Mitsubishi Outlander Service Costs
costello1
Member Posts: 60
I got a price on my 30k service for my XLS 4wd V6 Outlander . Can someone tell me if this is a fair price since I don't do any work on my cars myself .
For $399.00 they will do:
oil change and filter , rotate tires ,change air, fuel and PVC valve, flush the tranny and coolant . They said it would take about 4.5 hours to do.
I plan on keeping this unit for at least 2 or more years because of the warranty and I really like the car.
I change my own oil and filter but you could get it done at Quickylube for $25 or so...That with the air filter will cost you $40 tops....$399 is too much at the dealership...You have a 100K warranty on the outtie's drive train so keep the oil and filter changed regulary and change the air filter at AutoZone and you will have no problems getting your Outtie to last..I trade my cars every 100K and I have full confidence attaining that 100K on my '07..
Good Luck
That said, many dealerships & other shops pad the routine intervals with unnecessary items. To the OP, feel free to tell them to do only what Mitsu says is required & refer to your manual to determine what that is.
There is too much appraisal for these young technicians who usually have a boss that controlling time management of their technician. Usually technicians don’t follow repair procedures published in manuals for specific cars. They don’t apply recommended torque to the hundreds of components in the car (bolts, nuts, etc). They just use brute force to torque instead of using a calibrated torque wrench.
In order to service my own cars I had to read some books and the advent of the internet has facilitated my job of servicing my cars and feeling happy after performing the job. Popular Mechanics title: Complete Car Care Manual (ISBN 978-1-58816-723-1) can be ordered from Amazon. This book which is easy to read gives you general procedures for many service tasks. However this book is not car specific. I got 2-CDs for my Outlander GT. The CD (1) called “Service Manual 2010” can be ordered through your local Mitsubishi dealer or online from: www.helminc.com. This CD is for workshop and DIY people. Instructions are clear and need only secondary school background. The CD (2) is related to part numbers of all the components in your Outlander ($30). The diagrams of each component systems are well explained with information of what parts (or components) are re-usable with recommended torque for each part. You may order the disc from Russia at: www.o2epc.com. You may click the part in the diagram and the software returns the part# of that component. With the part number you may indicate to your dealer to order that part for you or you can order online. You may Google with search word “OEM Mitsubishi parts”.
I have done my own service of my Lexus SC300 for more than 10-years. I was forced to do this due to the very high cost to service this car.
I have learnt to do the following services:
1- Engine oil & filter & gasket
2- Cabin air refresher filter
3- Engine air filter
4- Brake service (front & rear)-Order complete kit (shims & clips) not only brake pads
5- Brake fluid bleeding
6- Steering fluid draining & filling
7- Automatic transmission fluid draining & filling
8- Differential fluid draining & filling
9- Coolant draining & filling
10- Wheel rotation
11- Jacking up (using jacking points)
12- Understanding to read elementary electrical diagrams
13- Removal & installation of new lower suspension arms
14- Removal & installation of new shock absorber and springs
15- Using silicone oil/grease to lube all the bushes (e.g. rubber-metal) of suspension components
16- Removal and installing stabilizer bar end links
17- Etc
You need to buy a good set of combination tools (e.g. From Sears or Wal-Mart costing under $100) and also a few torque wrenches
I am pretty old now and I found out that I don’t have the strength to undo some nuts or bolts that may be corroded. In my last job I couldn’t take off a nut from a corroded bolt suspension arm. I called a mobile mechanics/electrician from a telephone directory and he cut the bolt with his crosscut saw. This young man even helped me to torque a component in a difficult area under the car. He just charged me $25 including making the cigarette lighter and radio, of my wife’s small car, operative again.
Mitsubishi garages get their money not because of the sales of cars but by servicing cars. Usually the majority of dealerships charge about $90 per hour. They usually don’t do a careful job. For example, the change of brake pads needs the retracting of the caliper cylinder, so the caliper as a whole can go back to its original position with the new brake pads. Almost all technicians (although the repair manual say don’t do this) loosen the bleeding nipple nut and drain freely an amount of brake fluid. The brake fluid is highly corrosive and spreads out to the rotor disc (front or rear) damaging the silver and new look appearance of your rotor discs. Your car body can have a very new look because of waxing and washing but it is let down by looking onto your wheels which show corroded rotor discs. This is just an example.
