I'll let you know if I find out anything as well.
The squeak you describe I also have, and it's in the latch. If I cut about an inch off a straw and slit it such that I can slide it on the metal latch, it takes care of that squeak.
I hear this sound periodically, but it is most noticed when the windows are open. Try it, and I think you may find that the sound is really LOUD outside the vehicle. To me is sounds like something in the suspension, but I have not had it checked out. It is very sporadic on my 2008 AWD.
Even after everything is turned off, I sometimes hear it. And then sometimes I don't hear anything at all regardless if the AC is on or not. :confuse:
I had thought it was the CD skipping from the Navigation system but am not too sure anymore.
Any recommendations will be great!
Despite temperatures as low as -33F this year (even colder in past years), the only creaking or squeaking I hear is from my own aging body.
thanks,
josh
p.s. after reading some of the dialogue between the dealer and ford they suspect the PTU? and they also said that if they command the rear end anywhere from 0% to 20% the noise goes away... but if above that the noise is back... and when they command it to 100% then the noise in there both in reverse and in forward....
*Hotline Assistance Request*
*VIN: *1FMCU59H57KB89844**
*Vehicle: *2007 ESCAPE HYBRID**
*RO Number: *105788**
*Contact ID: *104295570**
*Request Date: *01-13-2011**
*Technician: *andrew g*******
*Request Form Details:*
*Description of vehicle concern:*
thump noise rear on take off in reverse
*Diagnostics performed:*
checked suspension and driveline
*Parts replaced:*
none
*Tech's question:*
any known concerns? I removed the rear driveshaft and road tested. The noise was gone with driveshaft removed.
*Hotline response:*
Andrew,
With the noise present, recommend swapping a known good driveshaft with the current driveshaft in the vehicle and re-evaluate. If a like vehicle is available, swap the driveshaft out of that vehicle for testing.
If the noise is still present with a known good driveshaft, suspect a possible issue with the ITCC (Intelligent Torque Control Coupling). To verify that the concern is not a PTU issue, with the vehicle on a hoist, command the rear coupling to 100%. Then, with the vehicle running, place the shifter into the drive position and verify that the front wheels are still and that the driveshaft is not spinning. If the driveshaft is spinning, suspect the coupling as the cause of the concern. If the front wheels are spinning but the driveshaft is still, suspect the PTU as the cause of the concern.
If further assistance is required, update this form and resubmit. Thank you.
*Additional Diag/Comments
*Comment from: *technician *Comment Date:* 1/13/2011 5:03:20 PM
Performed test. Commanded coupling to 100%. Front wheels and driveshaft were still with footbrake on. With footbrake off, wheels and driveshaft were spinning. With coupling commanded to 0% and footbrake off, driveshaft was spinning but binding/catching. Any further assistance or comments on findings would be appreciated.
*Comment from: *Hotline *Comment Date:* 1/13/2011 5:07:18 PM
Andrew,
With all four wheels spinning, and the coupler commanded to 100 percent, apply the parking brake. In theory, this should stop all 4 wheels. If it does not, and the rear driveshaft stops spinning, but the front wheels continue to spin, replace the PTU. If further assistance is required, please feel free to call in to discuss. Thank you.
*Comment from: *technician *Comment Date:* 1/20/2011 12:10:17 PM
Im still chasing this one. Ive had chassis ears all over the place. Cant source the noise. If I command the rear coupler from anywhere between 0 and 20% the thump noise goes away. If I go over that the noise returns at all percentages up to 100. At 100 the noise happens forward and reverse. Does this indicate anything in particular or is it normal?
*Comment from: *Hotline *Comment Date:* 1/20/2011 12:17:20 PM
Andrew,
The noise could be normal, but it would be best to verify by comparing to an identical vehicle. If the noise is unacceptable, at this point, it would be recommended to replace the rear axle unit and re evaluate.
*Comment from: *technician *Comment Date:* 1/20/2011 1:02:59 PM
Ive been waiting for another like vehicle to come in but no luck. I tried a V6 4WD that did not make the noise. Thats been the closest I could get. Thanks for the help. I will stay in contact on this one
*Comment from: *Hotline *Comment Date:* 1/20/2011 1:19:53 PM
Andrew,
At this point, if commanding the rear axle percentage up and down seems to influence the noise and the noise is greatest from the rear axle assembly, replace the rear axle unit and re-evaluate the concern after the repair. Thank you.
*Comment from: *technician *Comment Date:* 2/2/2011 11:35:18 AM
REPLACED REAR AXLE UNIT AND CONCERN IS STILL THERE. STILL HAVE NOT HAD A LIKE UNIT COME IN FOR SERVICE. 30 DAY TIME LIMIT FOR WARRANTY CLAIM GETTING CLOSE....
*Comment from: *Hotline *Comment Date:* 2/2/2011 11:46:41 AM
Andrew,
Please measure the circumference of all four tires, as they should be within 1/2" of eachother.
Also, Please verify that when the vehicle is on a hoist, the rear axle is commanded to 100%, the parking brake is firmly set and the vehicle is placed in drive that all four wheels remain stationary.
If the driveshaft is spinning and the front wheels are spinning, but the rear wheels are stopped, suspect a rear axle concern. If the front wheels are spinning but the driveshaft is stopped, suspect a concern with the PTU. If all four wheels are stopped, the PTU and the rear axle should be functioning properly.
Please update this form with the information required or call in and have all test information available for review. Thank You.
*Comment from: *technician *Comment Date:* 2/2/2011 6:20:06 PM
all recommended diag has been performed and rear axle unit has been replaced. the concern is still present
*Comment from: *Hotline *Comment Date:* 2/2/2011 6:41:23 PM
Andrew,
Please contact the Technical Hotline by phone to review this concern. Use CONTACTID 104295570 Please have the results of the diagnosis already performed to discuss in greater detail. Thank You.
Additional comments or diagnostic info
You have *950* characters remaining for your response...
*Call Log:*
*Calls to hotline for this vehicle:
*1/13/2011 5:24:00 PM - Tech said:*
Noise is not present with drive shaft removed. Noise is present with a different rear shaft.
*1/13/2011 5:24:00 PM - Hotline recommended:*
Andrew,
Command the rear duty to 100% and then road test for the noise. Install chassis ears to the PTU, rear suspension and coupler and then retest for the noise concern.
*2/3/2011 1:49:00 PM - Tech said:*
After further inspection, technician is unable to identify any obvious fault with the system that would account for the noise being produced. Seeking direction on the diagnosis of this vehicle.
*2/3/2011 1:49:00 PM - Hotline recommended:*
Andrew,
If you have a like vehicle available on the lot (an AWD gas model would have the same AWD components), recommend comparing the noise to see if this is a possible characteristic. If you find that the noise is not normal, further inspection of the command and input PIDs will be required. If you have any other questions or if you would like further assistance, please recontact the hotline. Thank you.
Does anyone know what is causing this ticking?
By the way, I've had real :shades: good luck with my 2005 Ford Escape hybrid. Hopefully it will last to 300,000 miles like those used for NYC taxis:-)
I have a similar sounding chirp / squeak in the front passenger side of my 2009 Ford Escape Hybrid. It seems like it is coming from the a/c system that is under the dash on the front passenger seat.
Is this the area where your chirp sound was coming from? I have taken the car to my dealer but they always say they cannot identify the sound. Can you help explain your straw solution further for me? This sound is very annoying and irritating. Thank you very much.
RW
I'm not sure if it's really a serious thing though. I had mine fixed, and about a year later it started doing it again.
It is the brake system charging up. The sound is normal for pre-2009 models.
I have more options on mine, but all the 2008 FEH have the same mechanical components. Mine does not sound like that. Maybe you have some kind of air leak in the engine? Try having someone gun the engine while you listen with the hood up.
I suggest taking it to Ford for repairs BTW; these hybrids really need specific expertise.
I hope your warranty is an ESP plan from Ford?
