2001 Nissan Frontier Wheel bearing failure
bobincinti
Member Posts: 6
Hi everyone. I wanted to let everyone know of a problem that I had with my 2001 Nissan Frontier this weekend that is a serious safety issue. Here is what happened.
My Nissan Frontier has 152,500 miles on it. Over the weekend a wheel bearing in the rear axle failed. With 152,000 miles, I have no problem with this repair. However here is the safety issue.
While I was driving it, the tire / axle assembly seperated from the pickup and went into traffic. It tore my brake lines and I lost all hydraulic fluid when I realized what happened. The tire / axle also went into on coming traffic.
Luckily no one was hurt, but the truck has sustained about $1500 worth of damage. Has anyone had a similar problem with Nissan vehicles?
Do me a favor and write the NHTSB about your problem as well. I reported this to them and they have not received enough complaints to force another recall. The info is as follows:
http://www.nhtsa.dot.gov/portal/site/nhtsa/menuitem.9fee1be6b2b2000bc22cf3749000- 8a0c/
I sent the NHTSB my parts and they concluded that water got into the axle via the ABS Sensor and caused rust. But they told me that they were not going to do anything about it.
I would also contact Nissan customer service about this issue and report it.
Bob
I sued Monro and their insurance company sent me a check for almost $1K. The insurance agent said he never saw a bigger hatchet job of a repair.
If you talk to the NTSB, tell them this is similar to case 10240574. I had my Frontier serviced for the recall and the wheel actually came off while driving.
Anyone who has this vehicle should inspect their rear bearings ASAP and report it to the NTSB and Nissan.
roads and my father owns a large cattle ranch(1600 head and about 4000 acres) so this truck has been driven in the pasture, through creeks, dry washes, deep gulleys, swampy low ground, and hilly, rocky scrub oak woodlands feeding livestock, pulling calves, hunting strays and just checking on the cattle more times than I can count. This is my 4th Nissan truck, 3 of them have been 4 wheel drive and I have always got my money's worth out of them, this one included when you consider that this is the first problem I have ever had with it and it has 154,597 as of last night. I talked with a former Nissan mechanic who has his own Nissan Repair Garage last night and he gave me a rough estimate of $450.00 including a rear brake job and replacing the wheel bearing on the other side as well. As long as he is going to be in there working on it I might as well replace the wheel bearing on the other side (driver rear) as well...don't you think? This included parts/labor and sounded pretty good to me but I was going to call the dealership today and get an estimate. The former Nissan guy said that he had done several of these and he sounded like he knew what he was talking about, plus he knew about the recall on the wheel bearing because of the ABS sensor leaking. I'll let you know what I find out from the dealership.
It sure sounds like you jumped through some hoops in getting your truck fixed, do you still have it or did you end up getting rid of it? I'm glad you settled with the Chain Service garage because often those places will screw you over and wait for the next person to do the same if nothing is said or done about it. Thanks for the interest and advice on the Frontier.
