Mazda Tribute Start Stall Idle Problems
i having trouble with my mazda this morning i was almost out of gas but it stall and when i went to start it back it would only click it wouldn't do anything else. got any suggestion what could be wrong with it. please let me know asap. thanks
I'm having the exact same problem so I was wondering if you found a solution yet. My dealer changed the battery, alternator, and fuel pump and nothing has solved it. Any advice would be greatly appreciated.
thxs
Had a problem over a year ago on my 02 Tribute (V6 ES) and paid the diag fee and another $180.00 or so to replace the idle control valve. Part was + $40.00 at the dealer versus AutoZone. The problem comes back now an then and the idle can float to 1500 or more, sometimes not coming down. I have a month or more left on the 1 year warranty for the work they did and do not wish to pay a 2nd diag fee since the first did not solve the problem. We'll see how it all works out. I'm worried if the idle creeps up to 1000 or 1200 and my wife or kids are driving, they may put it in gear ... ouch !!
I had a very similar issue with a Jeep about 3-4 years ago.. turned out the cat was shot and plugged up. It finally blew the stuff out and since then, the exhaust sounded different. Eventually I had the system re-done but prior, the thing almost wouldn't run and had a severe loss of power until the bb's burned or blew out. This could be a simple and inexpensive fix if you end up with the same diagnosis.
a) if it's me doing the guess work by trial and error, I start with the simpler and less expensive things and work up from there. Take the cats off and eliminate that issue yourself. You can temp run the thing with just a muffler and see if the engine runs ok as a short term test. Then you'll know if there are other factors or not.
b) where ever possible, I trust a shop to do the diagnosis for me. They have specific equip to check things. This way they are accountable to the fix and warranty as well as a mis diagnosis that replaces the wrong items that I would not feel the need to pay for.
Sorry if it sounds like I'm dodging your question but a shop doing a few basic checks related to the symptoms you describe should be fairly cut and dry. I'd think 2 cats and the system back (mufflers tailpipes) and labor is going to cost upwards of $400.00. Be sure you give the shop as much info about the way the vehicle started acting up and when.... often the right choice of words and some basic patterns can really give them a lot more to go on. Post back what you end up with when all is said and done !
Have your dealer do the code check and follow that path down to the fix with the understanding ahead of time that you will hold them to it. It will be a total of the diagnosis fee and the parts/labor. If they dont' get it right the first time, they will have to use your fees paid as credit toward the new fix ... should it go beyond the previous price you already paid. Mine was a wash ...around 180 to 200 $$.
Then go out and test it as much as you can to be sure they solved it. My problem was so intermittent that it was hard to know if / when it was fixed.
After a couple minutes to warm, the car shutters beyond 2000 RPMs. I refuse to pay of another Diag fee. They missed it the first time, now we try again.
1) could it be an air flow and or fuel mixture issue ?
Secondly, I am awestruck by dealers that hit us with the $100 diag fee then won't stand behind it. I'd rather they do the work and replace the part after I'm in for the $100. Then, how can they make you pay for the diag and the fix when the fix isn't it..?
Tell them they are going to earn that $100 this time around and you'll know when they are done because you car is fixed and under warranty for a while to boot.
*Simplify your point; One diagnosis fee = one correct diagnosis period.
They'd likely have to re-do another diag but you cannot owe them for two fees when they boogered it up the first time if the fuel pump they put on is not the fix.
The whole idea of the fee is paying for the elaborate computers they have that are nearly fool proof and save them hours of time in actual diagnosis cost/labor. They are double dipping in the profit center most of the time. Book time is $80 or more per hour nowadays and we are paying $100 for a 2 minute hook up to the computer. That's $50 per minute and lawyers don't make that !!
I always think about how things like that can go wrong and I try to rehearse what I'll say to counter them .... and how I"ll say it. It pays to be nice and friendly but hold your ground at the same time. I have them listen to me say it out loud and restate it back to me that I'll pay the diag fee and the fix if it's the solution. I'm sure there are times when it can be a domino effect or one problem linked to another gizmo but that would be an exception and I believe I'd understand the process and if I felt them credible, I'd pay the extra w/o fuss. For the most part just get them to agree to your terms or go elsewhere before the fees add up and the thing still pukes and fogs. Good luck!
Clay
We have a 2001 Mazda Tribute - occassionally it will not start - the motor turns over, battery is good - but it does not catch.
If we leave it for a couple of minutes, then turn the key again , it will start. We had the fuel filter replaced a few months ago and after that particular operation, the issue seemed to go away - unfortunately to return now. Has anyone seen this
before ? , any idea of what the problem could be ?
Our mechanic said last time that they saw no events
in the cars engine computer - in fact for something
there to register the 'check engine light' would have to come on - in this case - the 'check engine light' does not come on - so we have no idea as to the issue.
The car is leaking a little oil but outwith that there is no
other standing issue here.
Any thoughts appreciated .... car has 120k. Oil changed regularly every 5k. miles.
2. The Idle Air Control valve can stick closed intermittently - if you open the throttle a bit while cranking and it starts, change it.
3. If the fuel pump check valve does not hold pressure with the key off it can cause extended crank before starting. Cycle the key on and off before starting (primes fuel system). If it starts with this method, get the fuel holding pressure checked.
4. Get a new mechanic.
they have not been changed in a very long time .... probably won't do any harm together with the other items you mention here. I had to laugh at point 4. - probably
should consider it cheers ....
Anyway our mechanic found that a hose which feeds from somewhere??? was collasping in itself (possibly some vacuum hose) and he said the hose was not the Mazda original. So he replaced it with a more stronger hose and that seemed to have fixed that problem.
After about a week later, the motor would start good but some days the motor would misfire and you could see the tacho needle jumping up and down about 300 rpm. On those days the motor had no power and it was astruggle to keep it going.
On other days the motor would not miss a beat and performed well all day. But the very next day it went back to the misfire.
So I took it back to the mechanic who then changed the lft front coil pack and this seemed to fix the problem.
After about another week the misfire returned.
The machanic suggested we change all of the spark plugs to the more expensive ones with a longer life which meant the manifold had to come off (Just to change the plugs) DOH.
Anyway after a $750.00 AUD bill the car is still misfiring on some days and some days it has lots of grunt.
I talked to a Mazda mechanic and he said that he chased his tail for 2 years with no luck and he just gave up. He reckons that it is design fault in the motor from new!!!!!
So if anybody out in inernet land can help well I am listening Thanks from Dennis in Australia.
The dealership ran a diagnostic and told me that I had a crack in my head gasket, which was causing leaks of air into the system (which was worse when the engine was cold). Also, my idle speed sensor (which regulates the fuel/air mixture at different engine temps and RPMs) needed replacing. I hated to spend the money to get everything fixed, but my car runs like a charm now!
And since replacing the plugs involved taking the engine apart (which cost about $350US) the dealership replaced them at only the cost of the plugs while they had the head off to replace the gasket.
I hate that you already had the plugs replaced, but I would recommend having your mechanic look at your gasket and idle speed sensor. If that's the problem, hopefully your mechanic will realize his oversight and work with you on the repair bill (since he already had the engine apart and should have seen the condition of the gasket).
Did you get any resolution from your dealer?
The next time you start it check to see that exhaust fumes are actually coming out the tail pipe so that you don't blow your EGR valve..........My story is that my son asked me to change his transmission fluid in a 2001 escape Saturday. I released about a Qrt of the trans. fluid and replaced it with Lucas oil which should provide much viscosity to the other 10 qrts or so left. I took it for a drive around the block and decided to take it on the freeway. The Escape kept losing power until I heard a hissing sound-air being sucked into engine from a partially destroyed EGR valve. I don't know which catalytic converter is gone but fixing to order the rear one which costs around $150 with shipping. If I need to do the other two, I guess I'll be going to some junk yard to look for them instead of buying them new.
This escape was being driven by my son at around 45mph so he knew it wasn't working properly, but he did not take it on the Interstate and experience the Power loss as you stepped on the gas. A plugged catalytic converter can cause what you are describing, and I would have someone get in it and step on the gas while you check the air pressure coming out the exhaust. You may want to check your good car first to get an idea of what to expect. don't spend too much time breathing in the CO gas though-good luck!
