Honda Civic GX Transmissions Troubles
thatdeonguy
Member Posts: 52
in Honda
I can't believe I have been without my GX for 26 days. On New Years Day after doing a job in Palm Springs while returning to the O.C. the CVT failed. 48,500 miles with no CVT problems at all. I had the CVT fluid replaced by the dealer. As soon as I got it back from service it started the freeway surge thing. It only took 3 days to totally fail. Even though the CVT is not supposed to be opened up.
The GX tech at the dealer really wanted to see what broke in the CVT. His opinion was that the oil pump in the CVT failed.
WELL CVT's cannot be rebuilt. They are a replacement item only. The first CVT that the dealer ordered was damaged in shipment to the dealer. The second CVT seems to be fine. It comes with the 3 year 30,000 mile warranty from Honda. I can't believe how much I missed the GX and driving in the car pool lane solo. Plus going back to driving my full sized Ford Van was a real pain, in the wallet. Make sure that you service your CVT before the recommended 40,000 service; it may save you a lot of money.
Deon
Deon
I can relate. My 2001 GX smoked it's first cvt at about 32K miles. It took the lame dealer about 10 days to get a new one. Now at 52K miles cvt number 2 is surging. I took it in about 4 months ago and they conned me into only changing the fluid (for which I paid $90 ). Now I think I'll be getting number 3. Wonder what the lemon law says about this? :lemon: Does anyone know if the 2006 GX has a cvt?
Bob
never needed more than 4 business days to R and R my 3 cvt transnissions including paperwork and shipping, (the job only takes 3-4 hours to swap the unit).
John.
I wish that the manual transmission was an option. :P
I have seen several 2006 civic hybrids around town. I hope my 2001 GX last's at least a couple of more years till I can find a used 2006 GX to buy.
mine -
2003 15,000 mi: CVT noises and occasional surging - no replacement yet
I had the first cvt replaced in May of 2004. It basically gave me no warning and just died. I would think the newer ones are better but who knows? After I had the fluid changed in number 2 (about 16 months later), it ran fine for a couple of months. It doesn't do the "freeway surge" but instead surges off the line, usually around 20 mph. It feels like a definite "slip". It's getting progressively worse, so I better get off my butt and take it back. Both of my tranny's pulled about 3000 rpm for 70mph and 3400 for 80.
The other day I set a personal record of 206 miles (8 miles into low fuel light) after filling up at clean energy's Irvine station. Which, by the way, is a MUCH better fill than it used to be.
(1st replacement failed 600 miles After a fluid change).
70 mph/3,000rpm 80mph/3,400rpm.I was told the belt get,s fractures. Good info on cvt theory on howstuffworks.com
John
John.
~ 39K miles
~ 92K miles
Murphy
Thanks for the insight. Any idea what it costs to have one of those CVT's replaced? (guesstimate). And since they are replacing the transmission anyway, wouldn't it be only slightly more complicated to put in a manual transmission and just bypass another potential problem altogether?
Any thoughts would be appreciated.
Lance
List price at the honda dealer for a complete factory rebuilt with exchange of core is $4500 + 3-4 hours of labor.
About $ 5000 . And guaranteed 3 yr/ 36000 miles. My 01 lost it's first cvt at 2500 miles in 2002, second at 62,000 in 2005 and 3rd at 88,000 in 2007 , all factory fresh complete honda oem units. All covered under warranty. The one replaced at 62,000 started having trouble at 68,000, but was not bad enough to replace until 88,000.All of the replacement units were with honda's internal upgrades.
I'm not a hot rod and change fluid more often than required.
The tires on the car outlasted 3 transmissions ! . As to swapping with a manual,or a 4 speed auto, I would do that on mine , but it will prob. not pass emissions testing due to modifications. Don't think it would actually change the emissions output.
Yes by the way same Murf at CNGMotors
Murphy
What a nice solution that would be! Any Honda techs out there that would care to find out?
BTW - Murph: I've talked to you on the phone. Really nice and helpful. Thanks.
Also , off the trans topic, how about you becoming a supplier of cng filters without honda's "Gold Plated price".
Thank's . John.
I'm considering buying a 2002 GX with 72,000 miles from a private owner. On the test drive I noticed the transmission "shudder" when accelerating from a stop. I didn't get on the freeway so I don't know if it does the surge too. The current owner bought it at 64K miles and hasn't had the fluid changed. He didn't seem to know how long the shudder had been going on. In general he seemed kind of clueless. :P
Should I run? Carfax says it was a fleet vehicle, then a dealer bought it and sold it to this guy. No records of previous maintenance. Sounds like the 2001 was the really bad year, but my fear is that the fleet dumped it when the CVT trouble started, this current owner has been driving it obliviously for 10K miles, and I'll end up stuck with thousands of dollars of repair work. I'm planning on having a pre-purchase inspection done by a Honda shop, but will they be able to tell if it just needs a fluid change or if the problems are deeper?
Why do you want a GX ? For carpool lane and bridge toll perk's ? ok. If it is about fuel cost , the only place with really cheap cng is Utah.
In 99,000 miles my 01 GX has had had 3 sets of front brake pads , motor mounts, normal fluid and filter changes, tires at 78,000 and cvt transmission replaced at 2500 miles ,62,000 miles and 88,000 miles (the last one was a bearing , not surging), and an electrical switch recall that was on all civics , not just cng powered.
Honda care extended warranty covered the motor mounts and 3 transmissions.
The cvt problems Go back further than 01. the automatic HX gasoline civic was the first cvt model.The weak link is in the starting clutch assembly". It is simular to a design used on hondas automatic clutch motorcycles in the 1960's and 1970's. The starting clutch is used instead of a torque converter . This design is more efficient and has no slippage at all when working properly. The cvt is also used on the Civic hybrid , mainly because it needs no hydraulic pressure to work.The transmission is designed and supplied by Jatco , one of hondas major suppliers.
Now, CARFAX. All of my service was done at the honda dealer. I ran a Carfax on my own car and NONE of the warranty repairs showed up, a smog check 3 mos. ago also did not show up, only the electrical switch recall did.
Carfax only guarantees the data that they get from other sources. An example is major body damage and the owner had it fixed with no insurance claim. That may not show up. Not the fault of Carfax, but it is a database only.
I will most likely will buy a Honda next time . With a Hondacare warranty , as it saved me after the original coverage ended.
Yep! :shades:
Actually, maybe this is the question I should have asked y'all... From others' reports, it seems you can make the CVT shudder go away for a while by changing the transmission fluid. So... In your various experience, once the shudder develops, is it guaranteed to fully crap out and need to be replaced eventually, even if the fluid changes help for a while? Or might it go forever (say, another 100K miles) with nothing more than regular fluid changes?
Oh and... This guy has only had maintenance done at a gas station and the transmission fluid dipstick surprisingly doesn't say "use Honda CVT fluid only" like I thought it was supposed to. So if by some chance it had been filled with regular A/T fluid...? (Would that cause shudder, and is it permanent damage or would a flush & fill set things straight?)
'01 was the first year for the CVT in the GX, and it seems this one model year had an abnormally high incidence of CVT trouble.
But the *HX* (regular gasoline) had a CVT starting I think in '98.
Does anyone know whether the '98-'01 HX CVT is also problematic? Or maybe it was just one bad year and the HX and GX both had problems only in '01? Or is it a problem totally specific to the '01 GX?
:confuse:
p.s. The cvt fluid was not developed until 2003. It is recommended when changing the fluid on all cvt models. Before that they said just use the honda Z automatic fluid as was in all honda automatic transmissions.
Cvt failures on the Insight are rare , but that is a much lighter car (2 seat aluminum body)and a 3 cyl. 1 L. engine.
Someone in my office with a hybrid cvt got that same B.S. about a "deductible/diag. fee. Many dealers put the least experienced technicians on warranty jobs because the factory will only pay clock time , not book time for a repair. Honda , Ford , GM , Toyota and the rest will not reimburse the dealer for guess work on warranty issues,so they try to get the customer to pay.
Call Honda customer service at 800 999-1099. Stay cool on the phone , and you will prob. get your money back.
I had been having trouble starting at 70-80k miles so it can go on a long time before it gets bad.
The 'flashing D' means the trans is in 'fail-safe' mode and won't go into 'high gear.' It will reset when you turn the car off and on again. I found that a 10 minute rest was enough to get rid of the slippage problem, at least for a while.
A 'rebuilt' trans from Honda is either $2000 or $2500. A new one is $6000.
I was upset because I had been having problems for 30,000 miles and had been to several Honda dealers who advised me to just keep changing the fluid and hoping for the best. Honda sat on the extended warranty mailing until after I passed 100k. So, I was irritated that I had to pay $500 to replace a poorly designed transmission for exactly the same component, but I guess it's a lot better than paying $3000.
I'm also pretty upset that a major component like a transmission from a company like Honda can't be repaired.
