Lexus RX Personalized Settings
catdaddylong
Member Posts: 53
in Lexus
As you know after buying a new Lexus you are handed a personalized setting sheet and they set up an appointment a month later for you to come in and have the settings done at no cost. Most of the settings that are standard are not changed. What settings do you change and why?
I do NOT use the compressor unless actual cooling is required.
Later c-best versions (04+?) allowed a setting wherein the system would not automatically switch to cooling mode once the cabin temperature climbs to within a few degrees of your setpoint.
That "switch", if allowed, can prove to be hazardous since the interior surface of the windshield is no longer warmed once the system switches to cooling mode.
If you are happy & comfortable with the default settings, leave it at that & enjoy it. I bet most of the people don't change the defaults.
So if you had to pick a non-Lexus....what would YOU have picked that has somewhat similar luxury and driving characteristics?
Bud H
