Hyundai Azera Transmission
Also there's an earlier thread, Hyundai Azera Transmission:
pat, "Hyundai Azera Transmission" #1, 18 Aug 2006 4:00 am
Although the Azera has an adaptive transmission which "learns" your driving habits and changes shift patterns based on your actual driving, the tech at my local dealership claims that the adaptive pattern cannot be zeroed out.
I am not positive that he is correct, although he claims that he checked this out with Hyundai engineering.
I think the transmission lag is something we may all have to learn to adjust to along with the drive by wire. We are all accustomed to things being mechanical and throttling up was instataneous. With drive by wire there is an accelaration lag. There is also a minor transmission lag with these adaptive learning trannies but in the long run we pick up a little MPG. I do notice going up one particular long incline after leaving my house that I have to accelarate harder to get the car to shift into overdrive. I experience that same thing with my 99 Jeep Cherokee. Of course, my wife drives the Azera more than me.
Has anyone found out if the transmission adaptive memory can be zeroed out by dealer? Mine claims that it cannot.
The shifts still have a brief delay under WOT, but not nearly the 1 or 2 seconds of nothing with the original programming. Around town, the delay is barely noticeable since the reprogramming & memory flush.
I'll keep that in mind and try that same hill with a warm engine and transmission. Thanks for the thought.
If you want the AT to be more responsive, just:
(1) At over 50 mph, slap the gas pedal to the floor and back as quickly as possible about 10 times in a row.
(2) Do this so quickly that the AT does NOT have a chance to downshift.
(3) After too much gentle driving, the AT will slowly become less and less responsive. When it does, repeat steps (1) and (2)!!
I have found that this procedure works great on my Dodge Magnum and my Azera, and should work equally well on any newer car with an adaptive AT.
PS: My old '91 Jeep Cherokee had a toogle switch on the dash to choose between performance or economy AT shifting. This new fancy adaptive shifting is another example of a computer doing what it thinks you want, rather than what you may really want!
I normally drive smoothly, but when it is time to GO, I want to GO! At times I can almost visualize my AT's computer scratching it's little head trying to decide if it wants to do what I ask!!
am i right or wrong?
My 07 Azera (600 miles) seems to do the same thing. It can be a little bit disconcerting. Is this the adaptive learning others were mentioning?
It apparently is designed to hold higher gears for better fuel economy. I have had similar problems when merging onto the freeway. The fix for me has been to use the autoshift feature in that situation and drop down a couple gears manually, then go back to auto when the merge is complete.
I don't feel this should be necessary, but it is.
As far as others saying that I need to " hotrod " the car for awhile to teach it to downshift more readily - no thanks, I'll just try to anticipate needing a downshift and do it manually.
Good thinking!
Since then, I've tried moving it into manual shifting and changing gears. The tranny still seems to float before making the shift from 1st into 2nd. Anybody have any thoughts?
You are both right and wrong, sort of!
If you are facing uphill and wish for your Azera to not roll backwards, simply use the
SHIFTRONIC feature and manually shift into "2" and release the brakes, and
you will feel the car start to move backwards, and then stop rather abruptly.
Works like a charm.
Don't forget to manually downshift back to "1" when you want to start uphill unless the incline is not
too steep. You'll be able to tell if you need to go down to "1" when your car seems to be straining.
It takes a fairly steep incline to make our cars strain when starting off from rest in second gear.
I do start most of the time this way because I think it helps a little with fuel economy.
That's unless some young hot-rodder thinks he's got a fast car.
I don't think this applies when your car is facing downhill.
So you do have a "keep if from rolling backwards hill holder" if you want to
go to and use the SHIFTRONIC feature. Kind of slick don't you agree?
NOW, if only some computer type would figure out how to program
the tranny computer so it could be manually upshifted earlier.
It seems like a lot of work to me since all cars come with these great hill holders for both up and down hill.
They are called brakes.
"There is a TSB to address this. The # is: 07-40-002. It was issued in February 2007.
It covers a slow 1 - 2 shift under WOT (Wide Open Throttle.)"
I would love to read 07-40-002, but I cannot get that TSB to come up!
How to do so? :confuse:
Thanks in advance.
I brought it to the dealer to check it out. Basically they confirmed the issue checked for an update for the ECU(there wasn't one) and told me that they put in a case for it with Hyundai, but there was nothing they could do and that it wouldn't hurt the car.
My question is: Does anyone have any idea what is going on? It really seems like an electrical or, more likely, an electronic issue. Most likely the computer, but i suppose it could be the engine itself or transmission.
And second, what should I do about it? It's really frustrating to have a brand new car with such an annoying issue.
First of all, don't believe for a moment they will. File your case direct with Fountain Valley, CA and get a case #. Send a registered letter to the owner of the dealership with copy to Fountain Valley outlining the problem and requesting a factory representative to meet you at the service department to inspect and drive your vehicle. If they ask you to leave your vehicle demand a suitable loaner.
Hyundai and many of their dealers take great delight in stone-walling issues such as yours. Good luck.
but I suppose it could be the engine itself or transmission."
Mine does that also, and I think it is in the TCU soft ware, and not the engine.
The T/C seems to be locking and then unlocking, back and
forth, as if is does not know what to do. Most annoying.
Mine will do the exact same thing with the cruise control engaged when going
down a grade. This is not normal when compared to other vehicles.
Sounds like front tires are out of balance.
-Transmission, on the test drive I noticed the transmission lag from 1-2, even took the manager for a ride and showed it to him. Didn't purchase that one but purchased another one. Forgot to mention, this is my wifes care. We went from a Avalon to this by the way. Anyway, when I drive it, I notice it shifts differently from new.. Someone mentioned TSB's going to check on that.
-Maybe I should start a new topic, but thought I would start here. My wife called me about an hour ago, I couldn't answer, on Jury duty. But anyway, she couldn't get it into park. The engine was running, foot on brake. She was able to shut the engine off and start up ( in neutral) again and that didn't solve the probem. Eventually she was abale to do it. This is the second time for her. I was thinking user issue, but before I touch that, anyone else have this problem/
My confusion is that the owner's manual for my 07 Azera Limited says that the mirrors tilt down in reverse if the mirror selector switch is left in the "L" position. No they don't. Dealer expresses complete mystification and does nothing.
To pour salt in the wound, the '07 Kia Sedona van which I rented from Enterprise a few months ago claimed exactly the same feature in its owner's manual, and yet did nothing of the sort.
Any clues about this?
In addition, are to able to advise me about how to activiate the "exit" memory feature, and/or get power to the memory switches without the key being in?
Many thanks.
