This car is a mess!!
I replaced all 8 ignition coils a few years ago. Number 4 is misfiring again. I don't believe constantly changing out the coils is going to get to the root of the problem. I guarantee you Lincoln knows where the problem lies and ain't saying anything. They need to step up to the plate and make the engine right for at least the original owners. I will NEVER buy another Lincoln.
Where did you get the coils? Are they OEM or aftermarket?
Leaky valve cover gaskets . . . . check
Replaced by auto repair place. . . . . OEM/check
The responsibility for a reliability of the engine lies with Lincoln/Ford Motor company. A consumer complaint was filed by me, an LS owner, against them back in 2007 for this very problem that so many LS owners are experiencing too. The problems began right after the 50,000 mile warranty expired. Lincoln knew this was a problem that is why they extended the warranty after 2002 to 80,000 miles for subsequent models. This problem is a result of a manufacture design/defect, period, nothing more nothing less and Lincoln should own up to it and recall the engine for total over-haul at their expense.
But honestly - I just don't understand why people think that a manufacturer should be responsible for fixing every problem that ever happens to a vehicle even after 100K miles. That's why they offer a warranty. If you don't want to pay to fix a car after the warranty expires then get rid of it and buy something else.
And just for contrast, I had my 2000 LS V8 for 6 years and never had a single engine problem and I know a lot of others with similar experiences. It wasn't a problem with every vehicle.
Now that we know the truth, time for a class action lawsuit. FORD!!!!! STEP UP TO THE PLATE AND FIX THIS PROBLEM OR YOU CAN EXPECT A LAWSUIT FROM ME AT LEAST.
http://townhall-talk.edmunds.com/direct/view/.eea4390/19#MSG19
I never said it wasn't a common problem - I said it didn't affect ALL vehicles - just some of them.
You can't be in violation of "failure to recall" if it isn't a safety issue.
Save yourself a lot of grief and a possible heart attack and just get rid of the darn car if you don't want to fix it. The manufacturer isn't responsible at this point. And that would go for any manufacturer, not just Ford.
BTW, I'm long pass the point of heart attack almost had that when my engine failed twice now. Now is the time for legal remedies.
So go ahead and call me a liar - I don't really care. I know the truth.
Ford takes the stance that it is an almost perfect car the only recall i could find was on a wheel assembly and that was just on certain serial numbers.This engine should have been recalled i am very surprised that there have not been some serious wrecks because of this.
Another question is since the dame engine has been used in the T Bird why have we not heard from the owners on this same issue.
Just note:Every mechanic and i mean every one of them factory trained or hates to work on this car much less the engine so repairs are very costly.I call min eht $ 800.00 car because all estimates nomatter what your talking about start at $800.00
Years ago the Jaguar was acused of spending more time in the shop than on the road i think it has been replaced
http://stores.christophersforeigncarparts.com/-strse-template/about/Page.bok
This failure does occur but it certainly isn't prevalent. I searched back over 12 years of posts from thousands of LS owners and I could only find 2 occurrences - and one had 285K miles on the engine.
Absolutely positively false. There is no "stress" that can be put on the coils because of a bad timing chain or tensioner. Coils are electrical devices. They fail due to heat and/or moisture.
There are plenty of cases of bad coils and the vast majority are due to a leaky valve cover gasket which soaks the coils and boots in oil causing premature failure. Other coils can fail over time just from heat and normal use.
Coil problems are common and Ford extended the warranty on some vehicles. But the overwhelming majority are actual coil problems not caused by the tensioners. The tensioner is a separate and relatively rare problem. And once fixed the coils should last for at least 75K.
Yet another incorrect statement.
You simply have no idea how a car engine works. The tensioners do fail sometimes but they have NO impact on the coils. Coils misfiring do not cause oil leaks.
Tensioners can fail. Coils can fail. Valve cover gaskets can leak which can cause coils to fail. Once it's out of warranty YOU'RE responsible for repairs and that goes for ANY product made by ANY mfr.
You're expecting a lifetime warranty and that's simply not realistic from any vehicle mfr.
The 2003 LS got an extended warranty on the coils and gaskets to 10 years or 100K miles. You are wrong again! Notice a pattern here??
These are very minor problems that with time will happen to ANY car with Cop's. Again please read.
The tensioner were improved after the early versions started wearing out. If Ford/Jaguar had known from the beginning they would not have installed them. If fact if you would look into it you would find that Jaguar designed the entire engine and actually had 3 versions before releasing the mostly metal version from the 2003 and up cars.
There is and was nothing wrong with the timing chain. In 2003 Ford upgraded to a stronger more quiet running chain from Japan.
Another dumb [non-permissible content removed] "expert" on the internet!!
My car is once again experiencing the same engine failure problem and it is because of the loose chains. It is misfiring too, AGAIN after very expensive engine coil and other ignition repairs. IT'S THE TIMING CHAINS, STUPID AND FORD KNOWS IT. I am not in any financial condition to buy a new vehicle or trade it in AND EVEN IF I WERE IT'S THE PRINCIPLE OF THIS MATTER. FORD SHOULD STAND BEHIND THIS PROBLEM FOR THE OWNERS OF 00, 01, AND 02'S. NO IF ANDS OR BUTS ABOUT IT. There are plenty on the road still that are road hazzards!!
Stop calling people names especially if you have not clue what you're talking about.
I am in your corner once ford knew they had screwed up and this car is a screwup no doubt.They should make some sort of retitution to the owners of previous LS's after all we were the test samples for their test market car.Dealers do not even want to work on this car.Its got more rattles and shakes than an old 78 olds i have that has close to 500,00 rough miles on it.Construction sites back roads it spent the last 200,00 being more of a work truck.It has some probelms but it has used tires on it,the shocks are 15 tears old the trans leaks a little and i am burning about a qt in or around 1500 miles.I take it on the road because it is a much bettter riding car.
I know about mechanics not wanting work on this vehicle. It's a MESS and one I have been stuck with and I WANT COMPENSATED FOR ALL MY REPAIRS THUS FAR AND I WANT A NEW CAR THAT IS RELIABLE, they owe me that.
I filed complaints with Ford/Lincoln back in 2004 and demanded they fix the problem, they refused of course and I file complaints with other consumer rights agencies. This company NEEDS TO BE SUED. We need to start a multi-plaintiff lawsuit against Ford. Thanks for your support, cmax.
ANY first year car will have a few bugs, which are fixed as the model years progress; ergo the tensioners (which, BTW, are NOT the same thing as the timing chains) and window regulators. There is NOTHING dangerous about the L (other than the knucklehead behind the wheel). The problem has and will always be coils. The plug needs to be replaced with the coil (NO coil packs, grrrrr.....) as the coils will kill the plug and vice-versa. Yes, the '00-early'02 had tensioner problems. The plastic guide (have to keep the engine quiet) was changed to metal (more engine noise) late in the 2002 model run. The chain skips a tooth when the tensioner breaks and the engine runs rough (DUH!). Fix the tensioners and re-index the chain and the engine will be as good as new. The warranty certainly WAS NOT changed to 80K miles. There was a customer satisfaction program that extended the valve cover gaskets and coils to 10 years or 100K miles. That was only for (IIRC) 03-05 models. Both my '06's came with the basic 4yr/50K mile warranty.
Simple/basic maintenance will keep these, or any other car, running for a very long time.
This is why I don't come here often.......
Next, since I started this blog concerning Ford's FAILURE TO RECALL THE LS when they knew or should have known that this serious engine failure problem existed and chose to do nothing about it back in 2003 when I contacted them about my 2000 LS, please re-read all my posts concerning pasts engine repairs/replacements, etc. including the ineffective ones you outlined in your uninformed post. I am the original owner of mine and it is setting in my driveway inoperable right now due to another engine failure problem and I am afraid to drive it because it has shut down on me in heavy traffic before. I cannot afford another vehicle right at this time and I am not putting another dime in repairing the vehicle, I want compensation from LINCOLN for their defective product or I WANT a recall. I have all the necessary repair bills to back up my claim and Lincoln has my formal complaint originally filed with them back in 2003. Additionally, it's not a matter of basic maintenance. In fact Lincoln service managers along with other experienced mechanics will attest to the fact this IS A serious engine failure problem AND is unique to Lincoln LS's and Lincoln refuses to stand behind their product safety, preformance, and quality then as well as now. You have no idea what you're talking about, eaircon4jc. Lincoln has known for a very LONG TIME THAT THIS IS A SERIOUS DANGEROUS SAFETY ISSUE AND CHOSE TO IGNORE THE PROBLEM, now National Highway Safety and Transporation Board can do their job.
Calling the people who respond to your post uninformed tells us much more about you than them. Allen in particular has been posting since the first LSs hit the road and is about the only one of the "old timers" who still takes the time to respond at all. Several of us owned and drove LSs for well in excess of 100K miles with mostly minor issues. Sorry you weren't so fortunate.
There's no doubt that the demographic of LS drivers has "evolved" considerably since 2000.
