i thought i posted a msesage about the 'check engine light' problem that i have been experiencing since may. but, i can't seem to locate it or any replies to it.
basically, driving along and experience s slippage/braking/shuddering of the can (hyundai sonata gls v6 year 2000 - 14700 miles).
have had the maf sensor recall work done in dec 2000.
dutifully ratchet the gas tank cover after gas ups.
perplexed...about the check light problem...i do pull over and stop the car/shut off engine and then restart...no check engine light.
but, i could have an accident if this progresses to a stall condition.
perplexed, also,,,about not being able to see any comments from other owners experiencing this problem.
my email address was made public...so, i'll give it here, too...gervasi-joe@cooperhealth.edu.
Hyundai Sonata's tranny is orginally based on Mitsubishi's only mechanically. (Actually, it was developed step by step. Hyundai imported its design from Mitsubishi in 1980's. Then changed its design more than 10 times by itself. So you can hardly find the difference between Hyundai one and Mitsubishi one thesedays. However, I'm not sure that if U.S version Sonata has similar one with Mitsu's.)
Hyundai Electronics which has been world's second largest semi-conductor company has done a lot of electronic jobs on Hyundai Motor's transmission.
So, you can say, it is almost Hyundai one because thsesdays there are few original transmission in the world.
Just one month ago, Hyundai established new transmission company and built plant with Nissan's affliliation JATCO in Korea. It is a joint venture.
As for the shiftronic( we call it steptronic in Korea), I don't have complete information. I know that its logic(the way it works)is based on Porsche's tiptronic and Hyundai pays loyaty. Transmission's mechanical parts are Hyundai's own one.
Tony
Also, I talked to my salesman while killing time and he confirmed as best he could that the '02's will be here by mid-August. We looked at the Elantra GT, which they are selling for $15.5K loaded, no-dicker. I think the car looks damn good but then I've always liked Hatchbacks. Later.
Can you imagine the cost of an adjustment these days with twice as many valves?
IF possible, some dealers would charge you to replace the winter air or Korean air in your tires with summer air or American air if they could.
Thanks fo rthe clarification.
Tony
The car does has a slight shimmy in it though at 65-70 mph. This bugs me. It is not an isolated case as others on the Elantra forum have it too.
I had the tires balanced and rotated several times and really cant shake the shimmy as yet. It was not present in the beginning and started around 6 k miles, I have almost 9 k on it now since 12/01/01.
A little about the Sonata. Its doing well too with 13k on it. About 2 weekends ago I drove it and noticed a pronounced lull or hesitation when the engine is cold. You would think the wife would tell me this BUT NOooooooo!
I took it to work a few times and it always happened when cold and for about 3 blocks. It never starved for fuel at continuous highway speeds. I tried a can of mechanic-in-a-can and he didn't know what he was supposed to fix. A week later I pulled the Bosch Platinum +4s from it and had some new standard cheap plugs to put in their place. The +4s came out clean and all were evenly colored etc. They did not look as clean or bright as the ones looked when I removed them, BUT they were not in as long either. Anyways, with the plugs changed, I should have just waited till the morning to try the car out again, but as long as I was dirty and sweaty and in hot pursuit of this problem I opted to clean the throttle body with some of that STP throttle body cleaner. I had a car once that was giving me fits at low rpm and idle and cleaning it solved the problem. The Sonata TB was clean as can be. No gunk or discoloration or anything.
The car runs great again, even without the +4 screamers in it. SO, I dont know if it was th eplugs or some dirt in the throttle body!! Its my own fault BUT will not put the plugs back just to find out.
One thing I noticed and was rather PO'd about was not only do I use anti-seize compound on the plug threads BUT I do use the silicone lube on the plug boots, but never again. The stuff dried out and looked and felt like solder splash. It has totally dried out and not held up like it is supposed to. Never will I use that crud again.
What I am thinking BUT haven't told wifey yet is .... I may swap the wheels with the Sonata and Elantra in the name of science to see if I can sure the shimmy. I know pretty much in advance I will be too tired to swap em back though. This worries me as it is better to have a bumpy ride and smooth married life.
How's with you and your Sonata? Still screamin?
Tony
Also, I'm guessing the '00 came standard with remote entry; mine seems not to have it. (It wasn't sold w/ the remotes and my salesman couldn't figure out whether they were missing or never had them.) Is there a way to tell?
Lord only knows what rental car enthusiasts might have taught my transmission to do, but will it "change" according to how I now drive it? Sorry if that's a goofy question. It pretty much clunks from 2nd into 3rd.
I do wish it had more torque on the low end of the RPM spectrum; it seems sluggish from the get go.
Those Bosch platinum spark plugs y'all keep mentioning: 1) do they really work; 2) can I get them installed as part of my 15K (which is the next maintenance due) or will they nullify (the rest of my) warranty.
Thanks for the help. I think the car is really beautiful and unusual--there still are a lot stares. However, I MUST get a serious interior detail--Avis and my dealer left it a mess. AND there are no mats, only these cheap-[non-permissible content removed] black mats (I thought, dummy me, they were the regular mats turned upside down when I bought it).
sorry to ramble
The '99 GLS model had the keyless standard, I believe. In '00 it was optional. You may well not have it, especially being a former rental.
There is virtually no current Hyundai engine with decent low-end torque. It seems to be a corporate decision to design engines for smooth top-end and highway cruising.
I would advise getting the transmission fluid replaced at the 15K if it is not included at your service site. This may help smooth the shifting.
The GLS V-6 comes with Platinum tipped plugs standard which I find deliver fine performance. Many of those who have made the switch to the Bosch +4's have the I-4 engine which comes with a standard plug. The V-6 install of the +4's is more involved as the intake must be removed to access the rear bank. Installation of any component not standard with the car will not void your warranty. The worst case scenario means that any particular problem which can be shown to be directly caused by such an installation would be non-warrantable. That is true across the board.
And you can source the mats at
http://members.home.net/davefjeldsted/itmidx1.htm
as well as anywhere else. Focus Hyundai is usually very quick to respond.
Hope you enjoy your car and this forum. You might also try the T-H-C.org. if you haven't already.
I drive hard and in the upper 70`s so its been a good experience till now.i will keep u guys posted on whatz up with this light.
I suspect, however, (1) the Mercedes recliner was more predictable in operation and (2) the Mercedes recliner was NOT installed to promote owner napping during frequent, lengthy dealer service calls.
Recent Hyundai automobiles seem exceptional.
The old ones, however, were rather unreliable. All the electronic gadgetry possible would not compensate for the poor reliability record.
That said, my Sonata is still whirring along without trouble . . . and the gas mileage has actually started to improve a tad. I noticed another poster had the same problem I did: a Hyundai rep explained that this apparent ignition sensor problem does, occasionally, happen.
so cheers!!.i mean reputation does have a effect.i assumed the worst and did not even check the small things like a fuel tank cap ,i thought it was a major repair.to all i can say is i just love my car more with each passing day and mine always stands out in a parking lot of toyota and hondas and i really proud of this fact -- not another guy ! we r spl
I guess I deserve someone trying to get my Sonata, since the driver's kickpanel's been off for about a month, with various wires hanging down out of it. Still, even though I just need to tidy up the wires and replace that panel, I figured that my car would be relatively safe, since my flashing superbright Varad LED was clearly visible and the system fully functional, except for fine-tuning the shock sensor. Well, for whatever reason last night I tossed and turned and just couldn't go to sleep. About 2:50am my LCD pager remote started going crazy. The sad thing is that if it had displayed a shock sensor violation, I probably would've taken my time to check on it, however, the display showed a Door Trigger/Door Open Violation, which immediately put me into a state of shock and disbelief, thinking it had to be a stray signal or malfunction. I quickly threw on some pants and flip-flops and headed out the door. Between my door and the building's front door, I mistakenly disarmed the system, trying to shut off the beeping of the remote, rather than press the remote's reset/clear button. I immediately realized this, so I quickly pressed the arm/disarm button a few times, making sure it stayed on an armed status. I left out the front door of my condo building, took about 10 steps, then noticed an old Toyota mini-van (riff-raff resident of same condo complex) parked in the middle of the street near my Sonata, with it's lights off, rather than where I usually see it, parked 2-3 spaces away from mine. As soon I saw the van, the driver floored it, so I assume the engine had been running. Now, this guy lives on the further end of where my car was parked, and he certainly was not near his residence, rather he was in a great position as a look-out for anyone coming from my direction. If it hadn't been for the suspicious behavior of the guy/van sitting in the middle of the street with his lights off, then hitting the gas as soon as I came out at a fast walk, I probably would've thought the alarm system was malfunctioning or my pager received a stray signal. Anyhow, while checking out my car, I adjusted the shock sensor to be extra sensitive (the LED flashes w/sensor to help you adjust it) and took "The Club" out of the trunk and put it on the steering wheel (yes, I know the Club's not that effective). My car is fine and showed no signs of tampering, but I don't know if the siren even sounded, since it was parked a ways from my condo unit. I've taken down the guy's license plate number (he parked across from me this morning when I went to work) and am reporting the incident to the property manager, in case any similar events happen in the future, but I'm sure glad I got that pager remote. Like I said, if it had been a shock sensor violation, I probably wouldn't have taken it seriously, but a Door Trigger would either have to be the real deal or a serious malfunction.
Sonatava, sounds like you might have gotten lucky and stopped a theft.
Hopefully it won't happen to you again. Looks like that alarm is going to pay itself off.
The only continuing minor irritation is the door buzzing/vibration problem on some road surfaces which I tackled with foam strips and poly batting. Until I get some Dyna-Mat in these door panels, I'm sure I'll continue to hear something as time goes by.
All things considered, the GLS w/pkg 13 remains a standout 'value luxury' car. Since the recent 15K service and the 4 wheel balance and alignment, the car feels better, drives and performs better than it did when new. We are very pleased and I am especially happy since my wife loves her 'Moonbeam' more every day.
(On a side note, I have discovered through experimentation that I get a noticable improvement in gas mileage with Exxon gas. I used to use Amoco on a regular basis but began to question the efficacy of this when circumstances required other gas brands and I found my #'s going up with the exact same driving routines/history.)
Looking to August, the '02 Sonata should be even better with improved engineering, more power and even more goodies to play with. Oh, those compound curves!
Am at 22,000 mile mark for my '00 GLS. Still no problems. The dealer had to order the pollen air filter. Took about 3 weeks for him to get one.
The India Financial Times says Hyundai will launch the 2002 Sonata in July at the worldwide level. The debut for North America (which I hope it includes Canada as well) is expected to be late July. Then, probably is a matter of one month before we can see the "new thing" here.
For what I have seen in the internet, I couldn't agree more with Astrol about "those compund curves".
If you can go to the following address bellow, you will see the spy picture from Car and Driver Magazine. They say, the dimensions are equal to the BMW series 5, and the front grille just resembles de Mercedez Class C.
http://www.caranddriver.com/xp/Caranddriver/carnews/spy_target_hyundai_sonata.xml
And for those interested in the future of the brand, Autoweb.com.au (from Australia) forecast that probably in ten years Hyundai Motor will be one of the giants in the automotor industry in the world, because it is expected that Hyundai-Kia will be the leader in the chinese market, with total sales of 50 million cars every year by 2010. (three times the forecasted american market).
Here is the source if you are really interested in knowing who is going to provide you with spare parts for your today sonatas and eleantras in 10 years ahead:
http://www.autoweb.com.au/start_/showall_on/id_HYU/doc_hyu0001261/article.html
Sorry for the long answer!
However, the manager said they won't put them in b/c it's non-Hyundai part. He told me that Hyundai doesn't use platinum plugs & if I were to put them in, then it could void the warranty. Any feedbacks on this??? Chao.
PS - I think someone posted that V-6 has platinum plugs??? Is that right???
service dept read code & identified the output speed sensor needed to be replaced. part had to be ordered. car left overnight. repaired next day. ride seems fine so far.
sorry i didn't respond earlier...i was on vacation the week that the car went in for service.
thanks for reply and info on other web site (canada tech.)
I finally have most of my website up, showing details of changing the oil on the GLS's V6, the headlight reminder buzzer (which I routed through a notch made in the fusebox cover), and information and links for installing a keyless entry system, security alarm, and/or remote starter on a Sonata, or any other car. I know that by posting the details of my alarm installation makes my car a bit more vulnerable to theft, but I figure it's worth the risk. Keyless entry is really neat, a security system will usually give you an insurance discount and a bit of peace o' mind, and the remote starter is convenient in winter.
Most of the regular pages don't have photos, but the pages showing the actual installation may be slow-loading because of the images.
Tom's Sonata Pages
I went to a local car stereo establishment, and they laughed (what else?) when they heard the sound. After haggling to a decent package price ($800) I had them install a new Pioneer double din head unit (latest model FH P4000—very silver with blue LCD display and 200 watts) Blaupunkt 6x9s and 6.5 component speakers, plus a 12 CD changer and 8" Kenwood amplified sub tube in the trunk, and WOW!! what a difference. Now it not only looks like "da bomb" but sounds like "da bomb."
Apparently it was a somewhat difficult install, since it took three hours longer than they anticipated. The rear package shelf was a real challenge, as indicated by the look of total despair when they discovered what they'd really have to do to get to those speakers. However, they did a first rate job, despite the fact that they probably didn't make a dime.
Have any of you felt the audio quality was poor in your Sonatas? If so, did you go back to the dealer, or just go for the total replacement like I did?
Last night while driving I noticed the gas gauge slowly fall from 5/8ths tank to ZERO and back up a little in a matter of 2 miles!!!
I almost belived I was going to run out of gas !!
I always reset the odometer at each fill up so I knew I should be at 5/8ths.
Got home, went to bed hoping this bad dream would be over. It still read less than a 1/4.
I went to fill up and it only took 7 gallons which jives with the odometer reading.
Anyone else have this happen yet???
Tony
What are the current incentives on the Sonata?
A final observation: Hyundai did a great job with NVH on the Sonata. Too bad it was to the sacrifice of the suspension. Spring rates, strut valving, and, particularly, the suspension bushings are way too soft. The latter results in subtle changes in suspension geometry at high speeds on roads that are less than perfectly smooth. If you have a Sonata and enjoy high speed touring, you no exactly what I'm refering to. There can be a tendency for wandering off center that is disconcerting. But the fix is easy - offer a touring suspension option that uses the same suspension parts as those on vehicles headed for Germany an Italy. Surely the cars come down the same line, so the parts are right there. But do something. The American/Canadian/French suspension calibration just doesn't cut it. If I wanted a Buick ride I would've bought a Park Avenue. Come on, Hyundai, make this more of a drivers car. It would cost next to nothing. The parts are already there.
Had car in shop today getting the pollen filter replaced. Has about 21,500 miles on her. The dealer had to order the part the last time I was in for LOF.
Also the paint is cracking under the door handles. Is anyone else experiencing this problem? The dealer claims they are scratches and thus not covered by warrenty.
The return trip was under the same conditions except for heavy cross and head winds. Mileage dropped to a more standard 29mpg. It appears the effect of wind on mileage can't be overstated.
Funny thing though, my '95 Sonata 4 cyl. auto which lost overdrive a good while back has just returned an average of 25+mpg for the first time in over a year. The only difference was that I had to roll the windows down for ventilation during this period instead of using the AC as it needs a recharge. I would have thought that the effects of drag would have had a greater impact on mileage than the use of AC because I have normally been averaging 21mpg since losing overdrive. Perhaps it is only something peculiar to my car's running state when AC is engaged.
Hey! Now you guys have gone and really given me an idea!
Ever since the sensor triggering ignition spark was replaced (posted problem here earlier), the car runs beautifully: nothing to note since Hatfield Hyundai (Columbus, OH) did the repair.
Have noticed the mpg is starting to get a tad better, too.
Curious to know pros and cons other drivers have experienced so far.
Love my car - but am still a bit nervous about long-term reliability: this baby has to get me through medical school and residency because there is no way in hell I can afford another car over the next 8 years!
Happy motoring all . . . .
Sonatabean
I did not go for the Accent: it was too damn Spartan. My first car was a 1976 LeSabre Custom my mom cast off in 1984. It was a great car thru college: we could pile an entire fraternity in the car along with enough booze to keep a military base happy.
Went from a LeSabre (it was as-loaded as possible; every option, midnight blue, midnight blue leather) to a Geo Metro after graduation.
Metro was surprisingly reliable, but I learned a valuable lesson: I HATE ECONOMY CARS ! ! !
Followed with a Z (will never buy Chevrolet again: complete garbage; great sex appeal and speed, though) and then this Sonata.
Right after I bought the Sonata is when I decided to go back to school. The company I worked for went under . . . so I study, I incur debt, I drive a nice car.
Now, if I could just get adopted by a rich elderly couple . . . .
'Bean
moved from Arizona recently, the drive from there in my 01' Black Sonata GLS V6 Auto cruised with delight. Now I have a problem. The dealer I purchased my car from gave me 5 free oil changes to make up for the difference in Ad Fees when I dealed. Do you think any new Hyundai dealer might adopt/honor this freee offer?? I have 1800 miles on my car and got my first baptizing So. Cal car door ding. I'm hurting.:(
Time Magazine had a glowing review about Hyundai company, but did not mention the Sonata???
Another comment, I still think the only thing missing on this car to intice young and old buyer is a beautiful chrome hood ordament something like a Dragon on snake. (Kinda like the Jaguar) How can I get this idea to the manufactures??
Auto w/Pkg. 11. Purchased June 1st 2000. Now has 30,000 miles. Only problem so far is the drivers side power window regulator went bad last week and is being fixed next week under warranty. What I really want to know is does anyone know the Transmission Fluid capacity when changing w/filter. I intend on doing this myself as the dealer wants $100.00 and it only takes about 20 minutes if you work slowly. I guess i'll still have to buy the fluid and filter from the dealer because no parts stores here ever heard of SP-II.
Thanks in advance for any advice.
I have liked the Sonata alot since last year or so, and almost bought one. Just couldn't do it though, due to the car's soft handling. But still shocked that the Sonata is not too much more expensive than the Elantra GT. Color me surprised!
