BMW 5-series GT
The specifications on the new 8-speed transmission in the GT says that it is modular, and designed to support all-wheel drive without changes in length, so this is likely to make all-wheel drive available eventually on the GT. Most of the info I've found implies that won't happen until late summer or fall 2010. Most articles are also kind of mute about whether the diesel will ever show up in the USA. Combining both diesel and all-wheel drive is yet another variable into the pot. With the diesel expected to account for 60% of sales outside of the USA, they may not find enough to make it here. But at the equivalent of 40mpg highway (extra-urban cycle) in Europe, I think it would be a great addition here.
Anyone else interested in this combination? Does BMW listen? Anyone heard anything on this?
An 8-Speed automatic transmission? No.
AWD? No again.
I'd like a 5-Series GT with a diesel engine, RWD, and three pedals under the dash.
Best regards,
Shipo
The new GT does some neat things to improve efficiency:
- alternator doesn't charge the battery except on lift off or braking
- (not sure if this is in the US version) automatic grill louvers for faster warmup and aerodynamics
- the transmission is more efficient than the one it replaces by 6% because of lower internal drag. The engine RPM at cruise is really low (7 and 8th are overdrive)
I suppose that different folks have different opinions, however, I MUCH prefer to drive a stick in heavy traffic than an automatic, and I've put my money where my mouth is pretty much every day for the last 32 years (when I bought my first car with a stick). Over that time I've lived in metropolitan areas of (in order) San Diego, Los Angeles, Atlanta, Detroit, Chicago, Cupertino/San Jose, Chicago (again), New York, and now Boston.
"The weight penalty of all-wheel drive and the fuel penalty is worth it if you live in the snowbelt and your driveway rises 30' in a short distance in the winter!"
Hmmm, over the last seven winters we've had four with 100" of snow or more and our driveway is a 9% grade. The only thing I needed to get my RWD BMWs up the driveway, even in the worst of conditions, was a good set of winter tires. No way would I want to saddle a car like a BMW with AWD.
The all-wheel drive versions are due in July 2010. There are no current plans to import the diesel. Too bad; I think more competent diesel choices would improve their acceptance here along with the better environmental impact.
So, I'll check back when the 6-cylinder model arrives, but am disappointed they aren't thinking diesel as well. There's more than economy to those, but they have a poor image here that isn't being helped by a dearth of choices. In this model, the 530dGT is rated at 42mpg on the European extra-urban cycle...an eye opener compared to the 21mpg of the 540GT including a $1000 fuel hog tax bill on purchase. Admittedly, fuel economy isn't always a big driver when buying this class of vehicle, but it certainly doesn't hurt if the negatives aren't onerous.
Here's hoping BMW will bring at least one of these diesels in for this vehicle next model year when the x-versions(all-wheel drive) arrive.
That's one of my problems with the GT. It is a heavy car. The US spec 550i weighs right at 5000 lbs. That's 400 lbs more than a 750i, fer crissake. I can't get my mind around that.
The BMW people at the NYC autoshow in April indicated they were told the diesel would show up in the USA next calendar year. Sooner, rather than later, I hope.
As noted above, they also indicated a diesel version of the GT would come to the USA next year. Anyone have any insight as to whether that includes the x-drive version (my preference, if available) and when? I'd really like a new car by next spring!
The weight is a bit of a stunner. The 535 (w/out x drive) is about 4650 lbs.
Look on the bright side, 550GT w xdrive is about 100 pounds less than a ford crew cab pickup truck! :-) I'd still love a GT. Maybe if I get a hefty raise every 3 months for the next 3 years...
