I had tons of issues with my patriot and I had got the car new at dallas dodge and every time it was towed to the dealership they looked at me like I was the number one problem that the it was going back for repairs like 20 times in 6 months, yea I said it 20 times, ridiculous! I drove like all kinds of rental cars while my car was in the shop and dallas dodge paid for it and they would give me ISSUES that they had to or that it was very obvious that the car was a junk jeep, the messed up part about me bring my jeep pat back to the shop for repairs there was oil stains every were, and it was a new car. yea I paid 23,000$. For my jeep patriot, I sued Chrysler and won my case, oooh and if u wont a complete buy back from the dealership you need to make sure you get a lawyer with in the first year of purchase, new buyers only have 1 year to qualify for the buy back in the state of TX, but if you still want to sue then you can and that is what I did, I was 3 month to late for the buy back so I just sued for pain and what I went through with my jeep patriot and I won and got $ 5,500 and if you ask me it was better then not getting nothing, ooh and keep every single piece of paper work u get from the shop when getting repairs done. “Work orders” the lawyer will need this for the case and if anyone needs a lawyer I have one.
Alex Simanovsky & Associates LLC, 2300 Henderson Mill Rd, suite 300, Atlanta, Ga, 30345
Wish all the patriot owners the best!
Please help me!!
Feds investigate Jeep Patriot stalling problem ((Detroit Free Press))
Since it was new the factory sunroof has leaked constantly. It has been to the dealer 4 times but was never corrected. When the warranty was up we stopped taking it to the dealer mostly because of poor service and also because if those brain surgeons haven't fixed it in the first 4 times on their dime they aren't going to fix it on mine. Anyway, several forums stated the sunroof is an extremely common problem with these as is corrosion of the wire harness. We removed the drivers side kick panel and lifted the rug to check the harness and found about an inch of water in the floor pan, no surprise here. It has a drain plug so we pulled it so it could dry out. We followed the wires up to a silver module with two separate plugs going it by where your left foot would rest( you don't need to remove the kick panel to see it just stick you head under the dash ). This is the traction control module that communicates with the trans module AND the ECM. we unplugged the connector from the module and noticed some minor corrosion on the module pins but the big surprise is when we used compressed air to blow out the connectors. A ton of water blew out from both connectors! We then sprayed some of that electrical dry out spray on the pins and connectors and let it dry. About 10 mins later we plugged the connectors back in and started it up. It ran perfectly! Upon further inspection we came to the conclusion that judging from the visible rust behind the kick panel water was leaking from the sunroof and traveling down the drivers "A" pillar (windshield post), following the wires straight down into the connectors, dripping off and continuing on down to the floor where it collects under the rug. Drove it 40 miles to work today and no problems so far. This has been a problem child and only has 33k on it so we are definitely trading it in on a Toyota in a few days before this problem destroys the module and it gets really expensive. I hope this helps other Patriot owners!
I suggest you do as I will, and sell. at least before you have the issues I have had, unless you have a fondness for engine trouble lights that mean nothing, or something, nobody knows. Not sure if I will buy another 4x4 or get a car that is better on the highway, maybe look for an old Land Cruiser or something. But unless I shop out of town I will avoid that dealer, our only one, so no more abuse for me from them.
Sell, before it disappoints. Leave her before she leaves you!
Unfortunately I bought a Jeep P N and it is not a true off road machine. at best it gets your groceries reliably when it snows. that's if the tranny and clutch and everything else works. I have owned cars for 35 years and never had the bad luck to own such an unreliable piece of rubbish, nor to have such inept service and diagnosis as I received from Comox Valley Dodge.
I own a '08 Jeep Patriot FWD w/75,000mi. It has a CVT. My transmission problem: It mysteriously goes into transmission "limp mode" for no apparent reason. By limp mode I mean RPMs won't exceed 1500 and unless going downhill car speed goes up very slowly to about 30 - 35 MPH. After stopping & starting the engine, it cures itself for a while before falling into limp mode again. By trial and error, I have found that I know immediately when it's in limp mode when I start because when first shifting from Park to Reverse, I feel the car clunk & shudder & I know it's in limp mode. When that happens (now 2 of every 3 times I start the car) I immediately put the car back in Park & then as quickly as I can, I turn the engine off & then turn it on again. Every time I go through that procedure the limp mode clears & the car then drives fine until the next time I shut down and have to restart.
Does anyone have thoughts about what's causing the transmission to frequently fall into limp mode. The CEL light comes on during or shortly after limp mode and then randomly goes off again or not. Thanks!
Further to my 8/4 message above, the check engine code is p0700 -- a general transmission code for which further communication with the transmission control module is necessary. But like I said, the limp mode only manifests itself on start-up, never while driving. And once I clear limp mode by re-starting, the car runs fine.
