Radio Antenna problem
I have a 2001 Super Crew and recently noticed that when the antenna moves (even in the wind), the radio reception breaks. At first I thought it was merely a problem of a loose antenna, but it didn't stop after tightening it. Is the cable and fender mount accessible behind the mud cover inside the the passenger wheel well? I can see it entering the underside of the fender with the hood open, it is just to small a space to get my hand in to check out the underside of the plastic mount.
Any suggestions or ideas would be greatly appreciated. I really don't want to have to tear into the dash if I don't have to.
Dave
Dave
Thanks a lot for that tip. I will try your suggestions. Presently, I can just flick the antenna with my hand to make the radio break up, so it may well be the antenna itself since I notice that it hits the top of the garage door every time I enter and exit. It could be that it has been whacked one too many times.
Thanks again,
Dave
good luck
Dave
problem?
just curious...Dave
Dave
Thanks for all your help.
Dave
Dave
Dave
Sometimes I forget to press the button and turn it off. (Off light lights up and indicates Off) Am I causing any problems if I forget to turn it off?
