However, I later discovered that after driving on the highway at speeds exceeding 3,000 RPM, there was considerable valve train noise upon slowing down and an increased operating temperature, all indicating that oil is not getting to the valve train. Further research indicated that this condition could be caused by either an improper grade of oil or a partially blocked oil pump screen.
I cahnged the oil, which was obviously not the proper grade because the hot stuff I drained was thicker than the cold 5W-30 I replaced it with. However, this didn't fix the pressure reading. I've driven the vehicle around town, careful to keep it to under 3000 RPM, which seems to be the magic number, and the engine runs srong, sounds good, respondes well, and gives absolutely no indications that there is an oil flow problem. Tomorrow I will taike it on the highway and run it above 3,000 and see if I there is any noise.
I think the problem was a combination of imporoper grade of oil and a faulty pressure gauge. I know this seems unlikley, but when I drove the car today, the gauge indicated no pressure, yet the vehicel performed fine (I was very careful). Once the car warmned up, I got the same readings (low idle, lower operational). I seems plausible that oil which is too thick (say 10W-50) would not work well at the high RPM the Miata was designed to sustain. Simultanoeusly, it also seems plausible that a faulty gauge would give bad pressure readings regardless of the oil used.
The only other option I can think of is a clogged screen at the oil pump intake, which I will check if I get valve noise after running at 3,000+ RPMs. What I want to know is if there is anyone who can think of something I've missed, another cause for this that I should also check into. Obviusly, if the oil pressure drops when the RPMs increase, the problem is at the oil pump feed side. However, I've pretty much been a 6 - 8 cylinder guy prior to this, so any additional thoughts, advice, or information is greatly appreciated. Thanks and I look forward to more discussions.
Daedalus1
I have a 1993 model, one of the last years that actually had the true, working gauge. I'm not sure if 93 or 94 was the last year, but I'm pretty sure it was a dummy gauge by the 1995 model.
So don't trust the gauge.
Surely the wrong oil was being used. You might want to use an engine cleaner treatment to flush it out, then drain and fill with thinner oil, or synthetic perhaps.
Cheers
kevin
The top is 11 years old so if it's original budget $900 plus for a replacement. If it's not cracked already it will be in the next year or two.
The re-do came in 1999, so that's a newer generation.
I believe some early cars had some clutch chatter issues, not all of them, but a few. Make sure the clutch engages smoothly.
That's a good price, though.
Also, I'm wondering if you would recommend buying an extended bumper-to-bumper warranty -- not from the dealership, but from my credit union where I've bought warranties before with great success ($1300 for a 0 deductible, 4 year or 100,000 miles). Thanks.
It is amazing how such a small thing can cure the feeling that the whole dashboard area is coming loose. I don't wince when hitting a bump or going over railroad tracks any more.
There are drains near the jack points, if you can find them, use a paper clip to loosen any debris that may have clogged it.
The drains are just holes, basically, nothing special.
Warning - do *not* look up at it while you do this, else you may get an eye full of dirty water and debris. :sick:
I LIGHTLY spray these parts in order while the engine is running:
1=Radiator when air pull motor runs (Crack behind the AC Condenser)
2=rubber parts
3=Valve Cover
4=Fast Evaporation in a few seconds
5=Don't spray the turbo or exhaust manifold (heat shield ok=lightly)
6=Many guys at the SCCA AutoX meets saw me doing this & started the same to cool off their engine compartment quickly. 7 States! 12 tracks.
7=1/2 Liter when Hot, 90+ and 1 full Liter H2o when 100+
Photo of AA battery operated 1 L Chinese made water sprayer below.
$4.50 at Home Depot. Never any engine damage, in fact my cars run better than most due to a clean engine compartment! Rubber hoses remain soft and last long (450k miles on a Mercedes). Engine BELTS last longer too! Did this since the 1970s and over 1.5 million miles of vehicles. Diesel and gas & most of the them with turbos. Not my Porsche 911. Many High Output cars too.
Sprayer also works great as a H2o Drinking Water bottle, car wash, suntan cooler, Tail Gate Remover (shoot in air), Hair spray, ANY SITUATION THAT WATER IS USED... I have a 2nd Battery Sprayer for Chemicals, Simple Green, Windex, etc. I put Gatorade in a bottle once and market it coolant!
I then drank it as a joke! Faked choking! That was funny!
Could this "H2O COOLING TREATMENT" be the reason my engines last so long, rubber parts remain so new, engine fluids look barely worn when drained? Well, the engine is made 2 take a beating (dirt, heat, liquids, etc.) so a little cool air mist never did hurt my engines! 1 thing I did notice, RAW CUT OR GRINDED STEEL PARTS did tend to rust, so I would use some touch up paint to cover up these parts. No problems with the Miata.... I learned this trick at the race tracks in Hawaii aka Hawaii Raceway park where the outside temps. are normally over 95 and humidity is over 90%... The hand spray bottles were a "[non-permissible content removed]" to use, so we used the pump insect bottles! Those worked great to cool of the car & people... Guess growing up in Hawaii was a benefit! Hey, If I damaged my engine, I would know, and I would stop! But only "BENEFITS" seem to come of this "light spray habit"... I'm just sharing my experiences with engine maintenance for the last 30 years with 1.4 million plus miles and 20+ cars...
PS: Gents, it also cools off the interior of the car quickly when your Miata sits in the sun & cooks for hours! I spray everywhere inside and the car cools so fast, it's "MAGIC" vs. waiting for the AC to OVERWORK! I use this method almost every time with the ENGINE MIST...
Indemnification: I am not a certified mechanic or Engineer, so my experiences are not advice for the members of this web page or the entire internet community. Any behavior or ideas expressed here are only for the entertainment of the readers and are not advice in any way. The writer, repo4sale, states none of these methods should be copied unless you are 100% willing to accept the results, negative or positive, of your behavior!
Sorry, gents, but these ideas are being issued by REPO4SALE, A CALIF.LLC aka California Limited Liability Company with Zero Assets!
Back pads had 50%+ left so we left them. 101k miles
Finally replaced front Bumper Skin with a "junkyard MSM skin" due to the Ninja accident about 6 months ago. Allstate is a "[non-permissible content removed] Liar"! Paid $60 for the used MSM Bumper skin, and $60 for 4 MSM Rotors and 8 MSM pads from a Damaged Car. Used only 4 Front Pads, rotors are great like back pads...
Is this normal for Miatas??? Pads lasting 100,000 miles with abuse?
Got $4100 from Allstate and spent $315 fixing Miata ($200 labor + $60skin + $55 alignment). Kept the balance from the Court Judgment against Allstate! $3785 =
Paid $50 for brake job and $15 (4 pads)=$65 for MSM brake job!
Miatas are FRUGAL 2 OWN! I'm real real real FRUGAL!
Top material is like Mercedes/Bmw Material paid $200(vs. $550) + $180 labor = $380 for a Mercedes Type Top! What a deal!
Porsche Boxer owner sold his car, said it made love 2 the mechanics! So he then sold me a special Top ONLY Cover. 2 Velcro straps 2 windshield wipers & flaps under wipers, 2 clips under door bottoms & 2 straps in trunk! This is an 85% fit vs. the Porsche Boxer... I also used 1 can Scotch guard on the new top & 1 can on the top cover! I'll post a photo of this Porsche Top cover later, perfect to keep the sun & bird stuff off a new top!
OH, FREE REMOVE & REPLACE AT 99K MILES MSM CLUTCH WITH MSM CLUTCH DUE TO SHOP MESSING UP TRANS OIL CHANGE (plugs on right side vs. left)! MSM Clutch Kit was from a MSM 2004 with only 4k miles on it!
I'm so happy, this car is FRUGAL + FUN + FRIENDLY + FRICKEN FANTASTIC TO DRIVE!
A few members there work for dealerships and can tell you what you would get wholesale trade, and guesstimate the private party value as well.
KBB is often way off, so don't let that set your expectation.
Keli hard
The water sloshing is probably under the doors. There are drains at the jacking points under the car.
Go in there with a paper clip to loosen up any debris that gathered up and clogged the drain. That's a simple fix.
Wear eye protection so that dirty water doesn't pour on your eyes.
Thank you for your reply!
keli
On the Miata, Look under the door sills, right where the jacking points are.
If any body work was done in the past, perhaps the body shop sealed up the hole?
Im looking for a 2nd car and came across a 97 Miata...a car that I always wanted but was never able to pull off because here in CT the winters would never allow it. Now I can have another "Fun" car.
Im trying to stay under $5K and this is the only one I have found under 100K miles (it has 99K, haha). Looks to be in very good shape, aside from hubcaps instead of rims :-(
Anyone have any thoughts? Anything specific I should look for/ask about? Was this a reliable year for the Miata?
Thoughts on finding/prices for used rims?
Appreicate any info. Im going to see what I can find over at Miata.net.
Thanks again and I look forward to comments, comments, and more comments!
Thanks, Jeff
I see no particular reason to avoid it.
'90 models had some crank issues early on, and '99 models had clutch chatter and some other issue (I forget now). But overall major issues are few and far between.
Jeff
Wires for these should be replaced every 30k. I have a while to go.
Can someone expect to get 90K miles on the original tb ?
I recently bought this one owner commuter car from the dealership that sold it originally. They told me that "all required maintenance had been done". Since then I have found that the timing belt has never been changed ( 82K mi on the odo now ). The car has otherwise been cared for with maintenance records showing everything else having been done. ( The owner obviously traded the car prior to doing the expensive timing belt )
I have been keeping the RPMs relatively low ( below 4500 ), but I do realize that I need to change out the TB soon.
They used a whole timing belt kit and did the water pump, too.
The job got a bit pricey but it's the first major expense I've had in 8 years, so I can't complain.
On a bum note, I had my timing advanced to 14 degrees BTDC, and they set it back to stock 10 degrees. Would you believe I feel the difference?
I gotta find those old instructions so I can advance the timing again.
If it fails before the rest of the car I will report on how many miles (or years) the belt actually lasted. I understand it is a non-interference engine so a broken belt won't trash the pistons and valves.
I advanced the timing, and it fixed the power loss issue.
They had it set to 1 degree BTDC, it's supposed to be 10 degrees!
I advanced it more than stock to 14 degrees. Runs like a champ now. :shades:
Lisa
You should go to www.miata.net, a lot more readers there that know a lot about their cars.
Loren
Mine reads low until I rev the engine, but not zero, just low. It jumps up when the engine revs, then stays pretty steady and increases slightly with high rpms.
I haven't driven the car for several months. The drive belts were changed about 10K miles ago. ( Purchased the car about a year ago, but haven't had the chance to drive it much until lately ).
Is this common ? Should the belts be adjusted ? Other common causes ?
