02 town and country power sliding door
I have an 02 town and country with the passenger power sliding door. When we go to hit the button inside or on the remote for the power sliding door it just pops out and stays there it does not slide back. When we manually slide it back and hit the button inside or on the remote the door closes fine. If we open the door again from it works fine. If we do not use it for a little while we have to repeat the process over again. Did anyone else have this problem? Any ideas on how to correct it?
Thanks for any help you can give
The description of your issue sounds like the notorious "broken wire in the flexible plastic track below the door" problem. The wire gets a break in it after flexing back and forth a bajillion times over several years, and when the door hits that bad spot, it quits. If that turns out to be the problem (and it may not be, I'm just taking a guess based upon your description), it's a fairly easy fix. Basically, just a matter of cutting the bad length of wire out and slicing in a new length. The trick is doing a good job on the splice or else it may just work free again after you run the door through a few of times.
Or it could be something else unrelated to the wiring (shrug).
Either way, good luck.
Edit - I'm not having any luck posting a workable hot link here so you may have to cut and paste the following URL in your browser window if the link isn't clickable -
http://forum.chryslerminivan.net/showthread.php?t=4555&highlight=sliding+door
TONY
T&C Dad
It has something to do with the electrical system in the car. I had an extended warranty on my van and filed a complaint with the Dodge customer service. They fixed all the electrical on the van door passengerside and it did fix it, but now the driverside door is doing the same thing. I just have to keep it locked at all times. They told me that is all they would fix on it and if it messed up, I would have to have the rest fixed myself. It is a flaw on this van, and I believe there should be a recall on the van. I myself, am just waiting until it is paid off, and I am getting rid of it, and I will never own a Dodge vehecial again!!!! Customer Service was nice until you get a case worker, then you just have to stay on top of them and they finally did something. You might want to try to file with the customer service and see if they will try once to fix yours. It is a pain, and quite embarrassing to deal with the problem! I think everyone with the problem should complain to customer service and then they might get that there is a true problem with the van doors. Sorry, I truly feel your pain!
