Mitsubishi Outlander Exploding Sunroof
blovegrove
Member Posts: 5
was driving down the highway at 120km and all of a sudden the sunroof exploded up and out. I didn't hear or notice anything hitting the car, just a big bang and we were showered with glass. There was a big hole in the middle of the sunroof, and it looks like someone punched a hole from the inside out. all the glass around the edges pointed upwards. It was only 10 degree celcius and the inside temp was set at 20degrees celcius.
Anyone else had this happen?
everyone was fine, just a little shocked. now the question is, will it be covered under warranty? The dealership is looking into it, but the roof panel is $865 plus labour!
A friend of mine detailed his SUV one day and had removed his sunroof for some deep cleaning. Then another buddy called to say the silvers were running and off they went. He spaced out that he hadn't put the trim back around the sunroof.
The glass flew off on the highway going about 70 and he watched it land in the middle of the (fortunately empty) road and shatter in his rear view mirror.
The dealer wanted about $900 to fix that one too, but he called his insurance company and they covered it.
J.
If the glass edges were pointing upward, why were the passengers "showered" with glass particles? Shouldn't the particles have blown upward? And traveling at that speed, I don't expect the broken pieces that were blown upward will come back down to hit the passengers.
I always thought the glass materials that these sunroof were made from are shatter proof? They should not fall into particles when they break. Don't they contain a plastic the holds the broken pieces together?
Hmmm, some parts of this case just don't add up?
With AC as part of the vehicle I really didn't care for the sunroof, but it came as an inseparable "sun and sound" package and I definitely wanted the RF sound package. If it's not too late I would take lots of pictures before the evidence is destroyed. I guess it's a good thing I rarely use the roof and keep the shade in place (I only pop it up with the shade just open a little until the hot air is evacuated out when I first turn on the AC.) This I guess may save me from cuts in the future!!!
I'd be curious to hear what your insurance adjuster says. If it was a manufacturing defect I'm sure he would try to pass it back to Mitsubishi.
One oddball problem (the sunroof) and a rubber belt that fails (not uncommon) does not make it a bad vehicle.
There certainly is a cause. We just don't what it is. But I do think it's a bit presumptuous to assume that something had to hit the glass. Another possibility is thermal stresses which may suggest a manufacturing defect, e.g. some nonuniformity in composition of the glass affecting thermal conductivity.
SUVs and Smart Shopper
(yes I have glass coverage too, but we're not talking about a rock thrown from a dump truck)
