Replace tires on 1999 Forester
bluefireangel
Member Posts: 5
in Subaru
I have a '99 Forester L with the standard 205 60R15 tires that need to be replaced soon. I have a set of 225 70R15 tires available to me. I know that they are overall larger than the original. My question is, even though they are larger, since they are all the same size relative to each other, can I use them as replacements for the old 205 60R15?
225/70 is a *LOT* bigger than 205/60, but I think you may have the original size incorrect.
Comparing 225/70 to 205/70, you have a tire that is 20mm wider, almost an inch. My concern would be rubbing the base of the rear spring mount on the back tires, and maybe even the fronts at full steering lock.
Are the 225s mounted on rims that you could use, or would you have to pay to have them mounted? I'm wondering if you can test fit without any expense.
Even though they will fit on the rims, they are more than likely just too big for the car in stock form. On the plus side, if you did squeeze them in there, you would have quite a bit more ground clearance!
I know that the spedometer and odometer would be off. What I'm more concerned with is the AWD. Will I mess up the AWD or something else by using the 225 tires?
Don't bother to go any further. This is a terrible idea.
