Brakes ... Honda 98 V6 accord
Sorry if this in a mis-placed question but I
didn't want to get into the Honda vs. all other
vehicle Quality thread and the other Honda Brake
thread is close. (posted a q on the Brake thread
and now it seems to have vanished)
I've just taken my vehicle in for a dealer 30,000
mi. service and found out that the rear brakes were
reported to be at 15% (while the front were at
25%). Dealer recommends replacement at 20%.
I'm curious if a rear brake service after a short
30,000 miles (I've got 29,900 actually) is normal?
I thought this was a front wheel drive and
expected most of the wear to occur in the front.
30,000 seems very early to me. I'm no expert
since my point of comparison being a standard trans
'84 supra I drove till '98 and put 150,000 miles
on, never having to replace the brakes. Was I
living in a fantasy world?!
Thanks in advance.
Thanks in advance.
I have a 98 EX 4 cylinder auto and just had the rear brakes done at 30K as well. I was surprised when the dealer called me and said that the brakes would need to be done within 3K miles.
I asked how the front brakes were and was told they were fine. I accepted that as possible because when I had the 15K service done (different dealer), they had replaced the front rotors under warranty and I presumed the pads were replaced at the same time. I later checked my 15K paperwork and the pads were not listed (doesn't mean they did not change them). Alas, I authorized the rear brake work a week later.
I know how uou must have felt re brakes at 30K. My previous car was a 91 Accord 5 sp which needed only front pads at 112K. I know I drive this automatic much harder, but traffic here in Boston has become much heavier thanks to the great economy.
Anyway, I'm in No Cal now, different dealer, for the 30K service. I'm still pretty frustrated with this whole thing. No one's been able to give me any more information and I'm left feeling that I got things stuck to me by the dealer.
Maybe no one else with this vehicle's (besides you) has put this many miles are their car yet? I find that hard to believe.
I have 106K on my front pads and estimate they will be good till at least 150K. One reason these techs maybe replacing the rear shoes is that it is relatively hard to see how much is left on the shoes. I would also suggest asking for the shoes they took off the car-yeah there is a core charge of maybe $5-if they are real crooks-and I suspect they are-they will show you a set of worn out shoes and not yours.
Still remember showing a neighbor of mine how to change the oil on his 2 year old Accord-it still had the original filter on it-was so stuck had to use a filter wrench to get it off the car-the local Atlanta Honda dealer had been doing his service. Be careful-there are some real crooks out there.
Here's hoping these last me longer.
I believe they have used 2 different materials for the rear brakes also, but I don't know what has been used on the Accord specifically. I do know that my '98 CL uses non-metallic pads. I suspect, although I don't know, that these pads mean there is less overall wear on the brake system. Result? With my heavy braking, I still have not replaced anything going on 46,000 miles. In contrast, my Integra, which had metallic pads btw, had the rears chewed up completely by 30,000k, and needed new rotors and pads. One way to tell which you have: Do your brakes grind slightly every single morning when you first hit them? Then they are metallic.
Honda Accord Problems (Topic #1398)
You may or may not have noticed, but we are having a lot of problems with out host software recently, and keeping similar discussions all in one place may help. Besides, there is an experienced Honda tech hanging out in that topic who has been a great help to all of our Honda owning members.
So please, follow that link and let's continue this discussion there.
Pat
