GMC Jimmy Transmission Problems
1998 Jimmy After truck warms up shifts hard between 1st and 2nd gears. any ideas
I have searched high and low to find the culprit to what is going on...
Mine is a 1997 Jimmy 4x4. When it is cold outside, the transmission shift hard from 1-2 and takes quite awhile (as well as a low speed) to shift from 2-3-4.
The RPM needle shakes violently back and forth thus preventing the vehicle to obtain speed.
The vehicle WILL shift eventually, but this make going up a slight hill very slow and time consuming.
However, when the vehicle is warm or the weather is even warm outside, the transmission shifts great and doesn't seem to hesitate at all.
Could this be something as easy at the TPS, Ignition related, or perhaps bad plugs?
Help me out here as I am growing tired with this vehicle.
I love this truck! Mechanic says not worth fixing at 187k. I agree ($890) but, If i can find good used or rebuild for under 300 I'm going for it!
What tranny or rebuild kit do I need? Will a 4 speed work? Are there any special tools I need for a rebuild?
Thanks to everyone who tried to help
4hi dose it but not 4lo any ideas would be great
I wouldn't go anywhere near it. Beyond possible water damage, transmissions don't ordinarily become submerged without serious stress on the entire system.
SUVs and Smart Shopper
My friend is a disabled Vietnam vet and on a budget so i was hoping i could help him out with this.
Kurt
thanks much ghowtrk
front area, sounded like a squirrel cage fan being blown with an air
nozzle. Pulled over to check things out saw nothing. Then discovered
no reverse, could drive foreward but second gear came in slow and at about 3200 rpm's. seems to be slipping the whole time while
motoring. Any ideas what might have happened??? :sick:
