97 Deville - rough idle no codes
My '97 Deville has developed a rough idle recently. RPM varies between 625 - 700. DIC shows no codes. Seems to run fine other than idle. Gas mileage is about the same as always 25 - 27 mpg on highway. It has about 185,000 miles on the clock. Might use about a quart of oil per 5000 miles. Does anyone have ideas what might be causing the idle problem.
At this age and mileage, plug wires could also be failing. I'm assuming the plugs have been changed? The mileage for plugs is 100,000 miles.
There is a big rubber boot (cylinder) between the air cleaner and the intake. (Maybe between a MAP sensor and the intake?) When shut down, the unburned gas, etc from the intake condense out in this tube and over time in older Cadillac will rot a hole in the bottom. This screws up the air/fuel mixture. Just reach down there and poke around. If it has a hole, or even especially 'soggy' feeling, it might be pulling in additional air, causing a miss.
You put the stock AC plugs in, didn't you? If you used some multi-prong non-AC plugs, the Northstar might not like this.
And yes, I did use stock A/C plugs. Thanks for your suggestion!
I would look at the wires again. If they were recently changed, there might be a loose one...
