Honda Accord Engine Break-in and First Oil Change Questions
Saddle soap works great, and it's cheap too. I found some at the local feed store for $500/can.
Dang, Elroy.... $500 for a can of saddle soap IS cheap. So how about letting me be the exclusive supplier for all your car care needs? I'll even give you a 50% discount on your next can!
I would just stick to manual's recommendation and the maintenance reminder in the speed odometer.
It is true that Honda puts additives in the break-in oil and changing it too soon defeats the purpose. I no longer follow the 3000k rule after everything I've read. But the choice is up to each individual.
Apparantly Honda knows what they're doing with their recommendation of a late first oil change. I probably changed mine too soon!
Happy motoring.
Thegrad
hmm, Honda designed the reminder to tell you when the best time to change the oil without damaging the motor but yet you won't listen to Honda but you want us to tell you when to change it. I think Honda would know better than us. I guess it is true you can't make it to simple for some people.
I check the manual and it says to change the oil at 0%. very miss leading information. If I was someone who had no knowledge of cars, I would have destroyed my engine waiting for the 0%.
I owned Buick Regals for the past 12 yr's, but I just didn't like the new Buick. I like the Honda, It's a nice car. I have the navagator and the XM radio which I like. I'll have to keep a close watch on this oil change to see if it improves.
I really like castrol syntec motor oil. what do you like??
The new cars usually short change you. I also noticed that the fulid in my transmission was not full neither.
After putting in 3.9 quarts, a new filter and running it for a few minutes to see the "oil can" indicator go away - oil pressure? - I selected the "oil life" display; it said "30%" - the same as before I changed it. Honda's are smart but probably not that smart... Assuming I hadn't performed the appropriate "reset" function on the odometer, I turned off the motor. I put the key to "accessories" enabled the oil life display and held the "set/reset" button for 20 secs; no joy. I then held the "set/reset" button a little longer and it displayed "A 1". Shortly thereafter the display showed "100%". Have I won the war?
I know I shouldn't "hack" my civic, but advice from the Owners Manual and Honda Service is reliably unavalable. I do my own maintenance.
I like the car, It runs good. I have never owned a car that got more than 6k or so to a quart of oil and I'm in my late 70's. so I owned many auto's.
I look at it this way, I change my own oil, I buy 5 qts. put in 4 1/2 qt's that the car requires when it goes 1/2 qt short I put in the other 1/2 qt. When that goes down 1 qt. I'll change my oil. So I'll get about 4.5k or so to my 5 qts. of oil that I buy.
Forget the minder you will ruin your engine If you follow it.
Having worked for a manufacturer (not of cars) most of my life, I believe in owner's manuals and following the manufacturer's instructions--there is a reason they are provided. So, of course, the first thing I do is pull out the manual. It is the first time I've ever seen a manufacturer state explicitly in the manual, "do not change the engine oil early". Hmmm. Then, it recommends 0W-20 and says you "may" use synthetic. It doesn't say explicitly, but it is written to sound as though dino is fine. I've always been a 3,000 mile dino guy because even if the oil can properly lubricate longer, it becomes contaminated with combustion by-products which I don't want in my engine. So, I'm just a little curious about these recommendations. Oh yeah, the salesman also said there is no break-in period which of course the manual contradicts.
The maintenance minder is the way to go. Do not change the oil before 15% for the first time, and there's no point in doing it early any other time either.
I would, however, break in the engine. Avoid running at the same RPMs for long periods of time, and avoid full-throttle stops and hard stops if you can help it.
Someone on an Edmunds thread sent in his oil a few years ago and the analysis confirmed a high concentration of moly in the Honda factory oil. The idea is to keep the new engine metal shavings from causing problems. Honda has been recommending that you wait until at least 5000 miles for the first change for several years.
I just hit 90k on my 06 Accord EX-L with navi and a manual and I've been following the MM recommendations with no ill effects. This car has been great.
Dealers have different ideas when it comes to maintenance, usually to their financial advantage. I've been using a Castrol synthetic blend but I would have no trouble using strictly dino or going full synth. I just don't agree with the 3k oil change.... and I keep my cars a long time.
But in the end, it just depends on what an individual wants to do.
