A reporter would like to speak with you about your experience; please reach out to PR@Edmunds.com by 7/25 for details.
Lebaron Front End Problems
bpikulbpikul Member Posts: 1
edited March 2014 in Chrysler
1993 Chrysler Lebaron 4 Dr with 52,000 mi. 3days
ago, on highway, began to have Left front end
sounds that correlated with speed of the tire
rotation & associated with a rumble/ shimmying of
the left front wheel/end. Then, occurred at lows
speeds later that day; initiated with mild turn to
the right. Disappeared completely in between these
two episode. Garage replaced two front tires for
wear; balanced and aligned the wheels as well.
Now, repeat of the same sound with less shaking of
that left front tire on mild right turn. Any
suggestions? Steering linkage? Feels /sounds like
a "bump, bump, bump" with each revolution of the
wheel. I appreciate any response. BP
  • bobs5bobs5 Member Posts: 557
    www.allpar.com
    This site has lots of chrysler information as well as a "techinal support board". This board is like edmunds townhall, but with a lot of helpful people who own chrysler vehicles. They may have some suggestions about your problem.
    If your car is front wheel drive, it sounds like a cv joint may be going out. A warped brake rotor may cause a similar sound.
    Good luck
