1997 Mazda MX-5 Miata Long-Term Road Test
Edmunds.com
Member, Administrator, Moderator Posts: 10,315
Edmunds conducts a Long-Term Test of the 1997 Mazda MX-5 and describes how its Keegan Engineering-built engine will support a turbo.
As for coolant pathways, keep in mind that if you have the turbo as the highest point, you need to be very careful with bleeding the system. Many OEMs are turning towards coolant afterrun pumps and/or continuous bleed through a hot-bottle recovery system because of the obvious risk of local boiling in the turbocharger upon shutdown and when running the vehicle very hard.
