GMC Jimmy Speakers
99 jimmy am-fm-cd stock unit, both rear speakers quit at same time. anyone know if theres a common circuit to check or what possibly could do that?
My right hand dash speaker quit and I swapped both speakers from left to right and I moved the wiring around a bit, now both speakers work. Either a loose connection or a short in the wiring to the RH speaker was the cause.
While not impossible, the likelyhood of both speakers croaking at the same time is not likely. You could lose the rear channels, however. A cheap but effective trick for checking the wiring and speakers is to pull the radio, and disconnect the speakers from the back. Using a small portable radio, plug into the earphone jack with wire attached and stripped. Then you can connect the wires to each of the speakers and see if you get sound. The little radio will not have enough power to damage the speaker if you connect it backward, and you will know if the speaker and the wiring to it is good.
Shadetree radio diagnostics, 101.
