1. what cause this to happen
2. how do we disable the security system
Good Luck
I also have a hand brake where the brake light keeps going on and off after releasing the break. Man I love this car....:)
CD changer?
Also today while driving the horn honks 3 times and the hazard light flash 3 times at the same time. It does it 3 times in a row and stops. After a while it did the same thing again.
Anyway, the Hayne's manual shows how to remove... simply disconnect the battery, pull it out of the foam, disconnect the wiring connector and pull the vacuum line. Installation is the reverse. But they give no tests that can be performed to see if the part is faulty.
my wife has a 2000 vw cabrio,and the turn signals randomly stop working. I have checked the fuse, and the fuse is fine. could the relay be bad? how can it be checked?
thanks,
brook
I had a new stereo installed by Fryes on January 18th for a surprise b-day gift and dropped the car back at the High School with everything working properly - except of course the front passenger window. When she got home that evening she told me the key fob wasn't working and the horn was sounding every few seconds and the hazards would flash when this happened! Sounded like an alarm issue and I figured the key fob batteries were low so I replaced them and re-programmed the key fob according to the owners manual, which didn't help either situation. I first assumed that Fryes had shorted something when installing the new radio, which used a specific wiring harness that was bought specifically for that car, so I returned to Fryes to let them look at it before I took it to the VW dealership. During this day (of course it was raining all day) the windows would roll down on their own intermittently and sometimes roll back up and sometimes not, the horn would sound and the hazards might flash and might not!! The key fob had never began working again. Fryes took the new radio out and re installed the old one which had no affect on the problems and the windows actually rolled down in their garage with no key in the ignition! They said they new radio had been installed correctly and they re installed it and I was off to the VW dealer.
As of this message, the dealer has had the car two weeks and installed a new main computer chip, a different chip that supposedly operated the front windows separately and various other parts that they are now saying totals almost $2,000 with labor! At one point last week they said I needed both front window motors and switches, to which I replied was not correct (and not in so many nice words). I told them the drivers side front window was working, on it's own with no key in the ignition when I brought the car in and to go find the real problem. This morning the service guy wasn't in yet and I talked to the mechanic. By the way, I was told last Thursday the car was fixed but they wanted to keep it overnight to make sure. That sounds like a patient in the hospital. I called this morning to come pick it up and was told it still wasn't ready! When I got the mechanic on the phone he was very frustrated and said they had never figured out the whole problem but as they installed new electrical parts and computer chips, some things would work for a period of time then stop again and he, nor any techs at the dealership, had ever run across these issues. I suggested he contact VW corporate service (thinking he had of course already done that) but it seemed to be a novel idea to him! Either this car is possessed or VW doesn't have a clue or both. If anyone has had anything remotely resembling this issue or even heard of it please give me some direction, any direction. Should I contact corporate? The service tech stated they could find nothing relating to the radio install that would have caused any of this and that the radio had been properly and professionally installed. I find it hard to believe several components failed on the same day, whether related to the radio install or not. The dealership keeps asking for me to authorize new and very expensive parts to be installed but can't say if these parts are solving anything or not. Of course I have to authorize these requests as a car that has windows going up and down without any reason, plus all the other issues is basically worthless! If they eventually, by luck, replace the correct part why shouldn't they remove every other part they have installed to make sure the car actually needed them? I don't feel I should pay for those parts or the labor and I most definitely feel VW's corporate service division should have been called in and been able to diagnose the problem - and much sooner!! So much for the impeccable German engineering. Someone please help before I have a bill that is more than the car is worth! :lemon:
The horn flashing and hazards flashing starting going off while going down the road. The last time it happened was in the middle of a major snow storm with the heat cranked, the wipers, rear defroster and lights on. There was a puff of smoke from under the dash. I pulled into the near by rest stop and check it out. Everything with the horns and light straigten out, but I lost the remote access.
I know that the remote can also be used to control the windows up and down if you hold the button down for a while. My guess is that the remote control device is having all kinds of issues. I did not crawl under the dash to check out that problem, but I do do some diags on my window problem (wouldn't go down) and found that there were broken ground wires in the bundle of wires that goes from the door to the body.
Hope this might give an idea.
AJ
I've owned a 2002 Cabrio GLX for the last 4 years and I've became best friends with my mechanic.
Yesterday I got similar issues that you've described:
1) When I left my car in the garage overnight I noticed all the windows were open.
2) The courtesy light on the drivers door wasn't working.
3) When I was driving, the alarm horn would sound 3 times.
4) The vanity lights were not working.
5) The factory radio kept going into SAFE mode each time I shut off the engine.
6) When I opened the driver side door the windows would go down.
7) A 20 Amp fuse towards the far right of the of the fuse box was blown.
So today I took it to a trusted mechanic as I haven't had much luck with the local VW Dealer. The mechanic replace the 20Amp fuse and as soon as the vanity light was turned on, it blew again.
So he took the drivers side door panel off and found that wires coming from the door lock had been rubbing against bare metal of the door and had burnt out the insulation and were making contact. He rewired that section, 6 wires in total and put the door panel back on and everything is working as it should.
Total cost of repair was $200.
I would suggest you ask you VW dealer to check the wiring in the drivers side door first and also refuse to pay for all the components that they've changed ($2K bill) as they haven't fixed you issues. Write to corporate if they refuse.
Hopefully your problem with be fixed and your daughter can enjoy the car.
Its a great car when its working.
Any thoughts?
good luck.....be carefull with air bags.
bob
bobc
Today when I tried to start the car nothing happened. Once I took the keys out of the ignition there was a clicking noise coming from near the air vent in the front left dash and the gauges were flipping back and forth. My wife had mentioned problems with the gauges before but VW always claimed they couldn't replicate it and nothing could be done. I captured a video this time so people can see the issue - http://www.youtube.com/watch?v=xEs2brR4ZAQ
Does anyone have suggestions or idea about what could be going on? I'd like to have some suggestions for the mechanics this time since they seem to be all out of ideas.
we store the car every year for the winter. So, the day of the big storm, I ask my wife to get an oil change, and fill up the tank. Well, the oil change came with a free car wash. It was 25 degrees and dropping as the Noreaster appraoched. After the change, and shopping (which ran late of course), my wife returned to the car to find the locks frozen (we have to use the key - no wireless unlock). She did get the trunk open and somehow managed to wiggle her way to the driver's seat. When she put the key in the ignition, the alarm went off, and wouldn't let her start the car until she turned it off. Well, the only way to tunr it off is to put the key in the drivers door (nice irony).
Finally (after 20 minutes of alarm), she I guess forced the key in the drivers door, and turned the alarm off. Releived, she got in the car, and put the key in the ignition. This time all the windows in the car - all at once - went down automatically. None of the buttons made any difference, and they could not be put back up.
Needless to say, it was a long ride home. The windows are still down. I haven't had a chance to mess with the fuses. Has anyone had this happen before? Sugegstions?
Eric
Anyway I have had lock problems in the past so I dont lock it or use the key in the door now , since its been awhile Im not sure if you turn the key slightly to the left or if its the right ,dont turn all the way ...then the windows will go back up ! good luck to you !
It seems to me that the switch inside the door that triggers all the windows to go down broke, got filled with water and shorted out, or something like that.
Not sure about the alarm, but seems as if opening the door with the proper key would turn off the alarm. If the switch was broken/frozen/waterlogged, it might not have recognized you opening the door with a key, but rather thought that you were opening the door without using the proper key and thus triggering the alarm.
Try taking off the door panel, finding the electronics behind the door switch. First unplug the switch, i think that should stop any signal from the switch to the "all windows down" trigger.
Pulling my hair out
I'm hoping that perhaps it's a simple problem like a bad relay or something. Considering the power the motors probably draw, I would imagine that the window switch just controls a relay that powers the motor. Following this line of reasoning, I'm thinking that I could try swapping the relay for this window for that of another window and see if the problem follows the relay. Of course, this plan relies on a couple of assumptions that I am uncertain about.
1) The power window motors use relays
2) Each window has its own relay
If these are not accurate assumptions, could somebody please correct me and point me in the right direction?
If they are accurate, could somebody point me in the right direction for finding out which relays I should be messing with? I don't recall seeing any information in the car's manual regarding relays, just fuses.
Thanks in advance for any help anyone is able to provide.
Started with-
cruise control stopped working all together
tach and speedometer work sporadically
radio shuts off and turns back on
at red light, car loses all power and shuts down, put in N, starts right back up (3 times now)
Alarm started going off and on when opening unlocked door
headlights and dash lights will dim and brighten on and off....
This has been transpiring over about a year but the stalling is worrying me. I would appreciate any ideas (other than taking it to a dealership or getting a new car!)
We disconnected the alarm from the box behind the right tail light so my daughter will not be mortified again by the blaring horn at the orthodontist- LOL :surprise:
Thanks for reading and offering advice!
go to http://www.cabby-info.com/electrical.htm
ClaireS, Host
Automotive News & Views | Coupes & Convertibles
If you took the battery loose it might be in immobilizer mode,Check the inst cluster if there is a car with a key in it ,it's in that mode.also radio code will be missing,double check wiring plugs especially the crank sensor,,A scan tool would help here,read the codes out...
you could jump the coil to 12 v and see if it cranks ,
Now the bad part.... might have to replace the ECM or have that one reprogrammed.The life span on them is like electronics heat and over 5 years old isn't good.
I have read you can get the part # off your ECM and find the SAME # one and it will work,,,but I can;t find my #
Good luck,
I had a good shop rebuild a Automatic trans in my 2,0 cabrio,When I picked it up the engine was idling pretty high ,The mech said it needed to break in and maybe a tune up,Well the engine ran fine in park and started ok So Tune-up what? I drove it and read online how to reset the user adaptions that helped but still 2 feet on the brakes at red lights,About a week later 250 miles or so I started to hear a knock from the hood,wasn't a spark knock but enough that you could know it was there ,after about 60 mph the knock would disappear until you let off the gas then it was back,,,,a few days later the knock got LOUD and I parked it,I did check the oil the first time it knocked level was good and no metal visible in the oil and the oil was new,I pulled the pan and rocked the crank back and forth damn big knock,so I started pulling rod caps and checking them all ok,Then I happen to look at the torque converter and the 3 nuts that hold it to the crank plate where almost off the studs so I tightened them and torqued them and check for a knock ,it was GONE,I put it back together but it will turn over NO knock but will not run ,,,,has fuel pressures,spark ,check every sensor added raw fuel to intake,I had a MAF and A cat 1 error in code scan,but those are replaced now,I?m going CRAZY That same shop couldn't find anything wrong with it and another $350.00 down the tubes,lol I'll take ANY suggestions !!!!!!!!!!!!!!!!
