Ford Windstar Problems
It has a 3.8L engine with 145,000 miles - many of those were highway miles. An oxygen sensor was replaced in December per a scan tool reading, but the SES (service engine soon) light still comes on occasionally. The ABS light is on, but that may be due to something that happened when the brakes were serviced. Last week the transmission started to slip a bit when accelarating from a stop. Last fall it was also slowly loosing coolant. Never saw any on the ground, never smelled it, and the mechanic pressure tested the system and never found a leak. Nevertheless, the coolant level would drop. Three months ago the mechanic added some sealer to the cooling system, and since then the coolant level has held steady.
Does this sound like it's time to get a new van? It seems that way to me, which is too bad because I actually like the Windstar.
Nina
Now I am unable to reconnect it. I can push it in most of the way but not far enough to cause it to firmly attach to the notch. With a little shaking the connector just comes loose. I've tried to exert force to bring the 2 connectors parts together but this doesnt work.
I cant find any reference to this wiring connector in the Chilton manual and dont know how to attach it again.
Any Suggestions/ideas?
$4000 sounds like way to much to pay for an 11 year old vehicle to begin with. The bearings may have been damaged from coolant having gotten into the engine at some time in the past due to leaking head gasket. I think 95s had a lot of head gasket problems.
A rebuilt engine would be a little less, maybe around $3000, but that is probably still more than the vehicle is worth.
You could take a chance on getting a used engine installed, to try to salvage something out of this...without spending more than the thing is worth.
Yes, we did pay to much for it, I don't deny that. Call me a fool--because I am.
Thanks for your input, I appreciate it.
The engine had all the gaskets replaced along with the spark plugs, water pump, thermostat, cam position sensor, ECR valve, ECM all in the past year. I recently took it for Illinois Emissions and it passed.
So my problem began last night when I drove it to the store it ran fine. I was in the store for nearly an hour and when I came back out I started it as normal and it was missing and ran like crap. The check engine light was on and I smelled gas. So I drove it straight home and every time I would try to excel it seemed to shutter. Especially at 40MPH. So I tried to pay attention to the tach and at 2000 RPM is when I would feel it. I checked the spark plug wires and those MAY need replacing but no obvious burns or grounding. Checked PCV valve and it may need replacing. MAF sensor doesn't show any obvious problems. VCacuum hoses look fine.
I disconnected the neg battery cable and now the check engine light is off but the van runs bad and the exhaust odor is strong.
Any ideas? I mean other than running it into a brick wall and buying a Chevy.
This particular van has some serious issues and the only reason I bought mine was because they had complete service records for it and most of the Ford parts that go bad on the 95's have been replaced with custom parts.
So I'm starting at the bottom with the latest problem and replacing the plugs and wires. If that doesn't fix it then I will check the coil and so on. Anyone with other ideas? :lemon:
Please Help! Thanks!
I think the tranny is acting up again too. Some red fluid under the van and shudder during shift changes in overdrive that stop when I take it out of overdrive.
Just recently got rid of a 1999 windstar (purchased new, driven easy) with a long list of major problems than one could imagine, all just after the warrentee period. The car was assembled properly, and was very nice for the first 38K, then the heaterbox air door broke, then the transmission blew, then the cruise control quit, the interior lights started flashing on and off (not a door problem-the dash light wasn't comming on), engine stalling and rough idle due to a bad air servo, the radio scan stopped working, leaking fuel injectors causing the emmissions light to come on and causing hard starting, leaking brake fluid from a defective sensor, bad ball joints and growling power steering. At 53K, yes only 53,000, I'd totally had it with this peice of junk and drove it straight to the Chevy dealership and traded it in. (no way could I sell it on the open market with a clean conscience like I usually do). There used to be 5 Ford mini-vans on our street, including ours, and now there are none. Everybody had engine and drivetrain issues with these things. Stay away from the Ford Junkstars!
I still have not figured out what's wrong with mine. I'm about to take it in for diagnostics. :lemon:
NLYNN
NLYNN
Drives fine in the city except for engine light now and then due to lean bank one or two.
Still leaking trans fluid too since last attempt of shop. cycling this week to work.
Andy idea's???
Kees.
Lean bank 1 and 2 is usually a bad MAF sensor and very easy for even a woman with no car knowledge to replace.
And for all you great people out there.... I am a 32 year old single mom. I have male friends that come to me for car advice. I was fed up with paying mechanics to take advantage of me and decided to empower myself. With reading and research you can learn just about anything. With a manual you can usually firgure the rest out.
With that said, go for 2nd and 3rd opinions before you pay someone to fix it. Do the research and se what the other options are and how much someone else is charging for the same job. Don't be taken for a ride by Ford unless you're test driving a new vehicle. If that's the case I suggest you swing by the Chevy dealer.
