Ford Fiesta Engine Questions
Has any 2011 Fiesta owner followed the oil life monitoring system yet to decide when to change the oil? According to the maintenance schedule, it can go up to 10,000 miles between changes or one year, which seems like a very long interval than what I'm used to. I always changed my oil every 3 months/3k miles. My Fiesta has about 2.5k miles, and when I checked the oil a week ago, it looked like it wasn't even used, so I imagine I could drive a few k more before the OLM indicates I need to change the oil. I'm curious to hear what other Fiesta owners feel about the OLM system and about the traditional guideline of changing oil every 3 months/3k miles.
I changed out the factory oil at 2k and replaced it with a full synthetic (Mobil 1), and changed that out when the car got to 8k. When the car gets to 16k, I'm going to change the oil again but also send a sample of the used oil to Blackstone for a complete analysis. Based on that I'll decide whether to go up to 10k, down to 6k or leave it at 8k intervals.
Any input on how to modify when that indicator comes on? To change it to every 5K as opposed to every 10K?
I suspected that this OLM system with the Fiesta is not intelligent, especially when I found a YouTube video explaining the difference between the OLM and IOLM (Intelligent Oil Life Monitor) on the more upscale Fords. I would imagine Ford could develop a computer software patch (or flash update, whatever they call it) to reprogram the "unintelligent" OLM light in the Fiesta to turn on in 5k intervals. I'm currently at 3.2k, and it's been so hot here in NY that I may have to change before the 5k. I will most certainly check my oil this weekend for degradation!! :sick:
Checked and okay." I actually had to take my Fiesta back to have a metal interior accessory kit installed (metal door sill plates and leather/metal gear shift knob-5 speed). That was at 450 miles. How does a battery exhibit "light wear" at that low mileage?
That has nothing to do with Ford. That notice strictly comes from your dealer. Your dealer makes twice as much money by having you come in every 5k.
To reset the OLMS: Turn your car key to the on position, without starting the car. Hold down the brakes and accelerator for 20+ seconds.
The manual says to do that in the accessory position, and that doesn't work.
I will now continue to change it at 8k intervals. I'm using Mobil1 5w-20 and Fords filter.
For the cost of an oil change, anyone can have their oil analyzed and know just how far they can drive between oil changes.
Guessing is for amateurs.
As long as you keep your parameters the same (same type of oil, grade, etc), a group of three analyses (while costing about the same as an oil change) will help you determine the best interval for your vehicle. Once you've established a baseline, you don't need to continue the analyses unless something changes.
That way, you're not guessing at the intervals, wasting oil, or potentially damaging the engine.
That sounds like a great idea. Who did you send your oil to for analysis? My Fiesta is a 5 speed manual and it runs 3100 rpm at 70MPH and I heard the 6 speed auto is only at 2600 rpm @ 70MPH so I might need to change my oil sooner than you
I'm sure there are other places that do oil analysis but most people and businesses seem to use Blackstone. They will send you a sample container for you to use and mail back to them. They charge $25 for a basic analysis but I would really recommend paying the extra $10 for a TBN count.
Read over their site so you understand what numbers are important. It wouldn't hurt to vist "Bob's the Oil Guy" web site and read a few of the discussions there too.
Every 150,000 miles (240,000 km):
*Change automatic transmission fluid and filter (filter not required on 6F35, 6F50, DPS6 and AWF-21 transmissions); consult dealer for requirements
*Change manual transmission fluid
*Change rear axle fluid (RWD vehicles)
*Replace accessory drive belt(s) if not replaced within the last 100,000 miles (160,000 km)
*Replace timing belt (Fiesta); failure to replace belt can cause internal engine damage
I think I should go to the dealer's parts dept and have them look it up. But like you say, I'm 99% positive that it's a belt, not a chain. Anything technical that comes from a salesman is questionable.
Hahah; words to live by!
My Fiesta only has 16,000 miles, so I'm a long ways from knowing for sure which it is. If it were a chain, I doubt it would be on the maintenance schedule at all.
