2001 Chevy Astro Van idles rough when stopped in gear. But not in neutral (
2001 Chevy Astro Van idles rough when stopped in gear. But not in neutral (?).
My 2001 Chevy Astro van idles and vibrates rough when braking to come to a stop, and while stopped (in gear).
But if I slip it into neutral it idles out fine(?). I was having problems with my heat. So, I replaced the thermostat, flushed the radiator and added new anti-freeze. This helped to care of the heating problem; And, relieved some of the rough idle symptoms I've been experiencing.
Any ideas as to the possible problem for the remaining rough idle vibrations?
did you figure out what was causing the vibrating? my 98 just started doing the same thing. when im completely stopped with my foot on the brake the idle is really rough while in drive. if i go into neutral or park or reverse the idle smooths out. if i take my foot of the brake pedal while in drive with the emergency brake on(so it wont drive on) the vibrating stops. it only seems to be vibrating while the brake pedal is applied and the transmission is in drive. i would think if it were engine/tranny mounts it would vibrate in reverse too, but it doesnt. wondering if it could be caused by the hydro brake assist system, like a brake booster leaking vacuum??
the way i figured it out: with the engine idling i put my van in reverse and it would stop vibrating, so while holding down the brake pedal i put it in drive and gave it a little gas, that way the induction system had a chance to start working (iac,egr...) without the engine being able to move. it did not vibrate. when it came back to idle. when i took my foot off the brakes and let the engine move the vibrating would start again. that told me the induction system was not the cause but that it was only when the engine "moved". motor mounts or trans mount. got underneath and was able to lift up the driveshaft about and inch and saw the tabs on the transmission mount were both broken.
