1800822AUDI to talk to corporate. We all need to take this catalytic converter issue to corporate.
On drive home from dealer after having coil recall work done, the check engine light came on again. Turns out, both of my catalytic converters and 2 O2 sensors leading in were totally shot.
The Audi dealer told me "Audi has not let us know about any link between engine coil malfunctions (the recall) and catalytic converter failures". They proceeded to say, in very predicatable fashion, that they were not responsible for any of the repairs and gave me an outrageous quote. So I took it to my import mechanic. Total repair was $2,850 (~20% less than Audi quoted me).
I am writing a letter to AOA, but have little confidence that they will pay. Who were the attorneys on the last class action? I'm sure they are aware of this "development" but, if not, my wife is a products liability attorney (on the defense side, ironically) and I will have her reach out to them.
I am hoping that others will raise their voices. Audi needs to pay for their shoddy product. I was told my 02 sensors were bad at the time I had my cat con replaced.
Catalytic converters should not fail. I'd be interested in a suit also.
MODERATOR /ADMINISTRATOR
Share your vehicle reviews
There was still an "open recall" on this vehicle and they changed them out, no charge.
5-days later, check engine light is on again and gear indicator is also on. called audi customer care again and was told it is something we now have to deal with the volkswagen dealer since "WE" had it done there. are you f****ing kidding me? this is an a4 cab with ONLY 27,000 miles and ALL these problems? we are not talking about a hyundai here and we are not talking about a car with 100,000 miles in it. and all audi can say is i have to deal with it?
we have a bmw x3 with 118,000 miles on it (knock on the wood) it hasn't given us this big of a problem. AND this i told audi customer care. i got the same response... can't do anything about it ... i have to deal with it with the dealer that fixed it.
DEFINITELY... NO AUDI AGAIN!!!
I wondering if anyone tried replacing or disconnecting the catalytic sensor? I'd assume the only potential issue is with passing a smog test?
Thanks much
When an ignition coil fails, and causes a misfire in a cylinder, the fuel is still being injected into that cylinder. That unburned fuel will enter into the exhaust system and will pass through to the catalytic convertor, which is typically MUCH hotter than the rest of the exhaust, by design. This introduction of raw fuel into the catalytic converter causes the destruction of the cat. So if you have had a misfire in the past, it is safe to say that you will be replacing a catalytic convertor in the future.
Back to the blinking check engine light... This "blinking" light is warning you that the catalytic convertor is in danger of "meltdown" ( usually a sure indicator of a cylinder misfire). This situation is not just for Audi's, however. If any of your cars or trucks... American, German, Asian etc. display a "flashing" check engine light, the same problem(s) probably exist. You will probably experience the same after affects as well.
The best thing to do in this scenario, is to get the vehicle off the road and into a service shop ASAP, preferably without the engine running ( to save your catalytic convertor).
I had very similar problems with my Audi (2001 A4) in June and since I am the second owner, I did not get the recall on the coils... I had to get my car towed to my regular body shop and before I knew what the repair was for, they coils were replaced. I called Audi because my mechanic said that my coils were under recall a few years back. I had my repairs done (at my mechanic -not Audi) and then just faxed in a reciept to Audi Customer Care and (although it too several months), I did get a check for the parts and labor... Great Customer Service on Audis part.
Two questions:
My heads up display is not working.. Its not completely out because I see traces of information byt so blurred and distorted that I cannot make out that its saying... My car randomly beeps and Im sure with a proper heads up display I would know what its saying... I have been made aware (during an oil change) that my wiper fluid holder is cracked.... So I assume its telling me I need fluid??? I have googled a new display and it requires minor electrical abilities (I have NONE).
So, my first question is: Has anyone had this issue with their heads up display? Is there and easy fix?
Second question: Just yesterday, my car was having a bit of a trying time starting... slight hesitation... I feared the worst! (Had a new alternator put in it in April 2011) Once started, car ran great, no notifications of any problem (but with a non-working head up display ^ who really knows) Got to my destination... and my car sat for a few hours... went out to head on an erron and it started fine (slight hesitation noted) and drove two blocks to the mail box on my way out.. went to start it again and I got the "I have a bad cold" failure. It clicked and attempted to start but nothing...
So: Could this be my battery? OR WORSE???? I had it jumped and it started right up and was great.... got it back to the house, let it run for a bit and then it sat for several hours again.... went out before bed to give it a pep talk and nothing..... it tried but just would not perform.... HELP!!!
