren't like that, and my 2005 Cadillac CTS is certainly not like that - it's unbelievable the stark difference between 2 products made by the same company.
All cars break and require repair - even Honda and Toyota have Service Departments
Now over 110000miles and the intake gaskets are leaking pretty good. I am waiting for finances to fix real soon($717). Just did the front break pads($25). Rotors looked great, I just roughed them up to take the shine off. I also had a engine seal leaking on a engine mount causing it to fail($275).
If you search my other enteries you will see my fuel delivory issues and other electrical. My fuel issues have been attributed to electrical issues with plugs and such going bad or terminal shorting out. I had replaced two fuel pumps before I realized that when you moved the harness to drop the tank it corrected the connection for a little while. ($1600) A junk yard harness ($20). Tail light harness from junk yard ($20).
Honestly I really like this van. It gets kick butt gas mileage for the power, comfort and convienence to get 7 people in and out with bags. Wife wants to get rid of it but like someone else said above if you fix the problem you have a great running van paid for for the fix price of a monthly payment.
thanks,
We love our Venture too, its a 2000...
At 5 yrs/60K miles here's what I would recommend if you haven't done these already:
Flush radiator/check/replace hoses & refill with new antifreeze
Change trans fluid & trans filter - this may cure your "slipping" problem
Replace cabin air filter (its in the back of the glove compartment - check your owner's manual)
Replace air filter
That's really it as long as you've kept up with the regular stuff...good luck
When you said "taken care of the trans", what did you have done, and did it cure your "slipping" issue?
If they didn't change the filter (requires removing the bottom of the trans) I'd recommend having that done ..think about it like changing you oil but not the oil filter, you're just putting clean fluid through a dirty filter...
1. Creates foam...the foam does not lubricate like the fluid and could lead to failure...
2. As it expands, fluid comes out the fill pipe, once its cooled, your level could be too low to provide proper lubrication and could lead to failure.
A little high is no big deal...it is possible that the overfill could be the cause of your slipping - not necessarily likely, but certainly possible...you may want to get that straightened out...
I replaced both my front bearing hub assemblies on my 2001 Venture yesterday. Wasn't a real hard job. Cost me $180.00. Cheaper than $1100 at the dealer. It took about 3 hours.
I also recently replaced my a/c compressor and have begun noticing the same type of rattling sound when stopped in gear with the a/c on. Haven't diagnosed the problem yet as the a/c works fine and the noise resolves at driving speed. However, I tend to doubt that this a/c problem is related to your whirring noise (can't completely exclude that your the a/c compressior bearing isn't going out.) Perhaps of note, the belt-tensioning pully on my Venture started whirring recently (at 170,000 miles), and suddenly my serpentine belt broke, shutting off my power steering, a/c, alternator, and water pump......turned off engine immediately to prevent overheating. On replacing the belt, I noticed that the tensioner pully had actually frozen up and melted, ruining my old serpentine belt. Easily replaced the belt-tensioner ($50) and the serpentine belt, and problem solved. Ventures are great vans, but they require a lot of tinkering.
