Ford Focus Bumps, Rattles & Squeaks
I am looking at a 2005 focus wagon with 133000 miles.Car seems to be in good condition but when it is started it is loud inside the car as if there is an exhaust leak. When standing outside the car there does not seem to be an exhaust leak. The noise is like a rumbling vibration sound. Any idea what the cause could be?
I took it in last week thinking I needed shocks and struts because it would bounce all over the place and sounded like something was getting hung up on another and clanking when I turned. Turned out I had a broken front coil spring. Almost $400 later, that was replaced. When I left it drove much smoother and nicer.
But, when I came to a stop and started to go again, it sounded like the front passenger tire was rubbing on something. And when I start it in the morning, it vibrates a bit, and when I put it in reverse, it vibrates badly. Now, when driving, I can feel a shimmie that seems to be coming from the back and it's running ROUGH. It has to run a while, then gets better. But not great. I thought it was going to die on me when I stopped at a light this morning, it was idling rough.
I drive 700 miles roundtrip every weekend and don't have much money right now for repairs. I'm trying to milk this poor car for everything I can since I don't want to buy a new one to put so many miles on it. Any help you guys can offer is appreciated.
I was wondering if an alignment would help? Replacing the front coil spring, there was no mention on my receipt about an alignment and I'm being told they should have done one and rotated the tires.
The shimmy is still there and everyone I take it to can't seem to find anything wrong. The one dealer I brought it to said they would charge about $300 to look at it but couldn't guarantee they'd find anything.
Does anyone here have any ideas?
Except for high speed wheel balance, ( wheel balance should not be ruled out here as well ), the dynamic aspects (quirks ) of the cars' behavior at speed on the road are difficult to evaluate while the car is sitting still.
I understand your reluctance about committing $300 just to find out, especially with a car this age. I would just take a look at some of the obvious things I mentioned here first.
had all kinds of vibration issues at speed and brake pulse issues.
went to a mechanic and he rebalanced the front 2 tires. vibration reduced but can still feel vibrations at the pants so asked him to balance the 2 rears as well. (even though the mechanic said it was unlikely to cause that). After rebalancing the vibrations are pretty much gone and brake pulse miraculously improved!
i think what it is is that the focus has a pretty tight steering system (little wiggle room), and very wide tires for the car. So any imperfection on the wheel can be easily felt. find a trustworthy mechanic and try rebalance the tires.
I have pulled down on the bottom of the isolators on the radiator with a needle nose pliers and the vibration stops! For a while. These isolators are a dense foam rubber, about 2 inches diameter and two inches tall and look like a large grommet.
On my 02, the noise is bad when it is below freezing but goes away after the car is fully warmed. It is a throbbing vibration that sounds like an exhaust leak or an input manifold leak.
I am hoping it goes away as it warm, but if not think I will try replacing those isolators.
Will need to see how long it lasts but I am optimistic that it might last.
The old isolator did not look bad, but the car sure sounds good.
Did you find a solution to the shimmy while turning right at higher speeds? My daughter's Focus ZX5 does the same thing, and my mechanic can't find a problem.
Let me know if you find the/an answer.
