Can I replace Denali air shocks with gas shocks?
I have a Denali with 101k miles. I am told that my air shocks are bad causing tire cupping. @ 1200+ for just parts, I am wondering if anyone has any experience with replacing the air shocks with an OEM or aftermarket replacement gas shock? I would think the fit would be the same,(as for a standard Yukon 4WD, and just disconnect the air compressor either via the fuse or the harness. Also, would disconnecting the air system cause the ecm to throw a code? Thanks in advance.
Hi... I recently purchased a 2004 Yukon Denali. After purchasing the truck I noticed the rear Air-ride shocks where shot and the compressor didn't seem to run. I researched online and ran upon a Monroe 90012 conversion kit. Figuring I didn't have anything to loose so I purchased the kit. The kit was easy to install even with the Autoride interface modules. That's right NO service suspension displayed on the dash anymore. I tested the factory compressor and found the main power fuse was shot. After replacing the fuse the compressor worked great. The rear shocks even had the same fittings a the factory shocks so connecting them was a dream. The vehicle drives great and levels when loaded. This was a very inexpensive fix at less than $150.00 with new shocks on all 4 corners. Monroe link: http://catalog.monroe.com/catalogPart/monroePartSearchFromECatalog.do?partKey=832527&partNumber=90012&catalogKey=580&methodName=initialiseMonroe&catalogCode=monroe&locale=EN&loadStatus=ACTIVE
