I'm wondering anyone has seen the same problem or whether it's in the recent recall list. Thanks.
Steve
Try topping off the fluid level.
Overall, my '01 with 61K miles is kinda OK. I don't drive it much lately, but it needs new tires. The third set. The current Michelin LTX M/S went barely 40K miles. I will replace with the Cross Terrains which are much better rated than the LTX. My brakes are also needing replacement. The third set after only 61K miles. I suppose that's to be expected for such a heavy f/s truck. I should just trade out of the Seq. but the spouse is adamant on keeping it.... We'll see....
I just hope they finally put a full center armrest on this truck so that I can put it on my list of possible future purchases. I just can't be comfortable with those skinny fold-down thingies.
Anyone out there have any more info on the new sequoia?
Suggest you go have a talk to the dealer about these TSBs and get some money back
Sorry to bother the masses with something so mundane, but I've been trying to determine what most of you are using to clean and polish the wheels on the Sequoia. I've got a 2004 Limited 4x4 in black and I can get it looking pretty sharp but the wheels never seem to stay clean for any amount of time. I know the factory 17" wheels are "alloy" but does anyone have any suggestions on shining them without pitting or etching them?
Ken
I am interrested in knowing if you use a brake controller?
I will be pulling a 5200 lbs trailer with my seq 2001 and I need a brake controller. I can see by the fuse box a connection with 4 wires unused and I am wandering if this is what I should use for my brake controller.
Thanks in advance for the help
Guy
You were looking fro a brake controller for your sequoia, did you ever find one and which one did you get?
I looking into pulling a 5200 lbs travel trailers and need to kow other have done.
Thanks for the info.
I would not consider pulling my trailer without a controler that would activate the trailer brakes, not to mention I think its illegal in CA to tow a specific weight trailer without trailer brakes.
Hope this helps
Hope this helps.
Toyota Ken
Conversely, I have a cousin that just purchased an '05 Tundra 4-door (282 hp w/a cab height camper shell) and reports 17 mpg, mostly highway driving. I've never gotten that in either of my two vehicles.
Am interested in anyone elses' thoughts about this. I'm not surprised, but wouldn't complain if mileage were better either...
And your welcome.
Toyota Ken
Ken
I need to replace dunlops on 04 sequoia, at 60,000miles. I like the look of Dunlops on the sequoia, but wondering if I am missing potentially better ride with Michelins on this suv.
Did you consider or were the michelin LTX suv tires an option?
I always heard bridgestones were louder??
I live in KY and we get isolated snow, the dunlops did OK last winter.
Did you have Dunlops originally and like Michelins better?
Thank you!!
Is there any engine/performnce problems that will occur if I do? Anyone tried it?
Thanks. :confuse:
My '01 SR5 came with the Duellers. I replaced them at 25K miles with the Michelin LTX M+S. Very good tires, quiet and comfortable on all roads. Now at 61K miles, I will be replacing them with the Michelin CrossTerrains. The latter is a much better tire, from what I've read, than the LTX. You can certainly get them for about the same price as the LTX.
After barely getting 20K on my previous Duelers and Dunlops I'm very curious if these will get 3 times the mileage from the OEM tires. Regardless of the mileage they handle so much better on the hiway and in the snow.
Why do they put such lousy tires on these vehicles OEM... I thought the Duelers were the worst until I got the Dunlops...
More in Tires, tires, tires or you can even ask a Tire Rack rep for an opinion:
Ask Connor at The Tire Rack
I have had the exact same problem, with no fixing. My dealer claims it is due to either my brake pads or fluids being too low and that will fix it. I have a 2003 SR5 also. I was hoping the recall fix would eliminate this. The problem is it is so intermittent, I can only describe it to the dealer -- they never duplicate it. It happens on the highway after I usually hit the brakes and if I turn off the car, it stops.
If you ever got a solution, I would love to know.
Toyota Sequoia rear hatch latch assembly replacement.
I recently found it necessary to replace the rear hatch door latch assembly. It had broken and there was no way to open the rear hatch from the inside or outside.
The 2001 Sequoia sold in 2000 had 89,000 miles and was maintained well. It looks like this plastic part that failed is just a weak design and most or all will fail at some point.
1. You can open the rear hatch from the outside if you can get the small piece of the broken lever out of the square hole that is on the right side of the handle grip area. You will need to use a strong piece of wire or a screwdriver type tool with a slight bend on the end. The lever that pulls on the cable that opens the latch is located above the opening in the handle grip area, accessed through the small square hole. Insert the tool that you made and fish around to find the cable lever, you will need to have the tool pointed up to find the lever. Once you find the lever pull down to pull the lever. Note: make sure that the hatch is unlocked or it won’t open.
2. If you can’t locate the lever or can’t make it open from the outside you will need to do it from the inside of the vehicle. This isn’t fun but it can be accomplished with a little sweat and a few choice words thrown in.
3. You can work from the outside of the truck at this point, roll the rear glass down to give you access. The plastic trim pieces on each side of the rear glass can de popped off by hand, they each have three plastic barbs that hold them on. Remove them carefully and pull straight out to remove them, this will give you access to the large rear piece of plastic trim that covers the inside of the rear door.
4. Remove the vinyl pull-strap that is located on the rear panel, use a #2 philips to do this. Now start to remove the large inside door panel. This panel has the rear glass inside rubber anti-rattle blade attached to the top of it. (If you were able to open the hatch door from the outside you can remove the inside panel by starting at the bottom of the panel and using a thin blade to lift the panel away from the door and then pop the plastic barbs loose, then lift it up and off of the door sheet-metal.) Starting at one corner, bend out and pull up on the panel where it is hooked over the top of the window opening sheet-metal. It takes a little force to get it started but be persistent, once it is started work towards the other end. Once it’s loose at the top you can reach inside and pop loose the plastic barbs that retain the panel and remove it completely.
5. You now have access to the inside of the hatch. Remove the three round rubber grommets, this give you access to the latch lever that pulls on the release cable. Reach inside with a screwdriver push down on the lever and you will be able to release the latch on the hatch door and open it.
6. There is a white plastic cover covering the cable attachment point, remove it by pulling down and away from the assembly, it clips onto the assembly bracket and helps secure the cable to the lever attachment point. You can now release the cable from the assembly, remove the screws holding the license plate recess cover and the nut holding the key cylinder assembly and then remove the cable assembly bracket, (two nuts). Now you can remove the license plate recess panel and the broken latch lever assembly that is attached to it as a unit.
7. You can’t just purchase the ($2.00) plastic piece that broke, Toyota will make you purchase the entire assembly, $63.00. By the way I shopped around and got three different estimates from Toyota Dealers, ranging from $280 to $360 to do this job. This first repair took me seven hours because I didn’t know what I was doing, I spent 3 hours just attempting to open the hatch, I could do it now in about two hours.
Any help is appreciated...Thanks!
I'm looking to buy a used Landcruiser year 1999 or 2000 or a Sequoia year 2001 or 2002. Aside from the Sequoia being newer, are there any other pros' / con's to looking at purchasing one of these two vehicles?
bradesp
