Audi TT Transmission Problems
Not sure if this has been discussed already but...
Can someone please explain to me exactly how do paddle shifts work? It seems like a few models are having them these days (Audi TT, Ferrari, Aston Martin and RX-8)
First off, there is no clutch correct? ., so how does one knows when to shift, just let go of the gas and quickly shift the right-hand side pedal and press the gas again?
Drumm
Drumm
Ken
I have a 2001 TT Coupe 185, love it otherwise, plan to keep it. I'm hoping to have better luck than most, I guess. I see a lot of them on the road, not like the mazda Miata where you see most of them on the resale lot! :sick:
Is the clutch really that delicate? Or should I take refresher on proper clutching technique? :P
In addition, ONLY WHEN IT'S COLD, my clutch pedal will rise extremely slowly after being pressed. To top it off, my car does emit a faint burning smell once it's warm and shifting well.
This problem has been looked at by two dealers. One states no problems, the other states my vehicle needs a new clutch and slave cylinder. I'm hesitant to believe the latter. This isn't behaving like a clutch and given the high pricetag of this repair, (quoted between 3-4K), I'm hesitant to go ahead and fix it.
I should note that once warm, there is no problem shifting this vehicle. No gear slipping. Nothing.
HAS ANYONE ENCOUNTERED THIS OR DOES ANYONE HAVE SUGGESTIONS? THANKS IN ADVANCE.
Audi dealer claims that the car needs a new clutch. His estimate: 2.5 K - bummer :mad: !
Going by the symptoms though, I tend to believe that it is "only" the slave cylinder.
Have you by any chance got your problem fixed and can you help me w/some advice?
Anyways, the service writer said 'it's carbon in the injectors' so tracked down Marvel mystery oil. Injector cleaner doing nothing. Called the service manager...he wants the car right away. Is this the same as the 'bunny hop' others mentioned? What's causing it?
I brought it in for service and Audi gave me a cheapo A4 to tool around in. I waited for the parts to come from Germany for almost a week.
Cost to me - 0 dollars.
However! It was a leased car and I made my last payment in March. I just leased a 2006 Metallic Silver BMW Z4 3.0si.
No turbo lag
No tranny problems
No latch to pull down to close the ragtop
6 speed shifts like a hot knife in butter
255HP is really fast
The car sounds like a F1 race car!
No baseball interior
No quattro
I'm really happy with my Z4
No TT for 2006?!
NYBULLY
Do you own or lease? Especially if you own, keep the service records.
You may want to get the car checked by another Audi dealer.
Are you guys STILL on this TT tranny gig? Guys, I am so glad that I didn't buy the TT after the lease was completed.
I drove my 2006 BMW Z4 si 3.0, 6 speed silver bullet to Tampa Florida and back. This car held up really nicely! To date, I've spent 0.0 dollars on repairs.
This car has NEVER seen the BMW shop except to change the oil and NY inspection.
The new TT? It looks like a frog next to the Z4 AND they raised the price.
BMW baby!!!! :shades:
Well... this is the Audi TT Transmission topic, so...
On the other hand, this isn't the Z4 topic, which may be why you're not getting any responses. You might get a better reception here:
BMW Z4
Many thanks in advance for any advice you can give me.
So the deal, they will save me $4000 by not putting a new transmission in. The rebuilt transmission and a new clutch (expected at 80,000 miles) will cost $5660. My 80,000 mile service last year cost $2200. I can no longer afford this fun car and will sell it before the next shoe falls. Should have done sooner when warrantee ended.
i opted to replace the transmission; i already had to pay the labor cost to get to the master cylinder anyway, so now i have a new transmission.
Sometime, in a quick acceleration the car does not move.... I can press the gas pedal, the rpm will go up to 4000rpm and the car will accelerate to 40 miles/hours. Lately the car didn't even move.... :sick:
Did you get any info on the problem what's causing it and can it be fix? Thanks
out with urs..plz let me know..thanks
2001 TT Quattro convertible
A $5500 mistake, for private rebuilt. Factory rebuilt about $1000 more.
These cars are poorly built garbage, and especially the transmissions and some of the electronics. It took about six tries to fix the window switch.
Yes, Audi should take care of the bad transmissions, but that's about as likely as the Great Pumpkin visiting Linus later this month.
I took it to my mechanic and nothing shows up on his diagnostic test. He thought it could be the engine mounts or the shift solenoids. He took a look at the engine mounts and that wasn't an issue. The shift solenoids would take too much time to get into for a maybe.
He suggested to keep driving until I see an engine check light come on so that there is more definite information. I prowled the net and found someone having an issue with the shift solenoid as well, but his problem may not be exactly mine.
Anyone have any idea what could be the problem?
Better have $6000 or so ready for when your dog of a transmission goes out. It might just be the solenoids, but is more likely ready to crash totally.
Have your tow policy ready. My Audi was being used by my nephew for homecoming when the transmission decided to give up the ghost.
any ideas?
Theoretically you should be able to drive in some of the gears.
Fell in love instantly, car amazing, smooth butter like shifts with the DSG
trans...took it to a local independent shop (no local Audi dealer) to have the
dsg fluid and filter changed as paperwork didnt verify that the service previously done.
Two days after back, went to leave work, key turns everything on, but no crank of engine, and "service" indicated on dash, came back next am and key in everything fine, starts runs great, shifts great, two miles down road, trans goes into what seems like false neutral, pull over no reverse or other gears engage, turned of ignition and again no
crank and service light, scanner shows 1 logged code, U0101 lost comm with
TCM......get it towed to independent shop...next day start runs and drives fine, then out
of blue does it again at shop, no crank and u0101
Also should mention on two occassions key in ignition tumbler rotated freely with no action, rotated around abit then key and switch worked properly...
so dead in water at independent shop, not knowing if ignition switch can play into the u0101 or if im looking at a Mechatronic Unit or ?
Any help appreciated
-Reed
I bought the car yesterday and have put over 300 miles on it and can't wait to get back in for more!
Did you ever get to the bottom of this problem.. my TT 3.2 auto has just started doing exactly the same..
occasionally (not all the time, but just at the wrong time) it will drop out of gear, the dashboard gear indicator will start to flash and you can get any forward gear.
If you turn the engine off and on a few dozen times (with associated failed gear selection), eventually you'll get some synchronization and you're able to go.
Can't figure out whether its a software or synchronization belt/ gear teeth issue ?
Blocked the road today when it happened at just the wrong time on a busy narrow stretch
