Chevy Silverado/GMC Sierra - Owners hangout
Any Ideas?
I agree with you it is not fuel. It has to be once the fuel has entered the motor.
Will the 2004 Z71 Crew Cab be built on a 1/2 ton frame or a 3/4 ton? Will it be a true Z71 as we know it today(suspension, frame, etc.) just with 4 doors or will there be some more heavy duty trailering stuff added to itlike the 1500HD?
There is no timing adjustment avaiable unless reprogramming. For that you would need a tech2 and usually only a dealer would pay the $3k for it.
the 1500HD CC is now called a reg 2500 i believe
Ryan...didn't your dads old truck have a bad cat. a while back?
We changed out the plugs,wires,& fuel filter..
The P/U is missing,and will die at times..What could be wrong with it??My check engine light comes on occasionally..It was tested and said it was mis-firing..This just started coming on..Any ideas??
http://home.att.net/~m.prendergast-alliedsignal/silverado_fuelfil- ter.html
they run about $15 (ac delco)
Tom
How stripped down can it be? They all have AT..right? How about AC? past that, I can't imagine needing much more for a work truck.
Am I missing something here?
ALL for reg cab: Note excab rates reduced guide sez to see GM dealer.
Gross combo weight ratings ( this includes truck, cargo and trailer.
GCWR 1500 reg cab with either Z-85, Z-X3, or Z-71
options.
4300 auto: 3:08 9000 lbs.-3:42 9500 lbs.-3:73 10,00 lbs. NOTE this is for BOTH truck, trailer & cargo ! Stick is 1000 lbs. less.
BALL HITCH 5000 lb. trailer with 600 lb tongue
weight. NOTE: Weight Dist hitch required with sway control required for trailer over 5000 lbs.
NOTE all reg cabs listed below also. All also require either z-85,z-x3, or z-71 option.
2wd 1500 Trailer weight 4900 lbs., 3:08 axle
5400 lbs., 3:42
5900 lbs., 3:73
4wd 1500 5100 lbs., 3:42
5600 lbs., 3:73
These are for 4.3, auto. trans. reg cab only.
Stick trans. reduce by 1000 lbs.
Ex-cabs cap. is reduced even further. Book sez see GM dealer. Hope this helps.............geo
I did notice that if you go to the search engine Dogpile and simply type in "5.3 rough idle" you will get several listings describing this problem but no answers. I do know that with my truck I usually only have this problem with the AC on. If the compressor is off it usually idles just fine.
Jim
I am considering buying a short 5th wheel (ie 24-26ft.) and tow a triple with my 21 ft boat behind the trailer.
I am wondering if anyone has experience towing a triple of similar and what things I should consider before I buy the 5th wheel.
I know the truck will handle the weight fine, I expect total weight of trailer and boat to be between 10.5 to 12K lbs. The truck was used to tow a 11K 5th wheel and did fine.
I am more worried about overall length, sway at highway speeds, weight distribution, etc. Any input would be nice.
http://www.freetrip.com/rules_fr1.html
Jim
7400, xcab, 4 wd...Must have RPO-KC4 engine oil cooler... total GCWR (total weight of trailer(s),
truck, cargo and passengers.
3:42-13,500 lbs., 3:73-15,000 lbs., 4:10-17,000 lbs., 4:56-19,000 lbs.
Sonja- thanks, I have the oil cooler, and 4:10 axles, but 17,000lbs GCVWR still puts me on the edge.
Does anyone know the approx curb weight of my vehicle? I would guess 6500#. That would only leave me 10,500 for trailers and gear.
EDIT: Cat...checking another page today
xcab longbox 3500 4x4.......GVWR 10,000 lbs.
Book sez: Gross vehicle weight rating includes vehicle, passengers,equip., and cargo. All GVWRs of 10,000 lbs or higher require dual rear wheels.
Confused? Me too.
What does your registration say for weight of truck?
http://www.edmunds.com/townhall/chat/townhallchat.html
6-7pm PT/9-10pm ET. Pop in for live chat with other members. Hope you can join us!
kirstie_h
MODERATOR /ADMINISTRATOR
Share your vehicle reviews
Dealerships are independent of manufacturers meaning that you could get a bad one no matter what brand you purchase.
However, if I was buying a new truck right now, I'd get the GMC because I hate the way the new Silverado front end looks.
I wonder if that makes a difference when GM is assemblying the truck....do they do a more thorough job knowing someone ordered it, or do they even know?
We only know whether a vehicle is sold by a sticker on the windshield and that's only applied late in the build process. The sticker signifies that any defect/problems be attended to immediately prior to shipment rather than relegating the vehicle to the yard for repairs. Another point I'd like to make is if you're not satisfied with your vehicle then badger, harass, and make your dealer cringe when he sees you and if you're not happy take the problem to divisional headquarters. GM hates bad press on small issues and writes off major issues as normal(ie:engine knock) And finally, remember timing is important when purchasing a new vehicle. We have several hundred students working here during the summer(May to Labor Day) and most are too afraid to report a defect or wouldn't know one to see one. They are lucky to get an hours training before being left alone. Sorry for the long post...but I take my job seriously.
Chuck
Then carry on about the "global economy".
I have yet to see a low paid 3rd world worker buying a new $35k GM truck.
My mom and uncle worked for GM for years and were lucky to get out early with a golden parachute at 55. I know the BS they put up with !
Keep up the good work!..............geo
Keep up the good work. Many of us appreciate workers like you.
