Ford Crown Victoria/Mercury Grand Marquis Modifications
Hello to all! Totally new to all this. I own a 2005 Crown Vic P74. I recently had it tuned by SCT (computer flash Excal 2)and it runs really strong. I currently have single exhaust. I want to have duals put on it with Flowmasters. If I do this, does anyone know if it will throw the computer off and make it run like crap. ">
Haven't gotten underneath my 03 Grand Marquis yet to have a look-see.
Deke
On that note, though, I could have sworn that my '04 has dual cats, connected through a Y-pipe to the single exhaust. Did this change for '05?
Since I'm younger than the usual Grand Marquis owner demographic (at elast in Florida), I want to have mine stand out from the crowd a little. Looking at some aftermarket wheels; really like the American TorqueThrust "D"( with the dark painted spokes) or the TQ II which are all polished aluminum. A little pricey, so I'm considering the old standby - Cragar S/S, but I can't get anyone to tell me what size/backspacing/offset matches the stock steel rims so I can use the tires on the car now.
Upgrading to a set of factory LS alloys will run me about $200 per....
Deke
Deke
They would be fairly easy to find used. New wheels will cost ya.
I saw one such car today that still had the police numbers painted on it, including big ones on the roof. It also had the spotlights in the front. Only the civilian license tag and the kid behind the wheel gave it away, as it was a fairly late model car.
abfisch
Does anyone know who sells a program for editing the transmission shift points and lockup points? Or is that available commercially for this car? I'd like to do my own programming if possible so that I can make adjustments until I get it where I want it without having to send a computer back to a tuning person several times.
Or, what tuning persons work on our cars?
Thanks in advance. RHill
To modify the computer tables, typically you copy the program/tables from your car to a laptop or destop computer, edit the tables, and then load them back into your car's computer "Flash the computer".
For what it's worth and your mileage may vary.
Thanks for helping, if you can. :confuse:
Also, the engine likes to cut out when I go around corners... I can''t even find anybody that's had the same problem.
Thanks, Tim
I want to change out my 2009 Grand Marquis grill & put in a Chrome Crown vic grill.
Does anyone know for a fact that the grills are alike ? I don't want to buy one and it not fit...
Thanks everyone,,
Gunpacker
As I said, I really haven't a clue. Any help would be much appreciated.
I recently discovered a small crack in the intake, which I've since learned is not unusual.
I want to replace the intake, but I am wondering if it would make sense to upgrade to a performance intake?
Does anyone know how much needs to be altered in order to optimize performance with an upgraded intake?
The 4.6 is ubiquitous these days. Do the Mustang parts work? Are they worth it?
Any guidance would be most appreciated.
