Lexus GS Tires and Wheels
Has anyone had their dealer offer to replace all the tires?
I have GS300 AWD and have about 27,000km (16,900 miles) on them and dealer is replacing them next week.
Original were Dunlop and replacement will be Michelin.
The tires should last at least 35K miles with rotation.
Does anyone have any ideas??
Anyway, they offered and I accepted the replacement. By the way I did not see any uneven wear or damage.
I had a similar wear problem on my previous LS400 with factory Goodyear - softer tires and replaced with Michelin.
Shock absorbers on an old car, or
Steering system on a new car.
I suspect there is some sort of handling problem in the car.
I am at 7.5K miles on car (Yoko tires) and the tires are a "little" louder. Will replace with Michelins when the time comes.
They are beginning to make a whining noise when at speed.
The Jag had similar problems until I changed to Michelin Sport A/S. The Michelins also drive better.
All of the dealers in this area (San Diego) order only GS350s with the optional 18" low-profile tires. I noticed a problem with noise on concrete freeways when I test drove the vehicle. But I was told that it would take about four months to order a car from the factory with the standard 17" tires.
The 18" tires make my car relatively noisy on concrete freeways and bumps on regular roads much more noticeable. On a few sections of freeway, they cause my car to go into the dreaded "freeway hop". I'm stuck with the 18" wheels for now, but will be looking for a solution to that problem sometime in the future.
As for the other "yes" --- the 18"s do allow going around corners very fast, and the suspension keeps the car relatively flat --- surprisingly flat for a Lexus. Except for the tires, a somewhat short low-beam headlight cutoff, and slightly "vague" on-center steering, I consider it an excellent car.
To give you a reference point, I traded in a BMW540i that I drove for a number of years and loved. I just could not accept the really awful rear-end styling on the latest 5 Series. I kept waiting for them to correct that huge mistake, but finally gave up and bought the GS350.
That's the only other tire Lexus will recommend for this car. Anyone else had this problem?
I picked my car up today from the Lexus dealer here in Tampa. The new tires are Michelin Pilot A/S and they swapped the Yokohama tires out with an even trade.
The new ride is not only smooth but 50% less noise.
The dealer knew I was not happy and they went out of their way to have a satisified first time Lexus owner.
quite a bit when the speed is between 60-75 mph. It could happen a while ago or after
I had the tires rotated a couple months ago.
I don't know because the front tires are out
of balance or it's the hard run flat tires.
Does anyone experience this?
Checked the wheels, no signs of the weights
came off.
I'm in the process of buying the GS350 and none of the dealers are making the G-Spider Wheels available. That's OK, since it would probably be cheaper to buy it aftermarket.
However, I'm trying to find a Wheels stores that are selling the 18" G-Spider wheels for the GS350. I'm also interested in buying Chrome.
Does anyone have any leads on any Wheel stores in Los Angeles or Orange County, that offer these wheels at a reasonable discount?
Any help is appreciated.
Since the starter located in the V bank so You would have to remove the intake plenum to again access to the starter. There is 2 14mm bolts hold the starter in place. This is not an easy task. I would leave it to lexus Certified tech peform this job. You are looking at 7-8 hrs of labor and the price of a starter.
Dallas Independent Lexus and Toyota
www.jpimportz.org
Has anybody had good luck with run flats on a GS350 and wore them out without them cupping and generating noise?
One thing I notice is I don't think the tires can last over 25K miles.
They wear out faster than conventional tires.
The tires were rotates every 5K miles.
Does anyone have any bad experience on these Run Flat tires?
I'm sorry. If you do a Forums-wide search you'll find other discussions on the subject as well.
I did read other discussions before I posted mine. I can't seem to find any discussion for Lexus GS350 AWD. That's why I posted it here.
Since the tire is only 10 days old, I would call Dunlop at 800- 321-2136 to
see if anything they can do.
you have a couple of options.
1. You can shop around at a few lexus dealers and buy the 18 inch G-Spider wheels. i just bought 4 chrome G-Spiders and they cost about $1,800
2. I still have the 18 inch stock wheels that came with my 2008 GS460 and i'd be willing to sell those to you. it's a 5-spoke wheel that you can probably see if you go to the Lexus.com site and look at the wheels on the GS tab. http://www.lexus.com/models/GS/
3. I don't think you'll find any wheel dealer that will give you any decent value for your 17" wheels.
4. Either way you still need to buy the 18 inch tires. then you need to determine if you want Run flats or regular. if you get regular tires, you'll need a spare in the trunk.
either way, let me know if you're interested in my wheels. otherwise good luck
See ya,
Roland
Still have plenty of tread left on 4 tires.
Rotated every oil change (5K miles).
My wife drove it most of the time. She does not accelerate hard
as I do.
So the car doesn't burn much rubber.
