Nissan Altima 2008 Maintenance and Repair
I just bought a 2008 Altima Sedan 2.5S and is under 200 miles. Today, I finally looked under the hood along with the manual book in my hand to learn the whereabouts of all fluid locations.. to my surprise.. from the center of the engine all the way to the right side..(on the air filter, battery, etc.) I see a oil-like all over.. as if it has been spraying out somewhere..I ran my fingers on it and it smeared like oil - I could not smell it.. but it's like clear to brown in color... Does anyone know if this is normal or do I have a leakage somewhere? Is it the oil like I suspect? Yes, I will take it to Nissan and have it checked.. meanwhile.. it's the weekend.. and would like to have some peace of mind until Monday.
In addition, the power steering fluid reservoir, should that have been filled to max when I first bought the vehicle? Because, right now the level is below the Cold Min.
Thanking in advance for your advise or comments.
But I found out that it was not anything to worry about..it was just the cleaner that was used to spray over.. that makes it look so brand new... as the engine heats up the spray agent starts to sweat.. I simply wiped it down.. and all is well...
Any advice from knowledgeable gentlemen and ladies....please?~!?
SP :lemon:
If so, is there another dealer in the area you can take the car?
Are they providing substitute transportation while the car is in the shop? If not, I would definitely demand it, if the repair work is being done at the selling dealer...
Same dealer doing repairs!
There is another dealer about an hour away...what can they do for me please?~ I am at a loss here................ and yes, on my 2nd rental car provided by them. The PR that is being funneled here especially since I W A S driving a new car is overwhelming...everyone wants to know the "story" and yes, I am sharing !~ *grin*
The CLUTCH code is very interesting to say the least~!~! Don't you agree?? :confuse:
Obviously, I only know what you have posted, but it appears that this dealership is doing a lot of "head scratching" on you car. And, what's upwith the CLUTCH code? Is anyone in the service dept. actively pursuing that with Nissan USA???
Lets face it...there are only so many things that will cause your problems, and there are ways that any reputable dealership can determine the cause of discharged electrical systems (I am assuming you are experiencing a dead battery situation here).
It just seems that a second pair of eyes are in order here. At least, they are providing a rental. Make sure you get copies and RETAIN them of each visits paperwork...you may need them in the future....
Good Luck!
I'm not much of a mechanic.. but because I have a 2008 Altima too.. I make sure that I read up all about it....and be knowledgable with all the specs..
Just wondering... they changed the starter.. then they say it's a clutch issue-- but you have an automatic... Do you have the Intellegent Key with the Push Start Button? If yes, could it have been the battery for the IK?
Please do let me know what problem it was and how it was corrected.
On the CVT Altimas, you need to have your foot on the brake in order to start, and on the 6-speed (like ours), you must depress the clutch pedal. The ECM code likely read the same when they scanned it (hence "clutch")
Ever since the idiotic "60 Minutes" fraud about Audi "unintended acceleration" cars have been saddled with this nanny switch.
IMHO, the service dept wasted time & effort replacing the starter when it was (obviously) a simple switch.
However, I have noticed (similar to comments posted in some other threads around here) that when I get the car moving over 30-35mph, I hear a high pitched whistling from outside the car. If the windows are up, you can't really hear it... but with the windows down, even just a little bit, it's loud enough to be very obnoxious. The pitch changes with the speed and the gusts of wind, so it must be a gap or a hole somewhere that's making the sound.
Do other people have this problem, and what have you done about it? I suppose I'll bring it back over to the service department and see what they have to say... but before I do, any advice on what to call this problem would be greatly appreciated.
Hey guys, ran into this on another forum...I am going to have my service department look into it. I hope it help some of you, maybe this is the answer!
"I purchased a 2008 Altima 2.5 S, and when the window is down, there is the same annoying whistling sound that you discribe. I get this noise between 40 and 60 mph. I did a little "detective" work and I discovered that if I covered the side view mirror with a towel, I did not hear the noise. I examined the mirror and saw that on the botton portion of the mirror, there is a seam. I purchased for a few dollars a clear silicone adhesive sealer, put down a narrow bead in the seam, and 99% of the whistling noise is gone. I felt this was a better solution than going to the dealer, who would either not do anything, or do the same thing I did, or worse, replace the side view mirror. That could open a whole other can of worms. If you take your time, the silicone seal will not be visable...and it worked for me. Hope this helps."
You may be correct on the mirror theory. I have a friend who once worked for Mercedes in Germany, and remembers an instance of one of their cars having a similar problem. He said they replaced the outside mirrors, and the problem went away... so it maybe something similar here.
I have an appointment for Monday, June 9th to have someone at the dealership take a look at it. I will post after they've diagnosed/fixed the problem.
Good luck with yours!
On Thursday, they called to tell me they have diagnosed the problem to be the outside mirrors... but Nissan HQ still doesn't quite know how to fix it. They said HQ is aware of the issue, and knows the simply replacing the mirrors won't fix the problem, so they're "working on it." They then told me they would call me back in a week or two with a remedy... just as soon as Nissan HQ tells them what to do.
So for right now... it's Whistlin' Dixie for me, although after they worked on it, they managed to tone it down a bit, so now it's just a high pitched squeal, rather than a whistle. A friend of mine (a former Mercedes worker from Germany) recommended I put plastic wrap (like from the kitchen) over the mirror to stop the whistling. He said a little plastic wrap and some tape, and that should be a good temporary fix... just don't cover the mirror part. I'm going to give that a try... at least until they fix it.
I'll update more when (if) they fix it.
It amazes me how they missed something like this during their test runs of the car... This is so obvious that it's literally obnoxious. I really hope nissan fixes this.
http://www.nissanclub.com/forums/new-2007-2008-nissan-altima-discussion/267366-0- 7-altima-mirror-whistle.html
The folks over there seem to have had theirs fixed by simply having the mirror replaces... contradictory to what the service guys told me. Hmmm.
Luckily my car hasn’t lost power while I have been traveling with my two children, but I hate to think about the next time it decides to turn off. Has anyone heard of this issue occurring in the 2008 vehicles? Any information would be appreciated.
I did ask the installer before instillation that I didn't want remote start to turn off on me and that I have a keyless push button start ignition.
One day, just to check, I opened the hood and found that car coolant is almost at the minimum point. The other point that I noticed was car, when idle, has RPM more than 1000 and when started in morning goes up to 2000 without doing anything immediately after switching on the ignition.
I went to the dealer and they said car is okay and has no problem. And I guess they were just checking engine codes or waiting for check engine light to turn on.
Someone told me that there is possibly a problem with Engine Idle controller. Can anybody explain this to me and any idea what should be the RPM range when car is started first time in the morning? Is there any such range, I can tell the dealer that car is going beyond so that he agrees that car has some problem.
Your help is appreciated.
2. the coolant level our seeing is in the reservoir. the level will go up and down depending on the temperature of the engine. when a liquid is heated it expands. thats what the reservoir is for, to hold the extra volume of antifreeze due to heating. when the engine is cold, there will always be less coolant in the reservoir
3, when your car is cold, the engine will idle higher. a cold engine is very ineficent, and the idea is to warm it up faster. thats why the increased idle.
