Infiniti QX4 Shakes Violently
I have an 02 qx4. At certain speeds (45 or above) the car begins to shake/sway/rock back and forth. Sometimes it feels like the vehicle could flip over. I have replaced all the shocks and struts. I inspected for any broken sway bars/bolts etc and nothing seems to be wrong. Has anyone else had a similar issue? If so what is the fix?
Today Midas told me if vibration is like what I described, it is either the tire, or the tire balance, very very unlikely caused by something else. I will rebalance them one more time and see what happens.
I never had this vibration before, at any speed up to ~ 100 MPH.
Did you have it fixed or did you fix it yourself? I'd like to know how difficult it is for a DIY. I am afraid the shop will "find" other problems and I have to pay unnecessary money...
My vibration is only felt on the steering wheel, not a entire car, and it's only a little. Will bad rear bushing affect the steering wheel only?
By the way, Michelin Latitude Tour is so quiet just as Tirerack and Michelin websites states.
Any ideas friends? I really apprecaite you guys and this forum. Could it be a balance, shocks, or front bushings (is there such a part or just rear bushings)?
I also want to mention that my check engine light came on about a month ago and when it would come on, I noticed the car would idle rough, the codes mentioned spoke about a misfire in the coil and another code that mentioned there could be a slew of other stuff needed to be replaced. I am unsure what to do as the dealer said $800 bucks to replace all the ignition coils.
My mechanic also mentioned I needed to get my rack and pinion replaced. I am wondering if the rack and pinion is causing the car to rock from left to right. Either way, I have found the parts on the same website, but my problem is finding a mechanic that knows what he is doing.
Any feedback would be great.
at 155k miles replace #3 coil, oxygen sensor 2bank 2 sensor, 4 new struts and shocks (parts $155 shipping included from a manufacture from Florida) at 175k miles rear control arms lower and upper bushing and fixed the wobbling at lower and higher speed
I hope this info can help
