wwest, thank you for your response. What you say makes sense and would eliminate one possible cause. Apparently the only things the dealer tries are downloading error codes and driving the vehicle to duplicate the problem, not much thinking about what may cause the problem. I was surprised that no one else has apparently had this happen to them since a quick look at the NHTSA web site lists numerous such incidents. The really scary thing is that the NHTSA shows similar problems for many different manufacturers.
I have a 96 LS400 and (like others) the Radio (head unit) display went out and the CD Changer is intermittent.
I purchased a replacement head unit from a “junk yard” in Texas via the internet for $350. The removal instructions (with pictures) are available at the following site: http://carstereohelp.com/strlexus.htm It wasn’t very difficult, the only problem was that I was afraid to pry and pull with the necessary force to lift the center wood and also the vents.
Unfortunately the do not have instructions for the removal of the CD Changer and once I get that figured out I’ll see how their repair capabilities are and let you all know.
The dealer quotes I received (Northern California bay area) were $1,500 for a rebuilt head unit and $1,000 for a rebuilt changer (installation extra, of course).
I also checked with Pioneer Electronics and Lexus and both said that these units were “built to spec” and that there are no OEM compatible products available. In other words, if I want to keep the factory head unit (proprietary size in the center console) I HAVE to use that same changer.
Undaunted with this, I’m going up to Marin Lexus to check out a 1998 LS400 with Nav and air suspension. Only 48k miles. Hope it’s cheap since it looks like everyone says that the suspension will need about $4k worth of work between 75 and 100k miles. Can’t be certified since it’s a year too old so I’ll have to get a 3rd party warranty.
Do you still have you old head unit? I need one for the lights. My climate control needs a few bulbs and I don't know what kind they are. Maybe WWest could help me there.
The 5th gear in the auto trans makes a welcome improvement in gas mileage on trips - but be careful; there's ZERO engine braking when you take your foot off the gas at speed, unlike the 4-speed auto trans in the earlier LS400s.
And the increase in HP from 260 to 290 will be readily apparent.
My 91 LS400's steering wheel would come out and go back in, but would not go down (I think it does go up).
It's stuck in up position, and it's a real pain to drive. I've set the "auto" mode off because I am having this problem...
Anyone know what could be wrong? How hard is it to open up the steering column to take a look? If someone has service manual on this procedure please post.
Dealer wanted $1800 for a whole new assembly. Turned out to need a switch and a new computer ($300 from the junkyard). May be time to get friendly with a Lexus specialist.
i replaced compressor 16 months ago with a new compressor on my 92 ls. it worked fine until two weeks ago. it was sitting in parking lot idling when ac light started to blink. this happened 3 times in a period of 24 hours. after that it worked for 2 weeks with no problems, idling or highway speed. yesterday i started the car in the heat of the day to cool before driving, and it started blinking again after 7-8 minutes.if you turn ac off for a few minutes, then back on it works fine.the fans are working. they shut down within 10 seconds after the compressor stops.is there a switch somewhere that is causing this? any help is appreciated. i took it to my lexus dealer but all they tell me is probably the compressor.
Check for A/C codes , first hold the auto sw and rec sw down simultaneously then turn the ign switch on . This puts the a/c system in diagnostic mode , any codes will come on the a/c temperature display after the indicator check ( button lights and temp display (88.8) go on and off 4 times ) . If there are any codes stored they will be displayed at the end of the indicator check . To check belt tension look at guage at the back of the belt tensioner . Is the a/c clutch working ? Is the belt slipping/squealing?
thanks for replying. my control panel does not have rec swith. everything has worked fine for the past two days. ac has worked perfect. no belt noise. the problem is triggered by starting the car and running at idle to cool down interior before driving. but not always. it is 7-8 minutes before the compressor cuts off, if it does. thanks paul
Check the electric condensor cooling fans, if they don't work when parked then the A/C will be shut down to prevent coolant overheat.
Both fans should run at full speed, 12 volts across each, as the coolant temp rises. If coolant temp continues to rise with both fans at full speed/volts, A/C is shut down.
My 92 has a fresh/recirc switch just to the right of the temp. adjusting rocker switch. Most times under your circumstance the system switches to recirculation automatically until the interior has cooled down considerably.
I would still consider marginal (190F??) coolant (engine)overheat as a possibility, especially under your circumstances.
Given a 92, I would ascertain proper radiator cooling flow before any other work.
The 92 I just bought in AZ has dark tint on rear and rear side windows and a lighter tint on front side windows. Without the tint and given AZ bright sun and heat I suspect A/C and engine cooling simultaneously would be marginal enough (parked, engine idle) that even a partially blocked exhaust catalyst would give your indications.
i think the belt may be squealing. i drove the car home, it worked perfect. parked in my yard and raised the hood. there is a fairly loud noise coming from the direction of the belt. the compressor ran for 7-8 minutes, then cut off. both fans working,noise not as loud after compressor cut off. the belt probably has 70,000 miles on it. think i should start there?
The rec (recirculating) sw I was referring to is the bottom of the 4th sw left to right from the off sw. It shows a car outline with a curved arrow . Now see if you have any codes. I am leading towards a slipping belt , a slipping clutch , a bad tensioner ( allowing belt to slip ) or a locking/ed compressor motor , any of the above conditions will give you the blinking a/c light ( ie compressor speed is not in a constant ratio with the engine rpm). There is a guage ( indicates the degree of stretch/wear in the belt ) behind the tension pulley on the accessory serpentine belt , tell me where the indicator is pointing . At 70k + I would change the accessory belt and possibly the tensioner if suspect , regardless of the guage indication , paying particular attention that the ribbed belt is on each pulley evenly.
The code 21 is indicating the solar sensor ( black sensor in the righthand windshield vent ) is not sensing light. When checking in dark conditions direct a flashlight or similar light source on the sensor and the code 21 will not appear, from what you've said the sensor is working properly . The 00 indication means no codes in memory . Have you installed the new belt/checked the tensioner ? Also when the system is working , does the engine rpm increase/decrease slowly by about 300rpm when turning the a/c on and off? (approx 600rpm off/900rpm on)
If the engine coolant should rise to 190F then the A/C compressor will be shut down but no fault codes will be registered.
To test this possibility use a garden hose to spray the radiator/condensor assembly after the A/C shuts down. A/C should restart almost immediately if coolant temp is the cause.
i did not have a chance to have the belt installed today. will try tomorrow. i did flush and fill with new coolant. the strange thing is as soon as it cuts down and i press the off switch, it starts right back up when i press auto. works perfect on the highway. only time it cuts off is idling and slow traffic, and this is not all the time. thanks for all help. will let you know about the belt and i will try the garden hose.
in this post you said to close engine and radiator drain cocks,. when i drained my coolant today, i only drained the radiator. where is the engine drain cock located?
You can see the block drains without taking the under cover off by looking up and forward from the steering rack , near the main o2 sensor but on the block . It has a small pipette pointing down and there is one on each side of the block .
Installed new rear brake pads, forced piston to retract, fluid level in reservoir rose, trac diagnostic next, code 19.
Removed fluid to below max line and no help.
Lots of caution notes regarding overfilling brake fluid reservoir but no information regarding how to fix. fairly sure I have no fluid leaks but "19" says brake pressure pump is cycling too often.
Anyone else experience this and know what to do to fix?
Check the ABS sensors and their wiring harness. Also it is better to open the bleed fitting because pushing older fluid that may be contaminated back up the lines may not be a good idea.
I know you are not a fan of fluid changes, but over 10 years, you'd be surprised to see the level of particulate contamination in brake fluid, not to mention water content.
150,000 miles on this one, brake fluid is quite dark, I have always advocated changes/flush at ~100k.
Diagnostic indicates brake pressure pump is cycling too often. Must be a leak within the system, to the low pressure side say, or accumulator gas pressure side may be "flat".
But I still don't see how brake pad change, resulting in "over-fill" of the reservoir, could have resulted in this failure.
Coincidence maybe?
Dealer would be the last resort, but I'm betting they would simply start out replacing parts, assemblies (pump/accumulator), etc, until the diagnostic doesn't come back.
Parking brake set, firmly, tranx in drive, voltmeter monitoring the output of the Trac brake pressure motor, each time the accelerator is "tipped in" even ever so slightly, the relay enables the brake pressure motor.
On the tenth "tip-in" the trac failure indicator lights.
Repeatable even in cruise control on the highway.
Operationally this is exactly what it should do if on "tip-in" a rear wheel slips, but there is no indication of rear brake application nor dethrottling.
The ECU is correct, the Trac motor is cycling more often than it should, but why?
Jacked up passenger side rear wheel, started engine, put in drive, wheel begins to rotate, applied very light throttle tip-in, Trac applies braking, rapid pulsing.
Same with driver side wheel only off ground.
Front wheels thoroughly blocked to prevent movement.
Does everyone know this thing applies brakes to both rear wheels simultaneously?
I knew that the parking brake warning lamp was "failed" when I purchased the car. Since the speedo and tach needle "lighting" was also in failure mode I bought the entire assmebly from a wrecking yard and installed it yesterday.
It turns out that in the speedo assembly I removed the Trac failure lamp in the "shroud" above the speedo hade had the bulb removed.
Now, do I really need a (useless??) Trac system that applies braking to both rear wheels while dethrottling simultaneously, or do I simply remove the bulb in the new assembly?
Trac code 19: "TRAC motor ON and OFF operation is higher than a predetermined number of times (accumulator pressure leakage)."
Trac code 19: Circuits/devices to check... "(1) Fluid leakage in actuators or tubing." "(2) Pressure leakage of accumulator."
Hmmmmm....
Up until just a few moments ago I was assuming "Pressure leakage of accumulator" meant brake fluid pressure leakage.
Then I remembered that a water well pump short- cycles (repetitively, quickly, on and off, on and off, etc. )if the pressure on the bladder side of the water storage tank (accumulator) is low.
So now my guess is that each time the throttle is "tipped-in" (from ANY current position) the ABS/Trac ECU checks for sufficient Trac brake fluid accumulator pressure and actuates the pump until the accumulator fluid pressure switch opens.
With no gas pressure on the "bladder" side of the accumulator the pressure switch would not likely remain open (indicating high accumulator fluid pressure)for very long. But that condition wouldn't be detected until the next throttle "tip-in".
Ten cycles in a relatively short period and the Trac failure is illuminated and Trac is disabled.
Sure wish the wording had been "Gas pressure leakage of accumulator".
Anyone know if Lexus (or anyone) can recharge a Trac accumulator?
Oh, well, nice relaxing and easy-going father's day.
paul & west.tried the water hose, did not work. had the belt replaced today , and the mechanic said the tensioner was ok.the ac cut off 2-3 times in his shop after he had replaced the belt.finally it started working with both condensor fans running for 10 min.i shut the engine down, started it right back up and the ac worked for another 10 min. without the fans running.as soon as i backed out to leave, the ac light started blinking. i drove the car 25mi this afternoon to an appt. worked fine until i stopped and put in park. light started blinking.left there it worked fine. parked at wmart and stayed appr 40 min. started engine and compressor, ac started blinking immeditately. switched the ac off and back on, it worked fine. drove 25miles back, with no problems. i left it running in my driveway, and ac still worked. it was a really hot day in ga. today. could the heat cause some sensor to malfunction? how about you q45 man, any ideas?
In hot weather, A/C compressor running, the fans should run at low speed (connected in series, 6 volts each) unless the engine water jacket temperature begins to rise above ~190F, in which case relay act to run fans in parallel, 12 volts each.
How did you creat the circumstance wherein the fans did not run and the A/C subsequently shut down, therein lies the problem.
Parked, on a hot day, with the A/C running, if those fans don't run at least in low speed the A/C will shut down due to threatened engine over-heating.
Also check and make sure the viscous clutch is engaging the engine driven fan, forcing it to turn with the engine. Heat flowing downstream of the radiator increases the vicosity of the clutch fluid thereby tightening the coupling.
the electric condensor fans operated (and not) like that on their own then you have an intermittent circuit connection.
On the 92 the "high" side refrigerant pressure sensor/switch (controlling low speed operation) is behind the passenger side headlamp assy and the relays or behind the driver side headlamp.
How many miles?
You might be losing the brushes (intermittently in one of the fans which would prevent low speed operation and then by the time the engine coolant temperature begins to rise it may already be too late for both fans at full speed to reverse the trend.
I would actually place bets on intermittent failure of the refrigerant high pressure sensor/switch myself.
Went to the auto wrecking yard today and bought a used Trac accumulator (38k mile LS carcuss). On the way home I noticed that the Trac fail indicator wasn't illuminating. Once I got home I tested the Trac functionality in the method under which it failed every time yesterday, ten throttle tip-ins, in drive, with the parking brake set.
No failures.
So what gives?
I'm relatively sure that some past owner knew the Trac was failing and disabled the Trac fail bulb to prevent a new buyer from knowing/noticing.
On the other hand I was once also relatively sure that my work replacing the rear brake pads had created the failure via excess fluid in the master cylinder.
Oh, well, now I have a spare Trac accumulator, just in case.
My plan was to replace the accumulator and have Lexus drain and flush the brake system(s) and reset the airbag code 41 which I apparently caused inadvertantly by switching out the speedo/tach module without disconnecting the battery.
has 153,000. complete ac system has been replaced within last 3 years. all but condensor. all i did to create the situation was to switch the ignition off, to see if the compressor would start back up. it did, but the fans did not. i dont remember seeing these fans run but at one speed, and that seems to be a high speed. i did not know they are two speed. there is a switch that turns the fans on that is on the dryer. think this switch is ok if it turns them on?
Now I'm betting real money that the refrigerant pressure switch behind the passenger side headlight is intermittently failing. There are three switches/sensor in the one "module".
1. A low pressure switch that is open if there is little or no pressure in the system. This one prevents the compressor from running at all if there is not enough, or no, refrigerant in the system.
2. A high pressure switch, ~220PSI, that turns (sw opens) the compressor off once enough liquid refrigerant is accumulated on the pressure side upstream of the evaporator.
1 & 2 are in series internally to the module, either one open stops the compressor. 4 wires in the connector, one pair for 1 & 2, and one pair for 3.
3. A medium pressure switch ~100PSI(??) that activates the fans at low speed, series, 6 volts each, when the compressor has run long enough to begin accumulating liquid refrigerant.
The fourth sensor/switch is within the engine block, water jacket, and causes the fans to run at high speed, 12 volts each, if the engine water jacket temperature begins to climb in spite of the low speed fan operation.
If the engine water jacket temperature continues to climb even with the fans at full speed then the A/C compressor clutch circuit will be opened to prevent engine overheat.
Suction tube (bulge in this tube under and between the two condensor cooling fans)is covered with rime (white) ice at least 1/4" thick after about an hour of operation.
The A/C compressor doesn't shut down except if you turn it off somehow or it goes into engine overheat fault mode.
Refrigerant pressure switch(s)has/have failed.
Don't know why Lexus does not provide some protection/detection for this type of failure. Ford A/C system used to provide a fusible link between the high side and the low side such that if the pressure difference exceeded a certain value the high pressure due to continuous compressor operation was bypassed into the low side.
Apparently Lexus just lets the refrigerant keep being pumped until everything is frozen solid all the way to the compressor suction inlet and then the compressor itself fails due to "slugging", liquid refrigerant entering its suction side.
My 1999 LS 400 just rolled over 30,000 miles. Should transmission fluid be changed at 30,000 miles or just checked? I have heard Lexus recommends changing at 30,000 miles - my manuals say check at 30,000 miles?
What most do and we recommend [since Toyota T4 is an ultra premium product $6 quart] is a simple 3-3.75 quart pan drain and refill. While only 30% gets changed this way eventually enough additives get replentished for it to function.
The question is how long do you want the tranny to last 100k, 200k, or 300k. Replacement will cost you $4800......[5 speed AT].
Think the $25 plus labor is good insurance every 30k.
We have many customers with 90-92 LS400 with over 250k on cars same tranny [but this was a different 4 speed unit]. Since tranny was new for 98 not enough years/miles are showing to predicit how the 5 speed will last......YET!
IC600, on PCB sub-assembly 177232-0433 appears to be the reprogrammable microcontroller/microprocessor in the 1992 Lexus LS400 climate control module. 42 pin dip, pin 21 grnd, pin 41 & 42 both VCC.
Labelled:
D 151801-9434 501A 1109L 9125 Z41
"D" is most likely for Denso "9125 Z41" is undoubtedly a manufacturer date/batch code.
IC600 labelling is the same for a 1991 and 1992 climate control except for batch/date codes, 1991 climate control module is "9004 Z13".
CN7, connector 7, 4 pins, appears to be the programming connector.
Pin 4 is grnd. Pins 1,2,3 are connected to pins 24, 22, 23, in that order/sequence, of IC600, each through a 200 ohm resistor via IC800 resistor pak.
Anyone know who actually makes this microprocessor?
With the help of a mechanic from lexus(who works for my friends shop), we were able to diagnose my sound that comes from upfront when I go over a bump. I need to replace the right side lower ball joint. The shop charges at least $400-500. I could get the part for $76.00. Is this a simple install for myself? Do i need special tools? Whats involved? Someone got details?
Wish me luck!
Fritz
fritz@akerlund.net
In sum, a world of difference - very positive.
Good luck!
Help me
Dan
Maybe I need a new motor for my steering wheel?
Q45man, can you help me with any comment? Have you or anyone replaced a motor for the steering wheel?
Advise anyone?
thanks paul
It's time for a major tune up.
I'd suggest a brake fluid flush as well.
When all else fails, there's always the dealer.
Coincidence maybe?
Not just to the slipping wheel?
How stupid can Lexus be/get?
Corrected on later models with 4 channel ABS?
Hmmmmm....
How many miles?
No failures.
So what gives?
Labelled:
D
151801-9434
501A 1109L
9125 Z41
I suspect Toshiba.
